MY COMPUTER SHUT DOWN UNEXPECTEDLY AND WON'T TURN ON AGAIN
MY T410 WAS RUNNING FINE ON BATTERY. I LEFT IT FOR FEW MINUTES AND WHEN I RETURN IT HAD SHUT DOWN. I TURNED IT ON, PLUGGED THE ADAPTER BUT IT'S STILL NOT COMING. THE POWER INDICATOR AND THE FINGER PRINT LIGHT ALL DO NOT COME. PLEASE HELP ME
    Problem Solver:
  • 5 Answers
I usually try to hold the power button for >5 seconds to reset it. No lights even when plugged in?
Posted on Jan 01, 2013
  • FRED Jan 02, 2013
    yes mike no light even when plugged in.
  • miketbob
    miketbob Jan 06, 2013
    Shut down Unplug the power supply. Remove the battery. Insert power cord Reboot with power cord but no battery If it comes up, your battery is dead or weak Replace the battery. If you don't even get a flash, your power supply may be bad. Get a new power suppy. If it continues the restart cycling, then there's something wrong elsewhere.
5 Suggested Answers
  • 177 Answers
SOURCE: Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Posted on Mar 07, 2010
  • 81 Answers
SOURCE: blinking AC light with/without battery, computer shuts down
I want to try a very simple thing, cause it happened to me, while I am working on my computer , it shut down unexpectedly... cause the processor is working with its full performance and no enough cooling around the laptop. so while I move to other place and also I raise the laptop a little bit from the back to let the fans (bottom of the laptop) works perfectly .
try to open it again and do so.... may be it is a so simple thing that was far from your mind like I was before... good luck
Posted on Nov 30, 2008
lyonzy1
  • 208 Answers
SOURCE: Targus COMPACT laptop charger isn't working
Your battery sounds like its buggered. I would suggest buying a new battery
Posted on May 20, 2010
leecom72
  • 4806 Answers
SOURCE: Toshiba Satellite C655-S5082. Won't power
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Posted on Jul 16, 2011
Gateway MT6840 unexpectedly shut down and wouldn't
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 12, 2013 | Computers & Internet
BIOS Update was interrupted. Now laptop won't boot up.
basically your screwed , if the laptop is still under warranty I would return it without telling them u tried to flash the bios....ergo if they find out you will not be covered for warranty
the only other thing you may be able to try is inside of the laptop casing should be a small round battery usually wrapped in heatshrink or alike if you unplug that then unplug power source (main battery) and hold power button down for about 30 sec then replce both batteries and turn on it may reset bios to factory but is highly unlikely!!! you may need to contact the creator of the nios system!!!
Jan 25, 2013 | Intel Lenovo ThinkPad T410 2518F4U 141in...
Bosch Axxis WTE86300US turns itself off after ten minutes, won't turn back on for a few minutes after that
I would bet you have a bad sensor. There are a couple of sensors that monitor heat. When it gets too hot they shut it down as a safety precaution. Once it is cool enough it will start up again.
Sep 26, 2012 | Bosch Dryers
Lenovo t410 reset bios password
Follow these steps to clear the password:
NOTE: These steps also clear CMOS.
1. Shut down the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power from the computer by first unplugging the power cord from the AC outlet and
then unplugging the AC adapter from the computer.
4. Remove the battery
5. Remove the real-time clock (RTC) battery
6. Wait approximately 30 minutes.
7. Replace the RTC battery and reassemble the computer.
8. Connect AC power to the computer. Do not reinsert any batteries at this time.
9. Turn on the computer.
All passwords and all CMOS settings have been cleared.
Aug 06, 2012 | Intel Biostar P4TSE-D2 865 Chipset...
98 Buick Regal won't run unless hooked for a jump.
you may have a bad ground, or the ignition switch needs to be replaced.
Jul 28, 2012 | 1998 Buick Regal
Asus u52 shut down unexpectedly
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jun 17, 2012 | ASUS U52F-BBL9 Laptop
Hp pavillion dv9815 won't start. it just reboots over and over. shutting down each time.
take out the battery, then take out the memory. Put one of the two memory modules back in, and turn it on. If everything looks ok, shut down and put the other one back and try again...if everything is ok...then ok. If it doesn't work after the first one, let me know...
Jun 11, 2012 | HP Computers & Internet
I have a Maytag PYE2200AYW electric dryer. we had problems a few weeks ago and discovered that the blower wheel was cracked, so we replaced it (part # 31001317). Then a couple days later it just stops and...
Check the thermal fuse and thermostats again to eliminate them as suspects. Both should be zero ohms at room temperature. If you eyed the entire duct system from lint filter to outside of the house for lint, then these are probably OK.
One thing that will shut down a dryer: a defective door switch. If you turn the timer on with the door shut and can hear or see it progressing (running) then the door switch is OK.
If your door switch is operating marginally, the heat can expand the body of the switch and open the circuit (and shut the dryer off until it cools). Check the switch with an ohmmeter with the dryer disconnected from power.
A loose spade terminal on this switch (or anywhere else) can do this too.
Also, a misaligned door or defective door clasp might do this after heating up.
Keep thinking 'heat expands' and you might find it.
The only other thing left is a defective timer.
Good luck from Detroit, MI.
Jun 11, 2011 | Maytag PYE2200 Dryer
Computers & Internet Logo
123 people viewed this question
David Payne
David Payne
