Question about Kenmore Refrigerators
Kenmore Elite 71053
How to remove left side door
  • 1122 Answers
SOURCE: Kenmore elite refrigerator door leak
your drain in the bottom of freezer is clogged or frozen,use a hanger or if it is frozen use a hair dryer,thanks-mike
Posted on May 31, 2008
Sea Breeze
  • 4655 Answers
SOURCE: the left door of the fridge was open all day.
Get me the model number and I will try to get you going,
model number will be like 213.89547 on front bottom frame
Thanks, Sea Breeze
Posted on Mar 21, 2009
  • 14 Answers
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
Posted on Apr 04, 2009
  • 77 Answers
SOURCE: remove faceplate in door of a kenmore frig.
If you look at the bottom of the facial plate, underneath. There are two slots to insert a flat screw driver. You should be able to access everything once you take that off. Good luck
Posted on Apr 24, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite model # 795.77564600
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 23, 2010
How to make the freezer door on a kenmore elite 74033 tilt
Refrig of the year: Kenmore Elite 74033 Refrigerator
Consumer Reports Rated: Excellent
Hello Charles,
Just when I'm thinking Sears SERVICE is NOT some sort
of sad/bad joke... you put in a Kenmore Elite Model number...
continued search found your Owners Manual... Pages 10 & 16 are what you want
The front should be slightly higher than the rear to aid in door closing... (page 10)
Your refrigerator has two front leveling legs-one on the right and one on the left. Adjust the legs to alter the tilt from front-to-back or side-to-side. If your refrigerator seems unsteady, or you want the doors to close more easily, adjust the refrigerator's tilt using the instructions below: NOTE: Tools Required: 11/16" wrench or flat blade screwdriver.
1. Turn the leveling leg to the left to raise that side of the refrigerator or to the right to lower it. It may take several turns of the leveling leg to adjust the tilt of the refrigerator.
NOTE: Having someone push backward against the top of the refrigerator takes some weight off of the leveling legs. This makes it easier to adjust the legs.
2. Open both doors again and check to make sure that they close easily. If the doors do not close easily, tilt the refrigerator slightly more to the rear by turning both leveling legs to the left. It may take several more turns, and you should turn both leveling legs the same amount... (page 16)
`` After that...
All you have to do to maximize that efficiency is keep the closure area free of pizza boxes, ice cubes or errant frozen food bags.
Hope this was helpful...
Kenmore Elite 74033 Refrigerator Review Kenmore com
Feb 12, 2016 | Kenmore Refrigerators
What tempature should i set my refrigarator it is not cooling?
what is the freezer section doing .if cold but not freezing ice cream really hard call a repairman as it needs gas recharge
Jun 25, 2015 | Kenmore Refrigerators
Freezer door does not close all the way
Remove the tray, pull door all the way out and check to see if it is spare. Sometimes the gears jump causeing one side to seal and the other dosent. If that is the issue, use pressure to square door
Aug 19, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Is it possible to reverse door swing on dryer? My daughter has a new Elite front load dryer that swings from left.
REVERSING DOOR SWING
Your dryer is designed so the door swing may be reversed at any time without additional parts. Conversion is accomplished by transferring hinges to the opposite side of the cabinet.
To change the direction of the door opening:
1. Open the dryer door. Remove the four hinge hole plugs from the left side of the door opening. Place nearby for future installation. NOTE: You may need a plastic knife to help pull out the plugs. Be careful not to scratch the paint.
2. Remove the four screws that secure the door hinges to the dryer front panel (see below). NOTE: Remove one screw from each of the two hinges first. Hold the door firmly before removing the last two screws.
3. Rotate the door 180° and reinstall the door hinges to the dryer front panel with the four screws.
4. Install the four hinge hole plugs in the open screw holes on the right side of the door opening.
Hope this helped Tim
Dec 01, 2010 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore elite Model #795 7554 2501 MFg date 2005-01. The water container behind the left door is leaking I need a replacement. Can you help
in trying to locate this model # with sears data base it didn't come up. i don't know of any kenmore that has a water container behind the left door . left door being the freezer door .. the water container is located in the botttom of fresh food side in the back behind the crispers . if thers a leak in the freezer door i would think that it a water line that is carcked or come loose .. mm hope this helps .. pls reck your model # and in needed get back with me ..mm
Oct 21, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Removing door handles
Charlene,
You need to use a small allen wrench. There are small holes on the top and botton side of each door handle and underneath on the right and left side of the freezer handle. Just insert the proper size allen wrench in each hole and unscrew the handles.
Regards,
Ann
Nov 17, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Remove Doors on Side by Side Kenmore Elite Refrigerator with water tube
this is the new style connectors push in on the blue end of the connector and pull on the hose it will come out of the quick connect connector
Apr 25, 2008 | Kenmore Elite 20972
Refrigerators Logo
73 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
