Tv turning on and off, not a power supply problem, maybe tv seeing a fault trys to switch to standby
  • 1 more comment
  • murpheyd Jan 18, 2009
    My Akai LCT 2662 started to turn itself off, then it wouldn't turn off, then it just turned itself off???? Why doesn't anyone come forward I have heard this is a common issue with this AKAI model TV.
  • stuartamitch Jan 22, 2009
    So would replacing the main board be very expensive? shall i just bin the tv
  • murpheyd May 11, 2010
    Can we obtain a main board today where or is this unobtainium? $$$
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 88 Answers
Most likely cause is bad filters on the main board. This is common problem and will require the main board to be replaced.
Posted on Jan 18, 2009
I have a Samsung TV that will not turn on.
You have diagnosed the fault yourself. The main board of your TV is defective and needs to be replaced.
Good Luck.
Oct 02, 2017 | Samsung Televison & Video
Problems sony wega tv
Do the standby light ON. If not check the 5V supply rail on the main board. If standby light is ON, and it blinks? If so, these blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jul 27, 2014 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Logik TV stuck in standby
if you don't hear a click its the power over switch. on the power board it is a black box. if you have the back off turn the tv on and then out of stand by and flick the black box it will probably turn on.
Feb 25, 2014 | Televison & Video
LG 32LH2000 My TV was turned of last night in the usual way, the power turned off on the remote control, then the power supply switched off and the plug removed. This morning I attached the power...
most LG have a "vacation switch" on the bottom right hand side of the set very near that standby light.
it is placed poorly, where you can accidently click when grabbing the TV to move it or swivel it.
it is a toggle switch, a "master power" switch.
you may have bumped it to the off position. flip the switch, your standby light will come back on.
Apr 16, 2011 | LG 32LH20 32 in. LCD HDTV
Maxent 42 in MX42v1 doesnt power on
mate try this hold the mains switch pressed in fo 10 sec's then press chanel up on the front.thid failing you have a line scan fault try diconecting scan coils if the set fires up change the line transistor . this failing the line output transformer could have failed. good luck farr64
Apr 30, 2009 | Televison & Video
Will not turn on
Hi
maybe you have defective power cord or in your outlet, look first. or maybe you have defective unregulated power supply.
did you see the standby light?
Thanks!
Apr 12, 2009 | Toshiba 30HF85 30" TV
Goldstar TV (unknown model)
tv has a power supply fault requires service
Oct 22, 2008 | JVC AV-27530 27" TV
Same problem: LA40R71B
Does it make the the samsung jingle when it trys to turn on? if it does you need a power supply if not then most likely it is the main board. I would contact you r local service center for help and if the standby lights in the front blink in a certain pattern write that down it is a error code that the technicain can use to solve the problem.
Aug 09, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
TV Power on - No Picture
Bad IHVT ( aka flyback transfomer) replace with 257805 ? or
Asti 2078.....................confirm service # F36650 YX01
Please rate this solution..............................
Nov 13, 2007 | RCA F36650 36" TV
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
