Question about Fisher and Paykel Washing Machines
I have a fisher and Paykel WA80T65GW1 8kg top loading washing machine that has a lint problems and every time I wash dark clothes there is always a build up of lint which is noticeable on those clothes. I previously had a front loader with no such problems is there anything I can do to allivate this problem. Thanks Nicky
  • 37 Answers
SOURCE: washing machine lint
fluffed up,
If you have a manual filter..make sure it's clean. If you do, and it is, the tub drain could be blocked.( it is under the agitator and basket, requires disassembly) If you don't have a manual filter, the self-cleaning filter/ trap could be clogged.(it is underneath, also requires some disassembly. If you have tools and feel comfortable with things mechanical, get a repair manual from the library, maybe you can tackle the fix.
hope this helps,
handiman518
Posted on Jan 17, 2008
yalmer
  • 549 Answers
SOURCE: Connecting a new front load washing machine - Fisher & Paykel
Ther are only two things to look for with a new machine and they are...turn the water on or screens at the back of the machine where the hoses connect are plugged.
Maybe you have shipping plugs there.
Try www.fisherpakel.com for help.
Posted on Feb 22, 2008
mikedurland
  • 481 Answers
SOURCE: The lint is not being
the self cleaning lint filter seems to be clogged. before you replace it try this cheap/ easy remedy.
  • run a load with no clothes on high water level, hot water and a gallon or two of bleach.
  •  no soap.
  • do an extra rinse after to make sure you rinse all the bleach away before putting more clothes in.
the lint filter may be defective since it has always had this problem, but its worth a try.
Posted on Jul 01, 2008
TechBrian
  • 15 Answers
SOURCE: Blocked filter in Fisher & Paykel washing machine top loader
Fisher & Paykel washers do not have lint filters inside the tubs as they are designed to drain away any debris from the wash during the drain cycle.
Posted on Mar 10, 2009
  • 713 Answers
SOURCE: cloths come out of machine dirty the machine is a
Hi just read your posting.Now from the information in your posting it tells me you have tried all the settings and cycles and still the soap is present on the clothes at the end of the cycle,Is this correct?Have you tried a cycle with the EFFICIENCY button switched off and in the Regular setting?Have you tried a liquid detergent?Please reply with additional information on the questions and I am sure I can help you rectify this fault.Looking forward to your reply.
Posted on Aug 04, 2010
I am getting a lot of lint on clothing is there a cleaning process with my smart drive pride 5.5 fisher & paykel washing machine
clean the lint filter in the machine
put any clothes that are likely to shed lint or are susceptible to collecting lint in a wash bag before putting in the machine
Oct 17, 2017 | Fisher Washing Machines
Lint goes all over my washing every time i use the machine
Wash lint givers (eg. towels, flannelette sheets) separately from lint collectors (eg. synthetic
fabrics). Over loading SmartDrive can increase the likelihood of linting. Insufficient detergent for
the load can increase linting as there will not be enough detergent to hold the lint in suspension.
Over drying synthetic fabrics in a dryer can cause a build-up of static electricity and result in the
fabrics attracting lint.
Jan 06, 2013 | Fisher and Paykel Aquasmart wl80t65c
Dirt after washing
WASH PERFORMANCE INFORMATION
12.1 Creasing
Creasing can be caused by over loading SmartDrive or the dryer. Permanent Press or Delicate
cycles have been designed to minimise creasing as they use a lower spin speed. Do not leave wet
clothes to sit in the washer or laundry basket.
12.2 Soiling
Soiling is the result of insufficient detergent for the load. White clothes are better washed
separately. Separate lightly and heavily soiled items, as clothes can pick up soil from dirty wash
water. Cold water below 20oC does not wash effectively. Select the wash temperature according
to soil type. For example, blood and mud are better washed in cold water, while sweat and oil
based soil wash better in warmer water. Loads made up of articles of varying sizes will wash
better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent than
soft water.
12.3 Linting
12.4 Detergent Residue
Over loading SmartDrive can result in detergent residue being caught in the creases of the
fabrics. If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check
the instructions for the detergent. Cold ambient temperatures, cold washes or short agitation times
may not let the detergent dissolve properly. In these cases pre-dissolve the detergent.
Overdosing of detergent can also cause residue when foam breaks down and will show as white
specs on the clothing. Poor quality detergents can result in residue.
12.5 Black Marks on Clothes
A build up caused by the interaction of fabric softener and detergent (scrud) can flake off and mark
clothes. Do not use too much fabric softener, maximum 75cc. If this is a problem, it is
recommended that SmartDrive is periodically filled with hot water, plus 1-2 cups of dishwasher
powder and left to soak.
12.6 Grey Marks on Clothes
Not enough detergent for the amount of soil on the clothes can result in grey marks on clothes. If
this is a problem it is recommended that SmartDrive is periodically filled with hot water, plus
detergent and left to soak.
12.7 Dye Transfer
Wash and dry non-colourfast clothes separately. Non colourfast clothes left sitting in a washer or
laundry basket can transfer dye to other clothes.
12.8 Tangling
Washing with too much water (i.e. under loading) can cause the clothes to tangle around each
other. Do not load SmartDrive by wrapping clothes around the agitator.
Aug 11, 2012 | Fisher and Paykel Washing Machines
Fisher & Paykel ecosmart GWL11 fill problem
Your diverter valve is cloged with lint and not fully closed and is letting wash water go down the drain.
Feb 22, 2012 | Fisher and Paykel GWL11 Top Load Washer
My washing machine is ALWAYS off balance. I have tried adjusting the nobs on the bottom several times...a level always reads the machine is level.
Hello, the possible cause is if there is a thumping noise during spin cycle, the loads of clothes has probably gotten unbalanced, and what you will need do is to open the lid, redistribute the clothes in the washer, then restart it, repeat these steps if necessary.
Thanks
Jun 10, 2010 | Fisher and Paykel GWL11 Top Load Washer
Mar 10, 2009 | Fisher and Paykel IWL12 Top Load Washer
Fisher and Paykel top loading washer
This is not grease this is a build up of poweder in the machine on the outer bowl, this will also happen if you use too much fabric softner. :)
Sep 08, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
283 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
