Question about Kenmore 44042 Front Load Washer
44052 won't start final spin
It completes the first 3 cycles without problem. On the final spin stage, the washer won't start its "Final spin" stage. I hear the motor humming though.
dididsaythat
  • 291 Answers
SOURCE: Kenmore Automatic washer -110.24862300
sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
Posted on Sep 03, 2007
  • 156 Answers
SOURCE: Kenmore Front Loading Washer Slow Final Spin Cycle
out balance are water still in tub will do that try cleaning out the pump filter under the panel at the bottom of the washer some have a big white looking screw you turnit remove filter if there water in it it will flow to the floor so have something to catch it with
Posted on Feb 28, 2008
  • 63 Answers
SOURCE: model 110 washer will not go into a final high speed spin.
is it top load or front loader kenmore what
Posted on Nov 12, 2008
SOURCE: Washer will not Spin during SPIN CYCLES
Check the lid switch. Through out time the lid switch housing can come apart from years of heat and cold. When I checked mine, I found the glue deterriated and the housing came apart. What I did to fix it is I zipped tied the housing together and did a functional check and it worked.
Posted on Apr 25, 2009
SOURCE: Sears Kenmore front loading washer bangs and
I have a Kenmore 417, when it gets to the final rinse cycle the drum starts beating onto the left side of the washer and it leaks water
Posted on Dec 19, 2009
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Nov 05, 2015 | Kenmore Washing Machines
My the front load washer model gcvh6900jww has the red lock on the display. I accidentally held the start button for a few seconds and it locked. I tried holding the start button again for up to 20 seconds...
  1. Found This HelpfulSometimes something will go wrong in your washing machine that will cause it to lock up or stall. An overloaded washer or a brief power surge can cause this. The washer may not drain or spin properly, or it may stop the cycle in the middle of the wash. Another cause may be that the washer was stopped before the cycle was able to complete. In this case, the washer will spin and drain over the next 24 hours, but it will stall before reaching the final spin. GE has two simple methods to reset the controls
For Newer Washers:
    • 1 Unplug the washer.
    • 2 Twist the control dial around the cycle settings.
    • 3 Place the dial on any setting other than the final spin.
    • 4 Ensure that the water line is securely attached to the washer.
    • 5 Plug the washer back into the wall (making sure it has gone at least 30 seconds without power).
Nov 11, 2014 | Washing Machines
Spin Cycle Kenmore 44052
Possible that the control unit is malfunctioning. You can remove the unit and reset all connections, check for visible track failure or moisture in the unit, if so use a heater to warm off all moisture as it can cause malfunctioning. Finally check the wires to see if there is any that this loose or snapped.
Sep 03, 2012 | Kenmore 98702 Stacked Washer/Dryer
Ul code almost every load
I THINK THERE MIGHT BE SOMETHING IN PUMP
Jun 17, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer (total care system) is making a humming noise even though I've taken all the clothes out of it. The agitator works, but there's a humming noise. I've stopped it and re-started it, but...
Hi
1 of 2 things could be the trouble.
Does the washer drain properly if you manually turn the control knob? If not then this sounds like your pump is either plugged with possible lint and can't move or has died completely. 99% chance pump is the problem and 99% chance it can be an easy fix by cleaning the pump where the Drain Line is attached, worst case scenario pump is to be replaced, but not a overall expensive fix and most can do it without a technician.
Second problem is possibly the time itself, but if the washer is going through all cycles except spin then pump is likely the culprit, cause in spin cycle the machine has to drain the water from the unit as it spins, if it cannot the washing machine basically stops and cannot complete the cycle.
One way to tell for sure if the pump is the problem. When the machine enters the spin cycle and starts making that noise. Manually turn the dial a little bit till it passes the spin cycle, if it continues to wash till it hits the final spin/drain cycle then stops again...your pump is in need of help.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 04, 2011 | Kenmore 24032\24036 Top Load Washer
Hi, I own a Whirlpool Thin Twin Model# LT5000XSN1. I bought it used from a CRAPPY dealer (worst mistake EVER), since day one, we have had an issue with the spin cycle. The cycle will agitate then when the...
This sounds like a classic clogged empty pump issue. The empty cycle is timed and then it steps on to the spin cycle. The machine won't spin if there is still water in the bottom of the drum. When you reset it to a spin cycle again, you are making it run through the empty cycle again, finally getting rid of the water that the clogged filter could not evacuate on the first attempt.
You need to clean the empty pump filter. Now... Where is the filter???? Hmmmm... not sure. It MAY be behind a little panel in the front of the machine near the bottom. I can't find a picture of the machine on the net so I'm not sure.
Clean the filter, I'll bet your problem goes away. You have to wonder why the idiot who sold the machine to you hasn't suggested this!
Jun 21, 2011 | Washing Machines
Kenmore 44052 will not spin. Replaced door switch still will not spin. Ran diagnostics (code E43) so I replaced motor control board still will not spin. Could not get out of diagnostics so I replaced...
Have you pulled the pump and checked for obstructions? There may be something in the pump itself; you will need to check that...
If your problem can't solve, keep in mind that the error codes means physical wrongs, so, E43 is a door-locking problem or "board comunication problems".
I hope this helps.
Sep 30, 2010 | Kenmore 44042 Front Load Washer
GE front load washer will not complete the rinse & spin cycle
1) 1st check the filter under the machine (it unscrews behind the access panel 2) open front door and pull back the rubber membrane to see metal and clean out the debris blocking drain holes 3) remove the drain hose from the machine (spring clip) and try and run water thru it and keep blowing out the junk and re-attach 4) run the machine thru 2 cleaning cycles w/bleach and without bleach 5) start using less detergent
Apr 09, 2010 | GE WSXH208A Front Load Washer
Washer will not start final spin cycle
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
Apr 05, 2009 | Maytag EPIC MFW9700S Front Load Washer
Kenmore 44042 Front Load Washer Logo
32 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
