Sony Vaio vgn-sz483n lcd screen no backlight
The machine boots up and you can see the "VAIO" image in the back ground but the backlight does not come on. I suspect the LED backlight power supply fuse is blown. Does anyone know where this fuse is located? Much appreciated
  • Hubert Thong
    Hubert Thong Jan 03, 2013
    Actually the micro fuse is located on a small triangular circuit bord
    on left side of MOBO. Need to remove the top cover to access it.
    Soldered a new micro fuse in and screen's back to life. Thanks guys
  • 32,281 Answers
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Posted on Jan 01, 2013
jonags3
  • 83 Answers
SOURCE: sony vaio VGN FJ290P password reset sony vaio VGN FJ290P
I have set the password for administrator when i entered the bios set up. you can change its setting but not the configuration unless you've entered the password. you can't change the password with a new one if you cant enter the old password. Next time dont forget your password because laptops has its security even when stolen you cant open its bios set up if its protected by password. CMOS battery is in the mother board. You need a service technician to open your laptop to reset the bios setup battery.
Posted on Oct 11, 2008
  • 8 Answers
SOURCE: Sony VAIO VGN-FJ3M/W does not boot.
Possible hard disk failure or hard disk controller failure.
if you feel confident remove the hard disk and replace - obviosuly make sure that there is not power running and remove the battery - replace hard disk then battery then power and try again.
Do you get any beeps? is the hard disk clicking? listen carefully to it and post your findings.
Posted on Jan 11, 2009
  • 64 Answers
SOURCE: I HAVE A SONY VAIO VGN-FJ1S, BOOTS UP, THEN GOES SLOWLY WHITE/?
I actually did have a problem that was similar the screen would lighten up after a min or so and moving the screen fixed it. The actual cause of the problem was a loose chip on the circuit board of the LCD, i re soldered it to fix it, could also be a bad LCD cable.
Posted on Mar 06, 2009
Geekman
  • 32281 Answers
SOURCE: my sony vaio vgn-n365e screen is Dim
The fault could be a faulty CCFL lamp or inverter.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Posted on Jul 24, 2009
  • 1087 Answers
SOURCE: How to Remove the bezel from a sony vaio
http://www.fonerbooks.com/laptop_8.htm
Posted on Mar 29, 2010
My vaio van sz483N will not start following a hard drive replacement?
The HDD has not been placed correctly leading to a short circuit so the laptop does not switch-on . Remove the HDD and power-on the laptop if it switches on then need to check the HDD .
Jun 17, 2015 | Sony Vaio Vgn-sz436n/b / Vgn-sz476n/c /...
I have a sony vgn-sz430n and the screen has gone nearly black. At certain angles and with certain lighting, the screen shows some images. They include: Vaio Recovery Center (with a totally blank window)...
Ok ! So try one thing remove HDD from the laptop and then start the laptop.And i am sure that u will see that the screen gone black at certain points. So dude its LCD problem . Go to nearest Laptop repairing center and he can change your LCD. then it working properly
Sep 02, 2011 | Sony VAIO VGN-SZ430N/B Notebook
No image is coming out of its LCD. It's diagnosed to have damaged video chipset. It seems its cooling system is inefficient. model: Sony VAIO VGN-CR131E
Hi
Who diagnosed it?
If the surface of the "video chipset" (graphics chip) is damaged it may be possible for a specialist, with an Infra Red Workstation to repair it:
Ball Graphics Array Reflow
or
Ball Graphics Array Reballing
These repairs can be expensive and the fault can come back after repair.
But it might also be a fault with the LCD Panel, the Cold Cathode Backlight or the LCD Panel Power Inverter.
Connect the laptop to an external desktop monitor with a VGA cable, using the Fn + F5, F6 or F7 button to send the image to the external monitor. If no image appears, then the fault is with the graphics chip, if you get an external image then the fault is with one of the other components I mention above.
I hope this helps.
Aug 26, 2011 | Sony Vaio Vgn-cr131e/l / Vgn-cr120e/l /...
Usb port are not working. need to install driver. model sony vaio VGN-SZ483N
If you can get the laptop online, then go to the Sony website ( click here ). You should be able to download the correct driver. If your laptop won't go online, you may have to burn the drivers to a disk in order to install them.
Jul 31, 2011 | Sony Vaio Vgn-sz436n/b / Vgn-sz476n/c /...
Sony VAIO VGN-FE590P screen backlight cuts off but the vga side works is this the inverter
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jul 22, 2011 | Sony VAIO VGN-FE590P Series (4400 mAh)
Sony vaio FZ240E display flicker
The backlight (ccfl) of LCD called cold cathode florescent lamp is most probably damaged.
You can go for its purhase or ask for a quote...
Oct 30, 2010 | Sony VAIO VGN-FZ240E/B Laptop
Dark Screen
Sounds like you broke your backlight and need a new LCD screen. A new one can be found here for $70.
http://cgi.ebay.com/SONY-VAIO-VGN-SZ1-B-VGN-SZ110-LCD-SCREEN-13-3-WXGA_W0QQitemZ350247988452QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item518c682ce4
Mar 15, 2010 | Sony VAIO VGN-SZ110/B Notebook
The screen fades out sometimes and i have to wiggle it to get it back. i have a sony vaio vgn-cr115e
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, usually the CCFL lamp fails before the inverter.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Oct 19, 2009 | Sony VAIO VGN-CR115E/P Laptop
My sony vaio vgn-n365e screen is Dim
Check out
www.lcdparts.net
Jul 24, 2009 | Sony VAIO PCG-K23 Notebook
Computers & Internet Logo
117 people viewed this question
David Payne
David Payne
