How to set up DV-5160 speakers on Led tech tv
Sir .I have Sony Trinitron TV model kv2197m3.it is not power on. If we gave current only a small ocsilating sound is coming and no LED light .but we cut 110v to LOT TV will on and speakers are on and led...
that high whine sound you hear is the circuit crowbar most likely as its shuts down the high voltage because of a bad voltage detected in the circuit. simple for a tv tech but not worth it to the average peroson to fix
Oct 12, 2014 | Televison & Video
Battery led blinks orange on dell inspiron 5160
if the battery LED blinks orange, most likely there is a problem with the battery itself. Try to remove the battery and have the power cable connected to it. If there is no battery LED blinking, call Dell to replace the battery itself..
Aug 20, 2011 | Dell Inspiron 5160 Notebook
We just bought a devant 46" LED LCD TV this weekend.. Just asking if the sound quality of the TV itself is somewhat mono-type like? I compared the standard sound of that LED tv to any regular tv...
due to marketing and studies these companies are under the assumption that everyone that purchases a new tv is also buying a surround sound system. to cut cost they and save weight they go with lighter speakers. and then there is the this thing with loud sounds being the cause of people going deaf so to prevent that the manufacturer of your tv sets the decibels to an acceptable level because they care.even a tv from the eighties sounds better than most tvs today
Feb 22, 2011 | Televison & Video
Sony 60 in LCD edge LED TV: Hooked up new TV to a cable box - have HD picture but no sound. TV speakers say on. Makes sound when TV channel is changed (static). But nothing when input cable (via HDMI) is...
Your cable box most likely has a setting for audio HDMI such that HDMI sound is turned ON etc. rather than standard audio. Also check the TV settings for HDMI audio being set to ON. This should be a simple fix. HDMI audio usually is just a user setting adjustment and nothing more. Somewhere in your on-screen menus you should find the place to adjust HDMI audio.
Aug 12, 2010 | Sony XBR60LX900 60 in LED TV
Code for remote
To program your URC-3021 remote control to operate your TV, the remote has a code search function.
To search for a code for your TV:
  1. On the remote control, press TV once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
Hope that helps.
Dec 08, 2009 | One For All URC-3021 Remote Control
Fine tune audio on Dell Inspiron 5160
The only way you are going to get any enhanced audio out of a 5160 is with an external USB audio device.
One option: PCMCIA Sound Blaster® Audigy® 2 ZS Notebook
Jan 24, 2009 | Dell Inspiron 5160 Notebook
Dell Inspiron 5160 flashing orange / green power LED
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
pls do rate me FIXYA if i helped u
Nov 29, 2008 | Dell Inspiron 5160 Notebook
TV doesn't turn on
When the set is turned on, the computer senses that something is wrong and immediately shuts the set back off. The standby LED will then blink a code, a certain number of blinks, to indicate exactly why the set was shut down. It is possible that your audio output IC is shorted, as this would make a pop or strange noises in the speaker just before the set shuts down, which it does to protect your speakers from burning up. The set should be looked at by a qualified tech familiar with Sony TV's.
Aug 21, 2007 | Sony FD Trinitron WEGA KV-36FV310 36" TV
Televison & Video Logo
209 people viewed this question
Top Televison & Video Experts
Electro Med Services...
