Akita washing machine dwf-089
E1
  • 1294 Answers
SOURCE: daewoo dwf-6094r wont spin on spin cycle
You need to clean out your outlet filter;(which is accessible thru the front bottom right side of machine, small push door, or plastic screw) this needs to be done periodically - according to your usage. If this does not solve your problem check out your outlet pump. Plug off the wall first before you do the jobs. The machine will not drain water if the outlet is clogged. For the pump, tubes, etc you hav to open up behind the machine. Be prepared for water to come flowing out.......
And rate me pl, if the solution has worked......
Posted on Dec 02, 2007
SOURCE: daewoo washing machine dwf-75ts
Found the manual for a similar model. LE error code indicates a "Lid Open" error. Most likely the little switch that is tripped when you open the lid has failed due to corrosion or some other reason. If you can find an equivalent switch then replacing it should do the trick. Otherwise, you can simply short the connection so the machine thinks that the lid is always closed. WARNING: This effectively overrides the open lid detection system and poses the risk of having the unit run a spin cycle even with the lid open! find a replacement switch if you can. good luck! just shorted mine out temporarily and it works -- until i can find the right switch.
Posted on Jun 10, 2008
masteria
  • 355 Answers
SOURCE: what is LE error for Washing Machine Daewoo DWF
In other Daewoo models LE error code means pressure sensor failure. This sensor is used to know water level in the tube. It is probable that your model reports the same codes.
It does not necessary means a broken sensor you must check the electrical connectors and cables as well as all the mechanic and pneumatic elements like the hose connected to the sensor.
It is often clogs with soap and other particles.
Good Luck!
Posted on Jun 16, 2009
  • 215 Answers
SOURCE: Water overflowing during use
Seems like blockage in pressure system, machine will always think it is empty if so. Pressure system is under the lid, a round switch with a thin pipe going to it. At bottom of this pipe it is probably blocked with limescale or residue from detergent.
Posted on Feb 12, 2010
ZJLimited
  • 17970 Answers
SOURCE: LE CODE WHAT MEANS. DAEWOO
LE error code refers to the door mechanism. Usually there is a locking switch that senses when the door is closed, allowing the wash cycle to start. If your door is closed and you are still getting the LE error, it is probably this switch that is faulty.
Posted on Apr 21, 2011
Hi. Can you tell me what E1 means on the display
LG Dishwasher Error Code E1 How To Clear
Based on your model number ... it is probably an LG appliance.
Use the link above to learn about the E1 error code. According to the web site ... there is a chance that nothing is broken and the code may have been caused by how the dishwasher was loaded. The web site lists 7 reasons why the E1 code came on.
Helpful?
Good luck with your troubleshooting
Jan 25, 2018 | Dishwashers
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    What does code e1 mean
    E1
    2.048Mbits/Second
    Computing » Networking
    Rate it:
    E1
    Echelon 1
    Governmental » Military
    Rate it:
    E1
    Electrician Ist Class Petty Officer
    Governmental » Navy
    Depends on where you're reading the code from as well!
    May 11, 2016 | Heating & Cooling
    My air conditioner showing on the display is E1
    The E1 Error Code The most common reason for an E1 error code to be displayed on your air conditioner's front panel is to remind you that the unit's air filter needs to be cleaned. Many models will automatically notify you of this via an E1 error code display after the unit has been operated for a predetermined number of hours. For example, many Sharp models will display an E1 code after 720 hours of use. Alternatively, you could have dirt or moisture in your front button controls, causing them to stick or not function properly. This can be a common problem with many models of Haier air conditioners, but the issue is not restricted to any one manufacturer. Your air conditioner could also have a defective thermistor, which is part of the thermostat.
    For Samsung, the room thermistor needs replacing. This is a device that senses the temperature in the room.
    How to Fix an Air Conditioner When It Gives You an E1 Code eHow
    Jan 24, 2016 | Heating & Cooling
    What does E1 code indicate?
    Your Air Conditioner Displays E1 (E2, or E3) In The Display ...
    support-us.samsung.com/.../pop_troubleshooting_fr...
    Samsung ElectronicsJul 8, 2010 - Home > Operation? > Your Air Conditioner Displays E1 (E2, or E3) In The Display Panel And Won't Turn On Share on Google+ Share on ...
    How To Clear Sharp Air Conditioner E1 "Clean Filter" Error ...
    sci.tech-archive.net > Archive > sci.electronics.repair > 2005-08
    Aug 5, 2005 - Owners of Sharp air conditioner models ... the error code E1 will appear... following procedure to clear the nefarious E1 indication, and obtain
    Oct 27, 2015 | Heating & Cooling
    E1 error code on omega dishwasher
    E1 error on LG Dishwasher - YouTube
    ? 2:40
    www.youtube.com/watch?v=2qcwAyHI9ik
    Aug 24, 2012 - Uploaded by 62spindrift My fix for E1 error on LF Dishwasher. ... Maytag Maxima steam Washer has F8 & E1 error code - Pressure sensor & no water detected ...
    Aug 28, 2015 | Dishwashers
    Busco manual de ACER Aspire E1-572/E1-570/E1-532
    Hi
    The link below will take you to the page for the Aspire E1-572 where you can choose from drivers, documents, BIOS upgrades etc and download exactly what you want.
    http://www.acer.co.uk/ac/en/GB/content/drivers/4776;-;Aspire%20E1-572
    Cheers
    Sep 29, 2014 | Computers & Internet
    What does E1 mean in tadiran 250 R, it works then stops and screen shows E1 when it operates as a heater
    h Air Conditioners
    Nov 24, 2012 | Heating & Cooling
    E1 fault on kenwood dishwasher kdw243a
    error code E1 refers to "lack of water inlet pressure" the valve the elctrically lets in the water might be at fault
    Jan 18, 2009 | Kenwood KW85 Air Conditioner
    Washing Machines Logo
    126 people viewed this question
    Top Washing Machines Experts
