Question about Locks & Locksmithing
2001 daewoo lanos keyless remote programming
How to program fab / keyless remote to lock and unlock car door
  • 13 Answers
SOURCE: 2001 daewoo lanos unlock code
you need to take the radio out to get the serial number off the bottom,then google car radio codes,choose make and model and follow the instructions.it will cost about £8-£15 depending on where you get the code from?hope that helps?
Posted on Mar 08, 2008
emissionwiz
  • 78238 Answers
SOURCE: Program keyless remote entry
I need a year, but u can look it up at the link provided below.
http://www.programyourremote.com/
Posted on Nov 28, 2008
emissionwiz
  • 78238 Answers
SOURCE: 2001 XJ8 keyless remote programming
This is the procedure from the service manaul:
JAGUAR
XJ8 Remote Control Programming
1. Unlock the Boot/trunk with key.
2. Turn Ignition on.
3. Warning light on dash comes on.
4. When they go out, lift arm rest, inside their is a valley button, Press 5 times within 5 secs of lights on dash going out, Horn & Lights Flash.
5. Press any button on remote, remote programmed.
Posted on Jan 16, 2009
  • 12 Answers
SOURCE: Alarm Lock Trillogy DL2800 and DL Windows Program.
If you can load DL windows onto a laptop instead of a PC, you can program directly to each lock using a AL-PC12 cable which connects from a 9-pin serial com port on your computer, to the 2-pin banana plug on the lock.(be sure to observe polarity). Cable is available from Alarm Lock. Some very useful downloads and information is available on their website - www.alarmlock.com
I hope this helps!
Posted on May 19, 2009
SOURCE: programming keyless remote
2003-04 Mazda 6 REMOTE PROGRAMMING
Step 1: Open drivers door and leave open.
Step 2: Lock and unlock the driver’s door using the power door lock switch on the door.
Step 3: Insert key into the ignition.
Step 4: Turn key to on position and return to off position. (IMPORTANT - use ON position NOT ACC position). Do this 3 times within 10 seconds. Leave key in the ignition.
Step 5: Open and close the driver’s door 3 times. (Door should be left open after this step).
Step 6: ECU should respond by locking and unlocking the doors.
Step 7: Press any button on remote #1 twice. ECU responds by locking and unlocking the car doors.
Step 8: Press any button on remote #2 (etc.) twice. Each time the ECU will respond by locking & unlocking the doors.
Step 9: Remove the key from the ignition and the ECU will respond a final time with a series of door locks and unlocks. You're done!
Good Luck.
Posted on Jul 10, 2009
I went through programing as far as lock recycling but wont go any further
Remote Transmitter Programming NOTE: All keyless entry remote transmitters must be programmed at the same time.
NOTE: Programming (or reprogramming) the keyless entry remote transmitters into the central security module can be accomplished using a diagnostic tool or by carrying out the following steps.
  1. Turn the ignition switch from OFF to RUN eight times within 10 seconds, ending in RUN. If the module has successfully entered program mode, it will lock and then unlock all doors.
  1. Within 20 seconds, press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed. Repeat this step for each transmitter.
  1. If the door locks do not respond for any keyless entry remote transmitter, wait several seconds and press the button again. If the door locks still fail to respond, refer to Inspection and Verification.
  1. Turn the ignition switch to the OFF position, or wait up to 20 seconds after Step 2, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the doors will lock and unlock one last time to confirm.
Mar 18, 2016 | 2004 Ford F150
2001 mustang keyless entry not working properly what do I do
You did it like this ?
Programming -Keyless Entry Remote Transmitter NOTE: All keyless entry remote transmitters (15K601) must be programmed at the same time.
NOTE: All previous transmitter identification codes (TIC's) will be erased when programming mode is entered.
NOTE: To program (or reprogram) the keyless entry remote transmitters into the generic electronic module (GEM)(14B204), perform the following steps.
  1. Turn the ignition from OFF to RUN eight times within 10 seconds, ending in RUN. If the GEM has successfully entered program mode, it will lock and unlock all the doors.
  1. NOTE: The first TIC must be entered within 7.5 seconds of entering the program mode and additional TICs must be entered within 7.5 seconds of the first TIC. The programming mode is exited whenever the timing constraints are not met. Press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed.
  1. If the door locks do not respond for any keyless entry remote transmitter, wait for several seconds and press the button again.
  1. Turn the ignition switch to the OFF position, or wait up to five minutes after step 1, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the GEM will lock and unlock all the doors one last time.
Jan 15, 2018 | 2001 Ford Mustang
I have a 2000 ford mustang. Suddenly my keyless entry remote stopped working. I replaced the battery and turned the off and on 8 times and the locks cycled. after which i pushed the unlock but nothing...
The keyless entry system is controlled by the (GEM) - generic electronic module .
Keyless Entry The electronic door lock system has two main components:
  • generic electronic module (GEM)(14B204)
  • keyless entry remote transmitter (15K601)
  • NOTE: Battery power and ground must be remove before disconnecting the GEM connectors to avoid setting false codes.
    Power Locks Operation The power locks feature allows the customer to lock and unlock the doors via momentary switches located on the driver and passenger door. When the GEM detects a momentary press of the driver or passenger lock button, the GEM will supply power to the driver or passenger lock actuators for approximately 250 ms from relays internal to the GEM. When the GEM detects a momentary press of the driver or passenger unlock button, the GEM will supply power to the driver or passenger unlock actuators for approximately 250 ms from relays internal to the GEM.
    Remote Keyless Entry Door Locks Operation The remote entry feature allows the customer to unlock the driver door, unlock all doors, and lock all doors using a valid remote transmitter as long as the ignition switch is not in RUN or START. The driver door is unlocked whenever the GEM detects a valid remote transmitter unlock transmission. All the doors are unlocked when the GEM detects a second valid remote transmitter unlock transmission within three seconds of the first transmission. All the doors are locked when the GEM detects a valid remote transmitter lock transmission. If the GEM detects a second valid remote transmitter lock transmission within three seconds of the first transmission, the doors will lock again, the horn will sound for 20 ms and the parking lamps will flash for 200 ms to indicate the doors are locked. If the GEM detects the driver or passenger door is ajar during the second lock transmission, the doors are locked again and the horn is sounded twice. If the GEM detects a valid remote transmitter lock transmission within three seconds of detecting a valid remote transmitter unlock transmission, the GEM will lock all the doors
    • The doors do not lock/unlock using the remote transmitter
    • Ignition switch.
    • GEM.
    • Remote transmitter.
    • Remote transmitter batteries.
    • GO to Pinpoint Test C .
    You followed the program instructions to the letter ? Programming -Keyless Entry Remote Transmitter NOTE: All keyless entry remote transmitters (15K601) must be programmed at the same time.
    1. Take an have the vehicle checked for DTC'S
B1396 Power Door Lock Circuit Short to Battery GEM GO to Pinpoint Test B . B1397 Power Door Unlock Circuit Short to Battery GEM
Apr 12, 2017 | Ford Mustang Cars & Trucks
I have a 96 ford conversion van with a 600 plus addon keyless system and need to program new keyless remots , need to know how to get system in program mode.
Hi.
To program ( or reprogram ) a keyless entry remote transmitter into the remote keyless entry module, perform the following steps:
1. Turn the key to ON or ACC and short the two terminals of the program connector, a two-pin connector located below the driver's side of the instrument panel at the base of the steering column. All doors should lock and then unlock.
2. Press any button on each keyless entry remote transmitter in turn. All doors should lock and then unlock. If the door locks do not respond, press the button again (up to three times maximum with the same keyless entry remote transmitter). If the door locks still fail to respond, go to Pinpoint Test A.
3. Repeat Step 2 to program additional keyless entry remote transmitters into the remote keyless entry module (up to four keyless entry remote transmitters maximum).
4. Turn key off.
5. Remove the short from the program connector. All doors should lock and then unlock.
6. Verify that the keyless entry remote transmitters have been successfully programmed by pressing the LOCK or UNLOCK button on each one, and observing that the system responds by locking and/or unlocking the doors.
I hope this helps you.
Thanks!
Nov 28, 2010 | 1996 Ford Econoline
Keyless remotes not working
Try reprogramming the remotes. Here are the instructions for the procedure. Hope it helps. Cobra!
Programming NOTE: All keyless entry remote transmitters (15K601) must be programmed at the same time.
NOTE: To program (or reprogram) the keyless entry remote transmitters into the RAP module, perform the following steps:
  1. Make sure that the anti-theft system is not armed or triggered.
  1. Turn the ignition switch (11572) from OFF to RUN eight times within ten seconds, ending in RUN. If the RAP module has successfully entered program mode, it will lock and then unlock all doors.
  1. Turn the ignition switch to the OFF position, or wait up to 20 seconds after step 2, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the RAP module will lock and unlock all doors one last time to confirm.
Jun 06, 2010 | 1998 Ford F150 Regular Cab
How do i reprogram electronic door locks
Programming Electronic Door Lock Control System NOTE: The electronic door lock control processor (14B001) erases all previous keyless entry remote transmitter (15K601) from memory when the keyless entry remote transmitters are programmed or reprogrammed. The electronic door lock control processor can store up to four keyless entry remote transmitters in memory.
  • To program (or reprogram) keyless entry remote transmitter into the electronic door lock control processor, perform the following steps:
  1. Turn ignition switch to the RUN position and momentarily short the two terminals of the program connector taped to the wire assembly and located behind the glove compartment. All doors should lock and then unlock. Remove shorting pin.
  1. Press any button on keyless entry remote transmitter. All doors should lock and then unlock to verify the keyless entry remote transmitter has been programmed. If door locks do not respond, press button again (up to three times maximum with the same keyless entry remote transmitter).
  1. Repeat the above step to program additional keyless entry remote transmitters into the electronic door lock control processor (up to four keyless entry remote transmitters maximum).
  1. Turn ignition switch OFF. All doors should lock and then unlock.
  1. Check operation.
Jun 05, 2010 | 1997 Ford Windstar
How do I program a new OEM key for my 2001 Daewoo Leganza so it locks and unlocks the doors?
hi this is how you do it
first off make sure the alarm system is off then put the key to be programed into the ignition turn ignition on then off within 5 seconds this is then in program mode press the lock or unlock button 3 times within 20 seconds and then the central locking should start working indicating the remote is now programed...hope this helps please vote thanks
May 22, 2010 | 2001 Daewoo Leganza
I need to program a key fob for a 2004 Cadillac CTS. I just purchased the car used. it came with ONE key and nothing els. I have recently purchased a keyless entree remote suitable for the car and was...
Remote Key FOB Information
 1. Close all the vehicle doors.
   2. Insert the ignition key into the ignition lock cylinder.
   3. Press and hold the door unlock switch.
   4. While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
   5. Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
   6. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
   7. Repeat the previous step to program up to 4 transmitters.
   8. Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter programming mode.
   9. Operate the transmitter functions in order to verify correct system operatio
Sep 17, 2009 | 2004 Cadillac CTS
Program fob
Instructions to program a keyless entry remote for a Chevy Silverado. They also work on 2003, 2004 and 2006 Suburbans.
  3. Press and hold the DOOR unlock switch.
  4. While holding the DOOR lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
  5. Release the DOOR unlock switch. The doors will lock and unlock to confirm the program mode.
  6. Press and hold the LOCK button and the UNLOCK button simultaneously on one keyless remote. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
  7. Repeat the previous step to program up to four transmitters.
  8. Turn the ignition switch to the RUN (one more click forward) position in order to exit the keyless entry transmitter mode.
  9. Operate the transmitter functions in order to verify correct system operation
Apr 19, 2009 | 1999 Chevrolet Silverado 1500
Car key remote
1. Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in
RUN. Door locks will cycle to confirm programming mode.
2. Within 20 seconds press any button on first keyless remote. Door locks will cycle
to confirm programming.
3. Within 20 seconds, press any button on second keyless remote. Door locks will
cycle again to confirm programming.
4. Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
Mar 24, 2009 | 2001 Ford Expedition
Locks & Locksmithing Logo
64 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
