Question about Iomega Nas Computers & Internet
Reset my IOMEGA MDHD500-N.
I want to reset my IOMEGA MDHD500-N because I can't ping it anymore. Maybe I've given a wrong IP-address. Iomega Discovery tool don't find it anymore. Connecting with USB still works. Pressing the reset button (up to 30sec) seems not working.
2 Suggested Answers
  • 26 Answers
SOURCE: where i can download Iomega Discovery Tool???
Here.
Posted on Dec 14, 2010
Ping ip address
I think there may be a connection problem from your side or in that ip address you pining.So better reset the modem or router then ping it.
To ping ip address you can use method in windows XP.
Goto start-run-command prompt-Ping ip address
For example: Ping 55.253.12.86
You can ping ip address or website using the site Whoisxy.com
May 21, 2013 | Computers & Internet
My mdhd500-n won't connect to new router because it's on a different subnet how do I change it.
The hard drive may still have an old IP address. Set your network hard drive to DHCP. Make sure the IP clears and it is on the routers IP subnet. Just ping the router
Go to Start > Search (Run in XP) and type cmd ENTER. In the command prompt type ipconfig /all ENTER.
Oct 25, 2012 | Computers & Internet
DAP-1360 won't respond or reset.
Click the Windows 7 "Start" button.
Type 'CMD' into the search-box, and press ENTER.
Type 'IPCONFIG /ALL' and press ENTER.
Look for the IP-address of the "gateway" (or "DHCP-server").
Type that IP-address into your web-browser.
Jul 31, 2012 | D-Link Wireless N Access Point Dap-1360 -...
Router keeps losing WAN conection, but led lamp is blinking...
maybe new aerial finds more wifi hot spots, mine started doing that when i changed router port forwarding. but if in doubt just press reset button for 10 secs - might need to se paper clip and look hard around router for a little hole to stick it in..
...lol
Jul 12, 2017 | ASUS RTN10 wireless router
404 not found
that mean if the website not valid anymore.
it can be deleted or removed.suspend by the Web hosting or can be Block by the internet Provider.
but to make sure if the website is still valid or not valid,
try to input the ip address of that website at the Address bar web browser you've use.
for knowing ip address from website,open Command Prompt(CMD),
type PING (space) website Address and the enter.
to open CMD,click start > click RUN... > type CMD > click OK/Enter
for Example see the Picture below :
Jan 07, 2012 | Computers & Internet
I had a computer person set up our router before, but we have moved and now I want to set it up myself a different way. I want to have access to wireless internet. Initially I was able to put in the IP...
You probably disabled http and https admin. Locate the reset button on the back and hold it for 10 seconds. Reset maybe located in a pin hole on the back, use a pin or paper clip to press it. Refer to the setup doc for default user/pass. Typically admin/admin.
Comment back if you need further assistance.
Aug 31, 2011 | CP International WBR-3406TX Wireless...
I'm using two Macintosh Computers. I followed the quick setup wizard, all the right lights are lit. I've reset my broadband modem, I've reset the Dynex Router. Yet I can't make contact...
Richard have you tried setting up static ip addresses on the MACs
If you have other p.c's on network with auto ip assignment then alter the DHCP server lease to 192.168.1.10 to 192.168.1.240
then make ip address static 192.168.1.241 subnet mask 255.255.255.0 default gateway 192.168.1.1 and on the other mac
make ip address static 192.168.1.242 subnet mask 255.255.255.0 default gateway 192.168.1.1
http://www.macinstruct.com/node/550
Jul 07, 2017 | Dynex DX-E402 Router
Power indicator keep on blinking
hello!
blinking power light after firmware upgrade sometimes indicates that the upgrade is not sucessful or the firmware that you load is incorrect.
-- try to reset the router for 30secs and check if the power light is still blinking
-- if its still blinking check your pc's ip address while connected to the router
-- if the ip address of your pc is invalid (169.x.x.x.) turn to manually assign static ip address to your computer and check if you can ping your routers ip address
-- if you can ping the routers ip address, upload the correct firmware to your router
-- if you cant ping your routers ip address still, reset the router again and try to ping the routers ip address once again
-- try to change port and cables
-- if still unable to ping the routers ip address, chances are that the router might be defective now
Apr 29, 2008 | Linksys Wireless-G WRT54GS Router...
Cannot hook up to the interner with the router connected not sure which wire is not hooked up correctly
Try to ping the ip of another computer, to know if what is the ip of the computer. Type in the run CMD and the dos windows type ipconfig and look for the ip address. to ping the other ip address to probe that your setup of lan is ok. type PING the ip address of computer and hit enter if you see reply from it means your network connection is ok but if see request time out the setup configuration of your network have a problem. If still not working try to reset the reset button of the router to his default value in try to connect
Apr 16, 2008 | Computers & Internet
Cannot find print server at all
How this works: Restoring the PocketPrintServer to Factory Defaults In most cases, the best way to restore the PocketPrintServer to factory defaults is through "telnet". However, if you are unable to connect to the device because of a configuration error, use the following method which does not require a network connection. To restore the PocketPrintServer to factory defaults, complete the following steps: 1. Disconnect the PocketPrintServer from the network and power cycle it. When it powers up, the LED will rapidly blink orange for five seconds. 2. Power down the device during the rapid orange blink period. Power up the device and power it down during that orange blink period two more times. 3. Reconnect the network cable and power up the PocketPrintServer. It will have restored itself to factory defaults and will rapidly blink green as it searches for a RARP or BOOTP server to find an IP address. Gleaning If an IP address has not been permanently assigned when the PocketPrintServer is powered on or reset, it will look for a "ping" packet on the network. If the PocketPrintServer receives a "ping" packet within two minutes, it will accept the IP address in the "ping" packet as its own address. To use Gleaning, you must have super-user privileges on a UNIX system. Gleaning also works under Windows 95 and Windows NT. 1. Add an entry in the ARP table that assigns an IP address to the Ethernet address of the PocketPrintServer. To do this, use the "arp" command. arp -s temp Example: arp -s 192.168.42.24 00:02:16:00:00:01 temp 2. Start a continuous "ping" to the PocketPrintServer. ping Example: ping 192.168.42.24 On some systems, this may require an additional parameter. Some implementations of "ping" only send out one "ping" packet which could get lost in transit. Check your system documentation for more information. 3. Connect power to the PocketPrintServer. The PocketPrintServer will "glean" its IP address from the "ping" packet. This IP address will remain in effect until the PocketPrintServer is power cycled or reset. Therefore, a permanent IP address should be assigned by running the ExtendView TCP/IP utility or via "telnet".
Jan 30, 2007 | Extended Systems Pocket Print Server
Computers & Internet Logo
2,091 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
