Question about Nokia 6120
Calling ok key not working - Nokia 6120
Plz hellp me
Posted on Apr 28, 2013
Why won't phone ring on incoming call?
Has this always happened?
Does it happen every single time? are you in cellular coverage, or does it happen only when you are in certain areas?
Have you got your call diverts set up correctly?
1. Find "Keypad"
2. Choose option
  • Choose one of the following options:
    • Divert all calls, go to 2a.
    • Divert missed calls, go to 2b.
    • Divert if unavailable, go to 2c.
    • Divert if busy, go to 2d.
2a - Divert all calls
  • Key in **21*+61411000321#
  • Tap Call.
2b - Divert missed calls
  • To select how long you want your mobile phone to ring before the call is diverted:
    • Key in **61*+61411000321**the required number of seconds#
  • Eg.:
  • Tap Call.
2c - Divert if unavailable
  • Key in**62*+61411000321#
  • Tap Call.
2d - Divert if busy
  • Key in**67*+61411000321#
  • Tap Call.
3. Return to the home screen
Jun 07, 2014 | Apple iPhone 5c
How do I adjust the volume control on my samsung t255g cell phone?
Main Menu Settings Sound Profile Find your selection (example "Normal") Hit the "OK" button Then there are three categories to choose from on this next screen (call, message, phone) use the left/right keys around the "OK" button to choose which one you want. Use the up/down keys around the "OK" button to modify the selection For example, use the right key to go to "Phone" and then the down key to make adjustments. Keep hitting the down key until the writing in the yellow menu says "volume" Hit "OK" From there you can adjust the volume
If you want to adjust call volume, highlight "call" with the left/right keys Use the down key to go in the yellow area and keep pressing the down key until you see "ringtone volume" then hit "OK" and it gives you an option to adjust ringtone volume
Hope this helps!
Feb 27, 2011 | Cell Phones
How to delecte recent logs
These steps should be more or less similar.
  • Press the OK button for Menu
  • Select Recent Calls, using the navigation keys
  • Select All (4)
  • Select the Recent Call type, using the navigation keys, from the following:
  • Missed Calls
  • Received Calls
  • Dialed Calls
  • All Calls
  • Highlight desired Recent Call, using the navigation keys
  • Press the right soft for Options
  • Select either Erase (2) or Erase All (4), using the navigation keys
  • Highlight Yes, using the navigation keys
  • Press the OK button to confirm call log deletion
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Feb 22, 2011 | Samsung SGH-T309 Cellular Phone
Is there a reset option on the samsung red rant i am umable to power on and i have a new battery
Try a Hard Reset:
Hard Reset will reset the phone to its factory settings and erase all data.
1. Press the MENU/OK key to select the MAIN MENU tile.
2. Scroll Up to Settings and press the MENU/OK key. 3. Scroll Up to More and press the MENU/OK key. 4. Scroll Up to Security and press the MENU/OK key. 5. Enter the lock code. For this example, press 7 to prompt one to fill in. If you can’t recall your lock code, try using the last four digits of your wireless phone number. If this doesn’t work, call Sprint Customer Service at 1-888-211-4727. 6. Scroll Up to Erase/Reset and press the MENU/OK key 7. Scroll to Reset Phone and press the MENU/OK key. 8. Read the Warning and press OK (Left Soft key). 9. Scroll Up to Yes and press the MENU/OK key. 10. Scroll Up to Yes and press the MENU/OK key to complete the reset. 11. For this example, once the reset is complete, scroll Down to No to decline to verify Wireless Backup
Oct 23, 2009 | Samsung Rant Cell Phone
Advice phaser 7300dn appear 10: eeprom ,help me please!
The only thing you can do is attempt a reboot and hope for the best, otherwise call out an engineer to repair it! Or you could try and NVRAM reset but I'm not sure if that will work and be careful because you will set the machine to factory settings and may have to do a colour calibration all over again. Let me know how it goes.
Resetting all settings to default (NVRAM)
Resetting the NVRAM will reset all printer values including network, printer setup, job defaults, and color calibrations.
  1. Press the Down arrow key and scroll to Support.
  2. Press the OK key.
  3. Press the Down arrow key and scroll to Service Tools Menu.
  4. Press the OK key.
  5. Reset NVRAM will be displayed.
  6. Press the OK key.
  7. Reset NVRAM and Reset Printer NOW will be displayed.
  8. Press the OK key to reset all the settings to default.
Dec 11, 2008 | Xerox Phaser 7300DN Laser Printer
Got a dialling tone but couldn't make a call
Cnavarro,
my existing phones work fine but the new phone is really weird. tested Ok at the supplier's store and perfect at my friends' houses. But once tested at any of the phone outlet in my house, after keying the first 3 numbers....PLEASE CHECK YOUR NUMBER AND DIAL AGAIN etc... the scenario telling me my phone service in my house is OK and the new phone tested OK at other locations.
See if you could give me some clues....thanks
Oct 07, 2008 | Innovage 69420210126 Phone
Sony ericsson w910i keys
mine has done that with the ok, L-select, R-select, end call, start call, deleate, and numbers 1, 4, 7
Aug 26, 2008 | Sony Ericsson W910i Cellular Phone
Nokia N70 phone white screen and Hangout problem
hi there you've go a software problem there try this manual formating somtimes it works but if not must go now to any nearest service center to reprogram your phone. ok!
so here's the tricks to format....
power off the phone first then PRESS and HOLD
"CALL KEY" + "* KEY" + "3 KEY" then power on the phone just hold and wait till NOKIA LOGO appears then release. finish, phone will be ok. you will know that you successfully format the phone cuz' all your data form the phone will be back to normal.
ok!
peace!
Mar 31, 2008 | Nokia N70 Cellular Phone
Nokia 6120 Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
