Question about Oki Brand Oki B710n Network-Ready Laser Printer
Replaced Toner Is Not Registering
I have installed a new toner cartridge but the printer is still showing the "Toner Out" message and will not print. Is there a way to manually reset, or could it be a problem with the actual toner cartridge.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 76 Answers
Did you change it with the printer on?
Posted on Dec 17, 2013
I am having "install toner" problem
Hi Swarnab,
When you replace the toner cartridge, you need to reset the printer to tell it that it has a new cartridge.
The way you do this is to buy and install a toner reset chip.
You can readily buy these online from sites like Ebay. Make sure you get installation instructions when you buy the reset chip.
Happy printing.
Feb 10, 2014 | Samsung SCX-4300 Monochrome Laser...
Replaced cartridge still get error message
Clear the error, then hold the switch off then on.
Oct 14, 2012 | Canon imageRUNNER C2550 Color Copier
Cartridges error on a lexmark
Error: "Invalid Toner Cartridge"; Error: "Invalid Refill"; Message: "Change Cartridge"
Solution
One of these error messages may appear on the printer display immediately after or shortly after a new toner cartridge is installed into the printer. Note: This may not be specifically a toner cartridge problem; the error may be due to a stuck cover open switch on the printer.
To see if the cover open switch is the cause of this problem, open the top front cover and observe the message on the printer's display panel. The display should read Close Door or Insert Cartridge.
If this message is not displayed, the top cover open sensor and switch will need to be replaced. In addition, the printer may have damaged the new toner cartridge. If the cover open sensor is not operating properly, a new cartridge can be incorrectly flagged as a refilled cartridge by the printer. If this happens, the new cartridge will continue to cause an Invalid Refill or Invalid Cartridge error even if you try reinstalling it or installing it into another printer. If this should occur, please contact the point of purchase of the cartridge to find out how to get the cartridge replaced.
Caution: If the cover open sensor is not operating, do not install another new toner cartridge until you have completed the directions below. Inserting another new cartridge can cause that cartridge to stop working as well. Should this situation arise, please take the following actions:
Place the original working cartridge (the empty or near-empty one) back into the printer. This should clear the error message.
Turn the printer off. Doing this will disengage the cover open sensor.
With the printer switched off, open the top lid and remove the old toner cartridge.
Now replace the old cartridge with another new Lexmark toner cartridge.
Power the printer back on. The printer should now read this cartridge as a newly installed toner cartridge and the error should be cleared. The printer and toner cartridge should function properly now, but the top cover sensor on the printer will still need to be replaced.
If your printer is still under warranty or covered under a service contract, please contact Lexmark Technical Support or your service provider for further recommendations and instructions. Until you can get the cover open switch replaced, remember to have the printer powered off whenever you replace the toner cartridge.
If the top cover switch appears to be working fine, or if you have followed the above steps and your printer continues to post an Invalid Toner Cartridge or Invalid Refill error, make sure you are using a new original Lexmark toner cartridge. A toner cartridge remanufactured or refilled by a third party can cause this error.
To help identify a refilled cartridge, look for the yellow label attached to the toner drum and the body of the toner cartridge. If this is damaged or removed, the cartridge may have been refilled.
If you are using a third-party refilled or remanufactured toner cartridge, it is recommended that you install a new Lexmark brand toner cartridge. Lexmark cannot guarantee the compatibility of any third-party toner cartridges with our printers.
OR
1 Switch on the Lexmark X83 printer.
2 Lift open the cartridge door at the front of the device, below the scanner unit. The printer automatically moves the cartridge carrier to the correct position.
3 Pull each ink cartridge toward you to unclasp it from the carrier. Lift the cartridge out of the cartridge carrier.
4 Clean the copper contacts on the bottom of each cartridge with a clean, dry lint-free cloth. Use a gentle, circular motion to clean the contacts.
5 Insert the ink cartridges back into the cartridge carrier. Push back firmly on each cartridge until it snaps into place.
6 Repeat each step in this procedure again. Close the cartridge door.
Oct 04, 2012 | Office Equipment & Supplies
I have Samsung ML-1666 Laser Printer. I am getting
I would not advise you to refill a toner cartridge becausethe toner powder is very fine and you do not want to breath in this tonerpowder.When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint.You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer.This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter.A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Jun 02, 2012 | Samsung Office Equipment & Supplies
Independent-supply toner message
Treat the same as "Non-Genuine Toner". Caused by installing a refilled toner cartridge or taking out cartridge out, putting a new toner, and then putting the old one back in. Place a new toner in the machine, change SP5-051-001 to 1, and cycle power.
Jan 12, 2012 | Office Equipment & Supplies
I have a samsung printer 4521 and a new message appears on my screen saying: "FEED TONER EMPLTY" the fax is accepted but never printed. what to do???? thx in advance for ur help. my email:...
When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Aug 17, 2011 | Computers & Internet
WE GOT MESSAGE LIKE "TONER
Aug 10, 2011 | Office Equipment & Supplies
Put in new toner cartridge and printers still shows "TONER EMPTY" . I have reinstalled the toner cartridge 4 times and still have the error message.
You do not state the brand of printer, but some models like Brother and Lexmark do not automatically reset the toner counter and it must be done following the instructions included with the toner.
Jul 25, 2011 | Office Equipment & Supplies
Oki Brand Oki B710n Network-Ready Laser Printer Logo
180 people viewed this question
Top Oki Brand Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Oki Brand Office Equipment and Supply Expert? Answer questions, earn points and help others
