Question about Electrolux 10pk / Stihl / Echo / Jonsered / Husqvarna / Homelite Cj8y Pr18y 10pk
Spark plug oils up,will tick over but wont rev up,ok for the first ten minutes
    New Friend:
  • 30 Answers
Your fuel oil mix should be 50 to 1 If it is too rich it will foul the plug.
Posted on Jan 01, 2013
Mitsubishi Magna 2013 v6, top motor ticking, cruise control not working, car shudders when at traffic lights, replaced Dizzy, leads , spark plugs. Added injector cleaner to fuel, and something to free the...
Ticking is a loose valve, needs valve adjustment. Oil on spark plug is most likely a bad piston ring. Which goes in conjunction with shudders when stopped. Sometimes you can see this by running the car for a few minutes, then open the oil fill cap and smell, if it smells like gas or exhaust then its definitely bad rings. Ultimate test would be to pressure test the cylinders.
Nov 02, 2013 | Cars & Trucks
2002 yukon wont start
Ok you might need to open and close your key switch about ten times before trying to start it. Off position the on position, not start but on then off. Ten time.
Nov 26, 2017 | 2002 GMC Yukon XL
Bike wont hold its revs
do you mean it wont tick over or wont rev up ? could be spark plug etc or the carb needs cleaning
May 12, 2011 | 2011 CCM SM 125
I have a Yamaha dt125 R 2004 I've just had the engine rebuilt, re-bore with new crank and piston etc. I've just had my bike out for a run about after about a month without being started. It started on...
Your description sounds like a fuel related issue. Try connecting an external fuel source and test again. there is a screen in the fuel tank that gets plugged, and so does the filter... If external source does not help, look into the carb(s).
Carry an extra spark plug, and when failure happens, pull the plug wire and hook it to the extra plug, and ground the plug against the engine.....does it spark? If it has a good spark, the ignition is not likely your issue. If spark is very poor, ignition heat issues may need to be addressed.
Mar 22, 2011 | 2004 Yamaha DT 125 R
Problem kick starting yamaha wr400f,i have been using the de-compressor after trying for thirty minutes nothing,then had a few goes at bumping it off got started let it run for ten minutes then turned it...
Check the battery. If the voltage is low, you'll have a weak spark. If the battery is good, check the spark plug for proper gap - a worn plug can cause hard starting. Another possibility is degraded fuel; ethanol/gasoline mixtures deteriorate in a few months. If the engine fires off with a squirt of starter fluid in the throttle body, then dies, it's a fuel problem.
Aug 05, 2017 | Yamaha WR 400 F Motorcycles
Why wont my chainsaw tick over, it revs up but not tick over. also, cannot start it after 2-3 mins of usage, why?
Check the air cleaner and muffler for plugging. Try turning the idle speed screw (not the L jet screw) CW one full turn. Does it now idle? If the chain keeps turning at idle, back off the speed screw until the chain stops after revving the engine. When the engine won't start, remove the spark plug and check for blue, snappy spark. If the plug insulator is black, try a new correct type plug. If sparks ok, then squirt some fuel mix into the plug hole, replace the plug and try to start. If you get a pop or two, then fuel delivery is a likely problem. If it again runs, the plug may have been the problem. Otherwise, check the fuel filter, fuel line, and carburetor for any loose fasteners. Finally, run the engine at full throttle--it should 4-stroke with no load, but immediately 2-stroke when cutting. Adjust the H jet needle to achieve this. hope this helps!
May 19, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Car won't start, new battery, starter ok, just won't kick over Saturn 2004, 80,000 miles, oil change 2 months ago,
If the starter/Battery are ok.Check for spark by pulling off a sparkplug wire,have someone try to start hold wire near sparkplug tip you'll hear the spark jump to the plug tick..tick..tick..sound.Be carefull to hold wire just far enough to hear spark,also this is the secondary circuit from the coil it's high voltage wear a glove.If you smell gas youre geting gas if no spark it is 1 of the following.Bad Coil, or ignition modulator, crack in distributer, cracked wires that cause spark to not reach plugs.Good Luck.
Sep 09, 2009 | Saturn SL2 Cars & Trucks
E34 wont start e34 525i se
Seems that the fuel pump quit, check for fuel pressure, check for spark in the plugs and the fuel filter.
Jul 21, 2009 | 1994 BMW 5 Series
Ticking in motor, then stops for about a month, then starts ticking again. oil changed. in nuetral it wont rev past 3500 rpm
It wont rev past 3500 in driving?
The governer on these is set to NOT allow a higher rev when car is stopped and not in gear.
Try to change oil viscosity or filter manufacturer.Some filter manufactures put in a bypass valve that kicks in too early.
Jul 11, 2009 | 2004 Mercury Mountaineer
Will start up run for awhile then stall and wont restart
Hello, I would start with a general tune up. Spark plugs and wires, Fuel Filter, Oil Change and Filter Change, Air Filter Change, Some injector cleaner would not hurt eirther. Be sure to lubricate your high mileage car and also use a farily good oil for your motor as well. The run for awhile problem sounds like bad spark plugs. I would change your spark plugs, wires, distributor cap, and rotarty button.
May 20, 2009 | 1993 Honda Accord
Electrolux 10pk / Stihl / Echo / Jonsered / Husqvarna / Homelite Cj8y Pr18y 10pk Logo
62 people viewed this question
Top Electrolux Garden Experts
Phil Walker
Phil Walker
John
Are you an Electrolux Garden Expert? Answer questions, earn points and help others
