Question about Teac R-H500 Dual Cassette Deck
My Teac LP-R500 audio cassette player squeaks when playing. Tapes do not squeak on my other player.
The machine is only 6 months old so not over used. It worked OK for a week or so after using an old head cleaner tape. Is there a head cleaner system you recommend. Thank you.
  • Teac Master
  • 1,258 Answers
It all depends on where the squeak is coming from. Some very clean rubber parts make kind of a squeak but I don't think that is your problem if you use cartridge cleaning systems. The real answer as a 40 year plus Tape Deck Technician is to get in there and see what is causing the squeak- it may need some oil in reel table, Pinch Roller or even the Capstan Bearing. Manufacturers do not like to put oil into
unit as it makes for no repairs and you will not have to buy a new one.
I worked at Teac but this unit is far after my exit- I still do repairs full time on the product though. I am sure I could resolve it- I am in the Chicago are.
Posted on Jan 02, 2013
  • Ron McCranor Jan 03, 2013
    Thank you Sam, I live out in the Atlantic Ocean in the Scottish outer Hebrides,Western Isles so I can't pop over to see you so I will try and tackle it myself. So what oil do you use inside a cassette deck? Thank you again, Ron
  • Sam Palermo
    Sam Palermo Jan 03, 2013
    I use a number of different oils, sewing machine oil, service oil as from a service shop supplier, Tri Flow and synthetic oil depends on the application and size of bearing. Any would work. Light grade synthetic motor oil has been used.
4 Suggested Answers
SOURCE: cassette playback
Hi, I am brand new to this site. So I may not be very good. However your prob sounds like one I had a few years back. I solved mine by using two pencils, one in each hub.
Then winding manually from one to the other. This is quite time consuming, but it worked for me. Hope this helps, if not, sorry for wasting your time.
Posted on Jun 19, 2008
robotek
  • 1512 Answers
SOURCE: My Teac R-H500 tape deck will not play tapes
The belts will have failed. You will need to replace them for the deck to be reliable. If you are mechanically minded I can talk you through it... You giving me a FixYa rating will help my profile and loosen my lips on how to overhaul your deck. :)
Posted on Feb 14, 2008
  • 53 Answers
SOURCE: cassette recorder loads tape but will not play it
make sure the tape clamp is fully clicking down when the drawer has closed
Posted on Nov 07, 2009
How can I get an instruction manual?
Recording from tape is very similar to recording from the turntable, but you have to select tape as the source. There will be a button labelled something like PHONO/TAPE/AUX with which you select TAPE and then record as you would for a vinyl disc but you press play on the tape instead of playing a record. Here's something very similar which should help you. Good luck and I hope you get to save your memories.
http://www.teac.com/content/downloads/products/755/lp-r550usb_om_efs_va.pdf
May 12, 2014 | ANDERS NICHOLSON USB Turntable With CD...
Teac GF-350 CD Shelf System
Firstly double check that the recordable discs you have bear the label "Digital Audio" on them as per the attached picture. Secondly what happens when you go through the finialise procedure in the manual? Do you see the ?FIn--d? display when you select the finialise button? Do you see ?NO TOC? and ?REC? indicators blinking at the next step? Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 27, 2007 | Teac GF-350 CD Shelf System
Question (not a "problem") -
Yes, you can. You need a cable (A 3.5 to 3.5 audio jack - you can buy it for a few bucks at your local store) that plugs into the Microphone jack in the computer and the Headphone jack in the cassette player. After that, use a recording software (Such as AudaCity) and select the input microphone as the recording device. All you have to do, is press Record in the software and push play on the player. Good luck and best regards,Yuri.
Jun 04, 2011 | Arcsoft ShowBiz DVD 2 (3265)
My Electrolux washer is only 6 months old and the drum has started squeaking. What could the problem be?
NOT Solution - I just bought one last week and it squeaked for me today. Sounded like a belt. As the washer added more water to the drum to soak the clothes, the squeak went away. So not sure if belt slightly out of alignment - hence it rubs or perhaps a roller knob needs adjustment is what I am thinking.
Sep 23, 2009 | Electrolux AWF 1435 Front Load Washer
IT PLAYS TAPES SLOW
can i buy your panasonic rx-dt75. i have that model almost 15 yrs to me made in japan. but this past few months cd and tape do not work... contact me here +639392859269
Jan 06, 2009 | Panasonic Portable Radio/Cassette Player
Clean machine damages my tapes!
Replace the belts and ensure the clutch is working correctly.
Mar 11, 2017 | Sony TC-KE500S Dual Cassette Deck
Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
Nov 24, 2008 | Sony Handycam DCR-TRV730 Digital Camcorder
URGENT HELP cassette player problem, please reply
I HAD EXACTLY THE SAME PROBLEM ALL I DID WAS TAKE APART MOVED ALL WHEELS AND COGS IN SIDE AND JUST BLEW OUT ANY DUST CLIPPED BACK TOGETHER AND WORKED FINE PLAYS GREAT HENCE WHY IM LISTING IT ON EBAY.HOPE YOU HAVE SUCCESS
May 18, 2008 | Audio Players & Recorders
Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
Dec 06, 2007 | Video Cameras
Teac A-21 Stereo Cassette Tape Deck turns un, but won't play cassette tapes...
very likely that the drive belt has broken. I have fixed a TEAC myself using a large O-Ring from a hardware store (I know I was lucky to find a very close match). Open the unit and find the broken belt and take it to a hardware store to "size up" a replacement. Use the opportunity to oil the gear shafts and clean the rubber pinch roller.
Jun 22, 2007 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
Teac R-H500 Dual Cassette Deck Logo
443 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
