Question about Dishwashers
Kenmore elite dishwasher 665.1605 is not draining. It goes through the normal wash cycle but the water just wouldn't drain.
bigg t
  • 640 Answers
SOURCE: Stuck on wash cycle
Do you set your cycles by a manual timer or do you have a digital display?If a timer then it most likley bad or its stuck---if thats the case try wd40 behind it and see if it loosens,If your unit is digital then the control board is most likley bad,let me know.
Posted on Aug 06, 2008
  • 172 Answers
SOURCE: KENMORE ELITE DISHWASHER - MULTI-LIGHTS FLASHING
Look at your manual, usually available on net for reading or downloading. Blink lights are often used to code out a problem with various combinations and repetition rates to indicate trouble code number for look-up in manual.
Posted on Feb 22, 2009
  • 236 Answers
SOURCE: my carlton dishwasher fill and drains but does not wash
sounds as though the wash motor/pump is jammed or has seized therefore no wash.
Posted on Mar 16, 2009
wheelshot
  • 102 Answers
SOURCE: dishwasher runs, water doesn't drain out
sounds to me that you may have some suds residue in the dishwasher that keeps it from draining completely. Get you some dishwasher cleaner which you can purchase at wal-mart or wherever you buy your detergent, and clean out your dishwasher. It is a inexpensive test. Alot less expensive than having a tech come to your house. Make sure that your drain hose is mounted higher that where it goes into the drain. This is also a common problem that I encounter in the field. Hope this helps. Let me know if I can help you futher.
Posted on Apr 04, 2009
  • 1891 Answers
SOURCE: kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Posted on Nov 22, 2009
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
Kenmore 665 Dishwasher
Sound like you have a bad control console, which will need to be replaced.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Apr 08, 2012 | Kenmore 13742 / 13744 / 13749 Built-in...
My Kenmore Elite dishwasher did not drain the water out of the bottom after the dishes were washed last night. Could I possibly have pushed a wrong button to keep it from draining, or do I have a problem?...
Yes , If the program controller has hung it would have skipped the drain cycle. So try to redo the cycle and see if the drain works, is not check the program controller and the drain valve/pump.- if there is food particles that have clogged and blocked.
Jul 26, 2011 | Kenmore Dishwashers
Kenmore Model @16969990 Washing water doesn't pump out, cycle doesn't finish, attemptes to run other cycles default to "normal wash"
The drain cycle does not complete as the drain pump is not working the pump out the water. So unless the drain level comes down to reset the water level controller the program does not progress further.
So check the voltage during the drain cycle if voltage is present then the drain pump is faulty if not the main controller is faulty.
replace accordingly.
Sep 17, 2010 | Kenmore Dishwashers
Kenmore elite dishwasher, does not get the dishes wet
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher hums
empty out the unit and recheck the arm and rack then start it up empty and check operation --if huming but working properly --stated it does drain so motor is operating ---then its operating normal ---if arm still not working will need to remove arm and check gear or shaft for damage
Apr 16, 2017 | Kenmore Dishwashers
Dshwasher has water on the bottom after cycle
your drain line is clogged or your pump is bad check both. the drain push a coat hanger down it and see if you can pull anything out.
Dec 08, 2007 | Kenmore Elite 45986 Front Load Washer
Dishwashers Logo
44 people viewed this question
Top Dishwashers Experts
