Question about Mattel Fisher Price Magna Doodle (PC)
Magna doodle won't erase - Mattel Fisher Price Magna Doodle (PC)
Magnetic issue with magna doodle
You might have gotten a bad magna doodle you might have to call the company and get anew from them.
Dec 30, 2012 | Mattel Fisher Price Magna Doodle (PC)
97cc baja doodle bug won't start
Assuming that the engine can be turned over with the starter, the most likely culprit is it's not getting enough fuel, especially if it's been sitting for 6 months or more. AT YOUR OWN RISK, remove the air duct after the air cleaner and pour a shot-glass full OR LESS of gas directly into the carburetor or throttle body. It should start and at least run briefly. If it does, then add at least 3-5 gallons to the fuel tank. If you've run out of gas, then adding just one gallon is not enough. Today's fuel-injection systems have pressurized fuel lines which need at least a gallon just to fill all the pumps and filters between the tank and the engine. Good Luck, TechJoel
Nov 04, 2012 | Cars & Trucks
How to remove ink from magna doodle screen
You could try removing it with fingernail polish remover or a product called Goop Off.
Oct 05, 2012 | Motorcycles
I have a Mitsubishi magna 2001 model and I'm having computer problems the battery symbol keeps flashing and it keep stalling and won't idall properly
You need to have the Alternator tested, the battery symbol indicates the system voltage is low. The other problems are due to the low voltage.
Sep 18, 2012 | 2005 Mitsubishi Magna Wagon
Why mitsubishi magna 1994 shows battery sign when running?
Malfunction in the charging system. Have your alternator tested, it's probably bad. Do it soon or your battery won't have enough charge to start the car.
Jun 16, 2012 | 1994 Mitsubishi Magna
I have lost the instructions for my sons doodle penguin, have you a copy you could e-mail one to me please.
i do have a pdf document of these instructions, but this site won't let me attach it, give me you email address and i'll pass on
thanks
Jan 24, 2011 | Vacuums
How could i know if my friends are on line even they are in invisible mode
The easiest way to know is to use the "Doodle Environment", once you are logged in, double-click the user who might be hiding and from the IM window, click "Environment" and then "Doodle", if your friend is online hiding there as invisible, then the Doodle environment will load and you can play with the doodle, but if he/she isn't online, you'll see "Waiting for your buddy to load Doodle" message on the page.
Hope this helps,
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 23, 2010 | Yahoo Messenger
2 year old daughter cratched my plasma screen with a magna doodle pen it is a plastic screen
Your plasma cover screen should be glass, not plastic. I have no knowledge of Panasonic or any other manufacture that made a plasma TV with plastic....all plasma TV's have a glass cover. Clean the surface with a rubbing alcohol solution and a cotton ball.
Feb 06, 2010 | Panasonic TH-42PX500U 42 in. Plasma...
On/off sound
hi
What sounds like? Like a frying pan? a high voltage sparking? or what?
Thanks!
Dec 27, 2008 | Curtis CM32020S 32" TV
Mattel Fisher Price Magna Doodle (PC) Logo
119 people viewed this question
Top Mattel Toys Experts
Nikki  Mclean
Nikki Mclean
ray gallant
Are you a Mattel Toy Expert? Answer questions, earn points and help others
