Question about V-Twin Horizontal OHV Engine with Electric Start - 610cc, GX Series
I have a 24 hp honda twin OHV engine that is back firing i beleive the timing is out , how do you time it
It starts and runs for a second or two tha when i turn it over again it back fires than starts and runs for 0ne or to seconds
  • Honda Master
  • 694 Answers
Bad coil or flywheel is very suspect probably leaning twords flywheel
Posted on Mar 02, 2014
2 Suggested Answers
aquaman987
  • 927 Answers
SOURCE: I have burned up one
Honda GX100U Parts List and Diagram - (Type KRE4)(VIN# GCAGK-1000001) : eReplacementParts.com
This web company has a superior list of Honda engine parts.
I have used them in the past.
Gary
Posted on Feb 02, 2011
Vanguard backfires through carb
If you say the valve stems were bent..first did you find out what bent them they just bend...and is the valve face seat damaged..if they were not...your engine is out of time or you did not set the valve stem lash when replacing them this allows the intake valves to be open slightly under the firing stroke firing back through the carb and intake...you should have around four thousands of an inch clearance when the springs are completely relaxed and and you should be able to wiggle the valve rocker tappits ...check that if they are correct your engine is out of time..good luck
Oct 10, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Only getting oil in one side of valves ? 24 hp briggs, twin
clean all the passages i usually drain the oil and replace with diesel fuel run for 30 seconds drain and replace with oil sae30
Aug 31, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Starting problem
the blades stop when there isnt enough power to engage electric clutch sounds like a charging issue when the engine is running place a voltmeter to the battery there should be over 13 volts if not replace voltage regulator if that doesnt work replace stator
Jul 19, 2012 | Briggs & Stratton Briggs Stratton Intek V...
New 24 hp B&S engine running out of fuel
There is a restriction somwhere before the fuel filter, this is assuming gravity feed and there is no fuel pump for the engine.
Jun 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
20 hp intec runs wide open
24 hp briggs. replaced cam, exhaust lobe was unhardened. now it doesnt fire on that cylinder. plug is wet. spark tester shows spark,please help.
Mar 30, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton 16 hp v twin..replaced con rod and piston
Needle and seat not functioning ... float stuck or trash in needle and seat of carb.
Jul 08, 2009 | Briggs & Stratton Briggs Stratton Intek V...
V-Twin Horizontal OHV Engine with Electric Start - 610cc, GX Series Logo
300 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Spud Howell
Mike Carew
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
