Bradway/temperzone reverse cycle air con is turned onto cooling, after a few hours the cooling stops and the fan mode kicks in. The han-l-62 controller shows that the unit is working on cooling but on
Tried to fix the problem as suggested in the manual by rebooting to clear the controller memory. a) Turn on control a1) Change no 3 dip switch to ON b) Press reset button c) After control restarts change dip switch 3 to Off The air con starts cooling for a while then returns to fan mode.
Buffalo12980
  • 625 Answers
SOURCE: Unit will not blow cold air after starting up for first time this season
you may need to remove the rear cover to examine what is and is not running. once you remove the back, start up the unit on a workbench. see if the fan is running and the compressor has kicked in. look at the larger or two tubes coming out of the compressor. if it is cooling a small layer of frost or condensation will appear on this " suction" line. if this tubing and the other one are approx the same temperature, then there is a freon leak in the system. Only an EPA certified technician can fill your unit. I am not familiar with that RED button but it mat be a reset of some sort. With the back removed see how it is connected in the wiring circuit. if you have the wiring diagram, please send it to me under my regular email address and I'll walk you through the troubleshooting procedure.
Posted on Sep 02, 2007
  • 86 Answers
SOURCE: through the wall HAIER air con
model no
capacity of a/c
need to solve yr problem
Posted on Mar 17, 2008
hapndnvegas
  • 35 Answers
SOURCE: air conditioning unit remote control problem
when something is broke you can never break it worse so dig in and look for a stuck button or broken piece of plastic lodged in between the buttons or
you may want to go to: harmony web site and see if your model of a/c is supported these remotes are rather expensive us$129-$499 but much less than replacing the A/C and can control 225,000 devices made by 5000 different manufacturers just about any device under the sun. on the website under device choose home automation then climate control your brand then model number to see if your A/C is there. If you decide to go this route I would reccomend to check all the other devices you have also.
Posted on Apr 14, 2008
bobotfel
  • 236 Answers
SOURCE: AIR CON REMOTE CONTROL NOT WORKING
replace your receiver board it may be defective.
Posted on May 16, 2008
SOURCE: Daily reset of outside unit
I have the same unit and was having the same problem. My brother works on A/C's and told me that the coils most likely needed cleaning from the inside out because when they are clogged with a lot of debris the system will overheat and cause that switch to trip and so far it has worked. What you need to do is turn the main breaker off to the outside unit first then take the four screws out of the top of the unit, use a flat head screwdriver and lift the fan it's self up out of the carefully taking caution of the wires going to the fan, then take the garden hose with a spray nozzle and wash the coils from the inside spraying through the coil to the outside and then wash the louvers off of all the debris and this should help.
Posted on Aug 03, 2008
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
My Honeywell thermostat isnt keeping my house cool even though the temp is set to 69. Currently 90 degrees in here
Its probably not the thermostat. The air conditioner may be stuck on heating mode. If its a reverse cycle, the reversing valve may be jammed so even when the thermostat is calling for cold air, it stays on heat. If the machine is on heating mode, it should be blowing cold air out of the outdoor unit of the air con. If its on cooling mode, the outdoor should be blowing hot air.
Apr 12, 2015 | Honeywell Heat/Cool Thermostat
Indoor fan will not stop
Seems like the fan relay has stuck (Likely to be on the main indoor PC board) or if the machine was being used on heating mode, the indoor pipe sensor may have failed causing the fan to continue to run. Most air cons on heating mode, will keep the fan running for a few minutes after you switch off on heating mode to cool down the indoor unit before it turns off completely. The pipe sensor signals the main PC board to tell it that the unit has cooled down and can now turn off completely. If either of the above faults occur, the indoor fan will keep running all the time.
Jun 19, 2014 | Goodman CKL36AR36 Air Conditioner
Breeze air wkl 3000 blinking temperature al
NEW UNITS HAVE A VISUAL ALARM PRE SET TO KICK ON AT 62 DEGREES OR ABOVE, WHE THE WINE COOLING UNIT READS 62 OR ABOVE IT WILL FLASH "AL" AND THE TEMPERATURE NUMBER THAT FORVED IT TO KICK ON, IT IS JUST A VISUAL ALARM IT WILL NOT TURN UNIT OFF OR STOP IT .
THIS FEATURE WILL SHUT OFF ONCE THE UNIT READS ANY TEMPERATURE BELOW 62 DEGREES.
Dec 27, 2013 | Breezaire WKL-2200 Wine Cellar Cooling...
Intertherm heatpump outside fan will not come on, replace fan motor and capacitor, fan will not come on what could it be
some times heat pumps have a fan cycling switch to keep the head pressure normal in cool weather or check the defrost relay for the fan when a heat pump condenser gets frosted it will stop the fan and reverse into cooling mode for a few min. to melt the ice and this function is done by a relay or a printed circuit board if it goes bad you wont have voltage to the fan
Sep 30, 2010 | Intertherm P3RA-060K Air Conditioner
Air Con cuts in and out and so does cooling fan
I have a 2008.5 Mazda 3 GS Sport and when you turn the air flow selector to windows or windows/floor, the air condition will turn on automatically. (Can't turn it off.)
Nov 12, 2008 | 2008 Mazda Mazda3 Hatchback
Carrier
The cooling coil is more than likely iced over stopping the air circulation. Put the fan control in the on position and turn the cooling to off. After an hour or so the ice will clear from the coil and air circulation will be re-established. Then return to cooling and leave the fan control in the on position when in the cooling mode. This will provide air circulation to melt any ice from coil during the off cycle.
May 09, 2008 | Heating & Cooling
Heating & Cooling Logo
107 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
