Canon MX715 - Paper won't load
Hi. I have a brand new MX715 and I can't get the paper to load. I've tried all sorts of things, more paper, less paper, fanned the paper but I still get an error message saying the cassette is empty. Can anyone help?
SOURCE: CANON MF4140 'LOAD CORRECT PAPER CASSETTE : LTR'
I had same thing happen after a fresh Windows install. It was hard to figure out since it had been working fine until then, but luckily it is simple to fix. Open the Start Menu > Settings > Printers and Faxes folder. Then right-click on the Canon MF4100 Series printer and choose Printing Preferences. In there, change the Paper Size to Letter (instead of A4). You may also have to do this in the Print setup for whatever program you're using to print.
Posted on Nov 14, 2008
I had the same cr@p of the problem yesterday. The problem was not in the paper. You have to do 2 simple things, from which one will solve the problem.
first, download the latest drivers and install them.
And the more important thing, the problem occurred due to incorrect paper format. Solution is very simple. Open MS word or something similar, file->print.. and before you print open Properties menu. There for the Output Size will be selected "Match Page Size". you don't want that (i don't know why it doesn't work), but the solution is manually select A4, or whatever your page size is.
Posted on Dec 27, 2008
I had the same cr@p of the problem yesterday. The problem was not inthe paper. You have to do 2 simple things, from which one will solvethe problem.
And the more important thing, the problem occurred due to incorrectpaper format. Solution is very simple. Open MS word or somethingsimilar, file->print.. and before you print open Properties menu.There for the Output Size will be selected "Match Page Size". you don'twant that (i don't know why it doesn't work), but the solution ismanually select A4, or whatever your page size is.
And there it is... printer starts throwing pages out like crazy :)))
SOURCE: Error - Canon MP830
this Model has a paper tray on the bottom. Put some paper in the bottom tray and then voila..I had the same issue and i looked and the tray was empty..put some paper in..works just fine
Posted on Feb 03, 2009
SOURCE: Canon MP600 paper wont feed- error message- HELP!
Right ... After 5 minutes of looking and fiddling I have found the solution!! press the button abover HOME and it should change the tray in which you are printing from :D
Problem solved
Posted on Feb 08, 2009
FUJI XEROX CM205fw can't set custom paper size
So I am not the only one encountering the same problem! Printing A4 & DL are great but it simply does not let me print A6 properly no matter how hard I tried to configure the paper size (at the printer settings, printer preferences, the application settings etc)
Can Fuji Xerox fix this?
Apr 26, 2012 | Office Equipment & Supplies
Canon Inkjet, Not Printing?
Hi Rosa,
There was a paper jam and you cleared the jam, however you missed out to do one other thing. Cleaning the Rollers.
If the Paper Feed Roller is dirty or paper powder is attached to it, paper may not be fed properly.
In this case, clean the Paper Feed Roller. Cleaning will wear out the Paper Feed Roller, so perform this only when necessary.
You need to prepare: three sheets of A4 or Letter-sized plain paper
1.Make sure that the power is turned on, and remove any paper from the Rear Tray.
2.Open the Paper Output Tray gently, and open the Output Tray Extension.
3.Clean the Paper Feed Roller without paper.
(1) Press the g0081065_tcm14-774017.jpg (Maintenance) button repeatedly until b appears.
(2) Press the Black or Color button.
The Paper Feed Roller will rotate as it is cleaned.
4.Clean the Paper Feed Roller with paper.
(1) Make sure that the Paper Feed Roller has stopped rotating, and load three sheets of A4 or Letter-sized plain paper in the Rear Tray.
(2) Make sure that b appears on the LED, then press the Black or Color button.
The machine starts cleaning. The cleaning will be completed after the paper is ejected.
This should fix the issue
Regards,Suhail
Nov 03, 2011 | Canon PIXMA MP495 InkJet Printer
We just moved, and now that I've set the printer up in a new location, the paper won't feed at all. I removed the cartridge and wipped the paper feeder with alcohol still no luck
Hi
When you move the printer normally somethings will brake and get stuck. But 1st things 1st did you check if the tray lifts to take the paper? or try to take the paper atleast? if not then you can try to wiggle the printer a little and you should fine some thing being stuck come out and the printer work well again.
PLZ RATE MY SOLUTION
Jul 06, 2011 | Samsung ML 2010 Laser Printer
The printer won't feed the paper in properly. It turns crooked and then doesn't load in. Printer thinks there is either no paper or a jam. Can see anything physically in the way blocking the...
Hi Trevo
First, check the the paper guide in the feed tray is up against the edge of the paper. If it is not snug then the paper will skew.
If it is OK then check with a torch both sides of the paper path - where it goes in and where it comes out.
I've found bits in the path before now that are not seen at first.
This printer may have a removeable panel at the back where you can check a bit more easily.
May 25, 2011 | Canon PIXMA MP600 all-In-One InkJet...
I'm trying to print custom size papers. I've selected the mph on the printer with the settings for paper type. I've selected manual on the computer, with the settings for paper type and size....
What sort of printer are you using?
The printer may have a feed switch, which allows you to choose the feed location. Sometimes this physical button on the printer will override any software settings.
May 06, 2011 | Office Equipment & Supplies
Is Canon PIXMA IP1800 can handle T-Shirt Transfer Paper? if it can, what kind of transfer paper that will be good for IP1800?
There are several brands of T-Shirt transfer paper out there, and all are designed to work with InkJet printers just like yours. Personally I've used the Avery brand sheets, and they are widely available at local stores like WalMart, Staples, OfficeMax, etc.
I've also provided a link to the sheets available for online purchase from Amazon.com -
http://www.amazon.com/Avery-Personal-Creations-T-Shirt-Transfer/dp/B004E2S3MC
May 05, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Printer says no paper, but there is. Problem loading?
If not paper jam may has some problem with feed rollers on printer.First make sure that option to feed from cassette is turned on.Check this on maintenance mode.Аs the printer is in warranty better don't touch anything else and call Canon.
Nov 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Pictures have a pink tint to them
Is this when you've printed them, or on the camera screen?
If it's when you've printed them you may need to clean the print head of your printer.
You'd do this by going through your printer's 'toolbox', which should be accessable from a menu tree - my one starts with clicking the 'HP Solutions Center' icon on my desktop.
Never try to clean the printhead physically as it just makes the whole thing useless.
I hope this helps.
Jun 30, 2009 | Canon PowerShot A80 Digital Camera
I have a brand new canon mp480 printer. it keeps jamming
HEY THERE GUY'S THE EASIEST SOLUTION I CAN TELL YOU TO DO IS CALL CANON COMPLAIN THE'Y WELL MAKE YOU DO A COUPLE OF THINGS THATS SUPPOSED TO CORRECT THE ISSUE: LIKE ROLLER CLEANING A COUPLE OF TIMES, CLEAN THE ROLLER WITH ALCHOL, TURN EVERYTHING OFF AND SHAKE THE MACHINE A LITTLE AND TURN IT BACK ON TO SEE IF THAT WORKS AND FINALLY IF THAT DOESNT WORK THEY TELL YOU TO UNISTALL THE DRIVER AND REINSTALL IT!! WELL MAYBE FOR SOME OF YOU THESE STEPS MIGHT WORK!! BUT L'M TELLING YOU IVE PERSONALLY NOTICED CANON'S PRINTERS ARE ****!!! I'VE GONE THREW 2 PRINTERS SINCE DECEMBER LAST YEAR AND THEY SENT ME OUT A 3RD ONE FREE OF CHARGE!!! I TOLD THEM I HAD A CANON MP 150 FOR YEARS THAT I PRINTED EVERYTHING ON IT AND I STILL CAN EVEN AFTER MY DROPED IT AND BROKE A COUPLE OF THINGS ON IT!! SO FAR I HAVE USED THE MP470 WHICH IS GARBAGE!! AND THE MP480 IS THE SAME!!!! L MIGHT JUST SELL THE ONE THEY GAVE ME!!! IF ANYONE HAS QUESTION FEEL FREE TO CONTACT ME AT jdaguilera28@yahoo.ca SEE YA!!
Apr 12, 2009 | Canon Pixma MP480 All-In-One InkJet...
k24674
jasbo
jasbo
