Question about Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer motor wont turn over
Dryer wont start up, sounds like a car engine that wont turn over. we think the pilot light went out, but not sure where the pilot light is...
any suggestions are much appreciated!
  • 1,214 Answers
If the drum is not turning, then the belt may have broken and could be (because of the noise I think your describing, partially wrapped around the motor pulley.
Modern gas dryers do not have standing pilot lights. They are electronic ignition.
Chances are, you solve the belt problem, you'll solve the (I guess your having) heat problem.
Please respond with more detail of the problems you are having, and advise if the belt is broken.
Posted on Jan 19, 2009
Dryer hot at first and then stay cold
Sounds like the thermocouple needs replaced. When ever the couple doesn't make enough electricity the gas valve is shut down automatically. Sounds like your thermocouple is right at the threshold of minimum voltage and doesn't generate enough voltage to keep valve open.
If not that try YouTube for some good diagnostic videos:
Oct 28, 2015 | Whirlpool Dryers
I have an old Kenmore 70 Series dryer, just this weekend, the drum turns but no heat..... after a little search online, I suspect the pilot light went out. Where is the pilot light located? I lost the...
The burner is on the lower right side of the bottom under the drum. See this manual pdf page 23 for location and access.$FILE/4322260.pdf
The burner uses an ignitor and a flame sensor vs a pilot light. See this link pages 12 - 14$FILE/4314010.pdf Note the M series burner has been in use since 1984.
The dryer must have a complete termperature circuit and no "high temp limit" failures for the ignitor to light. That means the door is closed, motor is running, and the cycle thermostat is less than 135 deg F and the High limit thermostat is less than 180 deg F just to provide power to the gas valve solenoids, ignitor, and radiant / flame sensor.
Thanks for choosing FixYa,
Nov 28, 2010 | Dryers
Dryer starts up and flame starts for about 3-4 minutes and then flame goes out.
The pilot light lights? Then goe's back out? There is two stiff wires right in front of the flame. One of them is an ignightor, and the other one a thermocoupler. Or may just be one. That is the ignightor and thermocoupler. The thermocoupler is what detects that the pilot light lit. Its a saftey feature. It makes sure that there is fire before it turns on the main gas. So it wont blow up. It gets a film built up on it from the gas. Take some real fine sandpaper, or steel wool and clean it real good.
Then try again. It should work. If not then it needs to be replaced
May 21, 2010 | Whirlpool LGR8648 Gas Dryer
Hot water heater went out when they replaced our dryer doesn't
Make sure the gas valve at the dryer is turned on. Dryers use a glow plug or electronic ignitor to light the gas. There is no pilot light. Plug the dryer in and start it. Look inside the front lower panel to see if the ignitor glows. If it does and the gas does not light then the gas to the dryer is probably turned off. Look for a valve in the supply line to the dryer. Also inside near the front underneath.
Aug 05, 2009 | Dryers
Gas dryer on, won't heat, just had propane delivery,tanks were em
I hope you didnt blow up by now, but your to hold a pilot valve down while igniting it
and keep down for 1 minute then release then turn valve to keep the pilot to operate the valve
Jun 18, 2009 | GE DBXR463GB Gas Dryer
How do you light gas pilot light?
I don't think that there is a constant burning pilot light!! It should be automatic:
There is a ceramic ignitor that heats up red -hot, an electric eye sees the heat and turns on the gas valve ( on my Whirlpool).
Apr 26, 2009 | Dryers
Where is the pilot light on the Whirlpool Ultimate Care II Dryer?
Hello gigiknoll
Welcome to Fixya
My name is Huum,
This model should be electronic ignition and does not use a pilot light.
The igniter may be faulty.or the gas module may be faulty.
Pilots are a thing of the past!
This requires a tech to test it with equipment.
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Feb 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
Whirlpool Super Capacity 465 Gas-pilot light won't stay lit
I have a whirlpool accubake system / super capacity 465 oven ... the top burners do fine...but my oven pilot went out... and I don't know how to re-lite the pilot... the owners manual doesn't help ... it doesn't show anything a layman could understand ... no visual illustrations ... when I turn on the oven ... the display shows that it's been activated... it clicks a couple of times but does not light ... what is a simple way to re-light the pilot? thanks, A
Nov 25, 2008 | Whirlpool SB160PEE Gas Single Oven
sounds like your motor is bad or the start relay on motor.. dont think you can replace just the start relay on that motor
Nov 06, 2007 | Whirlpool LGR3624JQ Gas Dryer
Whirlpool GGQ8831L Gas Dryer Logo
133 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
