Question about Stiebel Eltron Mini-4 Tankless Water Heater
Stiebel Mini 4 won?t activate using 40l/min pump
I’m using a 40 l/min pump to run water from a tank through the Stiebel Eltron Mini 4, but the unit won’t activate. I tested the pump and the water heater separately and they both work fine; the pump seems to run enough water and the water heater works fine on public water system.
Also, when using the pump the water flow coming from the water heater is very low.
  • 25 Answers
You have to make sure that the pump is flowing enough water to activate the Stiebel. The tankless unit has a activation rate of a certain amount of water to turn it on.
Posted on Jan 20, 2009
How do I press the reset button on my stiebel Eletron mini tankless water heater??
On all models, you must remove the cover to access the thermal safety reset. MAKE SURE YOU DISCONNECT THE POWER BEFORE OPENING THE CASE. On Mini™ models, the safety thermal reset button is a round, flat, black button located between the wiring block and water connection pipe.
here's a video....
http://www.stiebel-eltron-usa.com/tankless-faqs
if it helps please click helpful :) & let me know thanks!
Jan 03, 2018 | Water Water Heaters
The thermal breaker keeps blowing
Replace the limit, by tripping often they become even more likely to nuisance trip.
Apr 29, 2016 | Stiebel Eltron TEMPRA 24 Tankless Water...
Stiebel Eltron 221094
Stiebel eltron model 221094 hot water is not as hot as it was before,
only warm water coming through. Do I need to replace unit?
Oct 05, 2013 | Stiebel Eltron DHC 10-2 Electric Tankless...
Heating unit in a stiebel eltron electric instant hot water heater went bad and I have to replace the unit. How difficult is that?
You will have to drain the tank, make sure when doing this to OPEN the pop off valve, the little handle on the drain pipe, or the water will not drain.
Feb 21, 2013 | Stiebel Eltron 240 208 Volt Electric...
Tempra 36 luke warm
turn thermostat up, if that doesnt do it, replace therm.
Dec 20, 2012 | STIEBEL ELTRON TEMPRA 36 Tankless Water...
It's running a long time
it would be norma[ for the first time you fireit up. from then on it should br fine
Dec 19, 2012 | Stiebel Eltron Accelera 300 Heat Pump...
Eletric water heater not heating up to 125
Include product brand, model and type for best possible answer.
Include if this is new installation, or installation that worked before and stopped working.
Oct 03, 2012 | Stiebel Eltron Stiebel TEMPRA24PLUS Eltron...
What s de minimum working pressure for a tempra 24?
Hello. let me help you. The water pressure is what it is in the house. In other words, the tankless water heater doesn't increase the pressure of the water, it only heats the water. There is no official minimum pressure but the minimum pressure you would be happy with in any home would be 20 pounds per square inch, PSI.
Jun 05, 2009 | Stiebel Eltron TEMPRA 24 Tankless Water...
Stiebel Eltron Mini-4 Tankless Water Heater Logo
192 people viewed this question
Top Stiebel Eltron Water Heaters Experts
chargerhp
chargerhp
Gil Shultz
Are you a Stiebel Eltron Water Heater Expert? Answer questions, earn points and help others
