Question about Whirlpool ET1FHMXLQ / ET1FHMXLT Top Freezer Refrigerator
Whirlpool et1fttxkqoo refrigerator compressor dosnt kick in
The compressor dosnt kick in the fan works and is blowing cool, but the freezer is not frezzing the food.
  • Robert Moller
    Robert Moller May 11, 2010
    If the compressor has a problem of hard starting, you can install a hard start kit. Supco makes a 3 in1 and is available at most Appliance Parts Stores.
    Guru:
  • 462 Answers
First Check the voltage to the compressor. Usually just 2 wires. If you do not have voltage and you are sure it should be running (it is turned on and plugged in) Check the controller (thermostat or Sensor/board assembly) because your problem is not with the compressor as of yet.
Assuming you have power to the compressor and the fan motor there is running up to speed the coils under neath are clean here are the items to look for to check out your compressor:
Getting to this step: Either your compressor is broken inside or the start components are not working properly. Ohm the compressor terminals to ground and across to each other.
If any read anything to ground the compressor is bad.
Your readings between the compressor terminals should all be different and you should have 1 low 1 medium and 1 high resistance reading.
Add the low and mid reading together and the sum should be close to the highest reading. If it reads say 20% more or less then retest it a couple of times to confirm your not slipping on the terminals.
Assuming the above checks out: Get a new Start relay (start capacitor if so equipped) relay and overload (and capacitor if it has one) In other words everything that is external and attached to the wires or terminals on the compressor, and replace them on to the compressor. Then if it starts problem solved if it still does same thing the compressor is bad (broken mechanically inside the compressor) and you have to decide to replace compressor or replace the refrigerating compressor be it AC or Refrigeration.
A few times I have gotten a compressor to start after leaving it off for 6 to 12 hours then retrying it. See the compressor unless left off for 6 to 12 hours and sometimes as long as 24 hours Is tight due to linear expansion from heat. And about 1/2 the time it is ok after new start components are installed. The other 1/2 the compressor will be ok for a day or 2 then stop again. Most likely from a “hard spot” in the movement of the internal parts in the compressor.
30 years of doing refrigeration and this has not changed.
Please rate me as high as you can and ask me to clarify anything you don’t understand.
Posted on Apr 14, 2009
  • 159 Answers
SOURCE: ice build up in back section of a Whirlpool no frost top freezer refrigerator 66"hx30"wx27"d
your sure the defrost cycle works? sounds to me its not. you need to remove the freezer back and check the defrost components. or put it in the defrost cycle and see if it is working. to get that much frost as you describe the dor would have to be left open. also check all door seals. let me know what you find and we can go from there
Posted on Aug 10, 2007
fridgetech
  • 473 Answers
SOURCE: fridge not cooling
Most of the time on a whirlpool the problem is the relay on the compressor sometimes called the start device. I would replace that first. If you need help finding the part let me know. I will need the complete model # from the sticker inside the fridge section. You can look it up with diagrams at http://www3.sears.com/.
Posted on Nov 09, 2007
  • 958 Answers
SOURCE: Whirlpool 20.8 Top won't cool neither refrigerator nor freezer
that's about right, if the compressor is drawing more than 4 amperes, then it is no good.
A reminder also to check the condenser for dirt and debris that could have accumulated at the front, this is a major contributor to compressor failure. check also the fan near the compressor. it should be running at the same time the compressor runs.
that's nice to hear from whirlpool....
good luck tapperal,
tnx 4 using fixya,
drcool
Posted on Oct 07, 2008
  • 58 Answers
SOURCE: Refrigerator is running but not cooling
You have a bad compressor relay. to check it you will need a voltage meter. Remove the rear cover and you will see the compressor remove the relay held on by a wire. If the relay sounds like a maraca replace it with part #8201769. If is donesn't sound like somethings broken inside it check for continuity on all 3 compressor terminals ( all terminals should read closed ) now this can go to ways if the terminals read good and the relay is good then the compressor is lock rotor and has to be replaced. Most cases it's the relay Good luck hope this helps
Posted on Jan 08, 2009
tborn6
  • 700 Answers
SOURCE: Kenmore side by side refrigerator/freezer is not cooling
http://www.appliancerepair.net/apnet/frameset?
http://www.appliancerepair.net/apnet/refr/ch05.htm
try this site for the aanswers that you seek
Posted on Jan 23, 2009
My frige & freezer do not cool,light & freezer fan run,compressor & coil fan do not run,air is blowing out of air vent in freezer,no cooling at all
If the compressor isn't running, the refrigerator or freezer won't cool - period. Hopefully, by now, you've had a repair technician come and troubleshoot the problem.
Aug 06, 2014 | Frigidaire Gallery GLHS66EJSB Stainless...
My Whirlpool ET8WTKXKT0 doesn't cooling down. The fan is working, but the compressor like dead. What I have to check? Thanks. Victor
Its the problem with compressor,The problem is weak compressor.The refrigerant ( R12) in the compressor is got low.The compressor is weak.The compressor needs to be replaced.-------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that freezer not cooling this indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Whirlpool ET8WTKXK Top Freezer...
My whirlpool side by side is getting warmer. Freezer was up to 45 F yesterday, today 55 F, Refrigerator getting warmer too. Fan on freezer and refrigerator vents blowing, but isn't that cool. What's...
check and clean the condenser coil under the ref , remove the back to the ref if the compressor is real hot you need to put a fan behind the ref for a couple of hours until the compressor cools down then plug it back in.
Nov 21, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
My Whirlpool refrigerator quits working and restarts
Good day,
If it only occurs on a monthly cycle, even a service tech would not find it unless it happened while he was there.
First choice would be to replace both the thermostat and the defrost control. These are the items that turn the machine off and on and either one could hang or stick once in a while.
NOW, that is based on the fact that the machine goes totally dead during that period. If you hear something, anything running then the above does not apply.
The possibilities then, are, the fan motor in the freezer won't run (you can hear it running when you open the freezer door), the cooling fan motor behind the bottom rear cover that cools the compressor and condenser same situation, will not run.
Lastly, the start relay mounted on the side of the compressor is weak. It will not kick in the compressor, but in that situation, the fans will run.
Hope that helps. I've serviced a lot of refrigerators with that complaint, and it's always been the first 2 items.
Feb 17, 2010 | Whirlpool ET1FTKXK Top Freezer...
Problems with Whirlpool 21.0 cu. ft.
checklist: freezer fan running, compressor fan running, compressor running, any frost buildup on back wall of freezer. you may have to take a rag and touch the compressor to feel if its vibrating to see if its running unless you can hear it. please reply
Jun 12, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Side by side whirlpool refrigerator with easy water and ice, not
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 17, 2009 | Whirlpool 21.7 cu. ft. Side-by-Side...
Why does my freezer work but my refrigerator doesn't?
my westinghouse fridge
the freezer is working but not the fridge
Feb 05, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator not cooling down below 60 degrees f.
hi!!! make sure your inside fan is blowing and also go to back of your frig and see if the compressor and condensor fan are working if not then thats your problem..If they are working then you have a seal system problem in your frig..make sure when you look at the compressor you try to hear a cliking sound if you do then change the current relay..Good luck..
Jan 04, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridge not cooling
Nov 09, 2007 | Whirlpool ED5FTGX Side by Side...
Whirlpool ET1FHMXLQ / ET1FHMXLT Top Freezer Refrigerator Logo
183 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
