Question about HP Computers & Internet
Hp mini 110 keeps saying resuming windows but wont boot up
When turned on it goes to a screen that says resuming windows and gets stuck there can use f9 to go to another screen but still wont boot
furlough5
  • 28 Answers
SOURCE: hp mini screen is blank
Hello imlapd. If you don't even see words on the screen when you first turn it on (the BIOS puts things on the screen before it boots to Windows), then there are 2 possible causes. First, the video output or something else on the motherboard is bad. Second, the LCD display (the laptop screen) has failed. The cost to fix either one of these will be close to what the laptop cost brand new if not more. The good news is, if your HP Mini is less than a year old or you got an extended warranty, HP will fix it for free. You just have to call their customer service.
800-HP invent
or
800-474-6836
Be prepared to provide the following information: Serial Number (S/N), product name, model number, and a brief description of the issue.
Posted on Aug 27, 2009
  • 243 Answers
SOURCE: My HP Mini 1000 XP
Press F8 during boot this will take you to boot options select "Last Known Good Configuration" or select Safe Mode to perform a system repair.
To repair your system follow the steps below
1. Click Start and open Run on the Start menu.
2. Type (or copy and paste) C:\WINDOWS\system32\restore\rstrui.exe in the Run box.
3. This will open System Restore now select the first option (restore my computer to an earlier time) and click next.
4. Select a date when your network last worked and complete restoration.
Do not worry about selecting the wrong date you can always undo any restore within system restore you will select undo last restore.
Posted on Jan 12, 2010
bahratt
  • 561 Answers
SOURCE: Windows xp will not boot on my hp mini 110.Keeps
Try selecting Last Known Good Configuration, or Safe Mode, and use System Restore option to go back to a date where the system booted correctly.
If neither of these options work, then you need to try to get into Recovery Console:
  1. Insert the Windows XP CD into your CD drive and restart your computer. If you are prompted, select any options required to start (boot) from the CD.
  2. If you are prompted to Boot from CD, you need to change your Boot menu Order in BIOS or Setup to boot from CD before it boots from Hard Disk.
  3. When the text-based part of Setup begins, follow the prompts. Select the repair or recover option by pressing R.
  4. Type 1 to select C:\Windows
  5. When you are prompted, type the Administrator password. (usually blank, so just hit the Enter button on your keyboard.
  6. Type chkdsk /r (space between k and /) and press Enter.
  7. The process may seem to take a while and freeze at times, but it's working. Just allow it to finish on it's own. Once done, you can type exit, and press Enter. Remove the CD before the system starts up again.
Posted on Jan 15, 2010
sfender713
  • 397 Answers
SOURCE: hp mini 110 started with a hp symble and f9=change
The hard drive is not being recognized as a bootable device- you will need to reinstall windows or replace the hard drive in order to resolve this issue
Posted on Oct 02, 2010
seanb003
  • 149 Answers
SOURCE: HP mini 110 wont power
While the Mini is on, try holding the power button down for 4 seconds, then power back up. hopefully this hard reset will work.
Posted on Jan 14, 2011
It keeps asking for current password i dont know it
You can remove or change the Window's User or administrator's password and privileges. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Mar 22, 2013 | HP Mini 1000 Netbook
My hp mini110 wont boot up how can i fix it
Turn OFF the Notebook and once its powered ON, keep Pressing F10 to load BIOS screen of the Notebook. In this screen under Diagnostics, run the test on hard drive and memory. Post back the results here.
Sep 11, 2012 | HP Pavilion 110-1030NR Notebook
I have an HP Mini 110-3135DX. When I turn on the power all that is displayed is a blue screen and it wont boot. How do i fix it?
check you bios pages are correctly configured,,goto bios navigate with "tab" and arrow keys,,play around untill you know these pages dont change anything untill you are sure you know what you are doing..Exit and save pay attention to boot sequence if this is set up wrong it might cause failure in the way you describe,the instructions on the right hand side of the bios pages should help you---good luck --Davey
Jun 20, 2012 | HEWLETT-PACKARD HP Mini-Notebook...
Hp mini "unmountable boot volume"
I ran across the same problem. I used chk disc utility on a hiren's bootable usb. It found and fixed the errors on the main volume and it rebooted up without a problem after that.
Jan 27, 2012 | HEWLETT-PACKARD HP Mini-Notebook...
Hp mini 311 stuck in start up mode says "windows xp" over and over and then it goes to black and then starts up again with xp. I have turned off, taken battery out, tried to go into safe mode,...
boot it with the windows XP CD and reinstall windows. hit the 'r' key the second time it appears on the screen when it says that it has found an existing OS in 'c' drive, this will reinstall the OS without loosing any previous data.
Jul 01, 2011 | HP Mini 1000 Netbook
How to Reset HP Mini 1000 Laptop BIOS?
http://laptoppassword.blogspot.com/2011/06/hp-mini-password-service-compaq-mini.html
Clear Bios Password for HP Mini - Compaq Mini:
HP Mini 1000, HP Mini 110, Compaq Mini 110C, Compaq Mini 110, HP 2230S, HP Mini 1120LA, HP Mini 1151NR, Compaq 700....If you see this screen on boot:Enter CURRENT Password: [_______________]
We can help you Remove Password, right now !!!
You just enter 3 random passwords one by one and see if you get a similar [System Halted] message with 10 chars Error Code. (e.g CNUXXXXXXX, 2MCXXXXXXX....)
Jul 16, 2009 | HP Mini 1000 Netbook
Computers & Internet Logo
80 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
