Question about Directv Televison & Video
Need Directv HD Receiver code to program my Sharp Aquos remote
Need a code for the receiver so I can operate my Directv receiver with my Sharp Aquos remote
  • 27 Answers
SOURCE: programming the directv remote to program a sony audio receiver
Go through the process of setting up the remote again instead of trying the volume first use the power off button. In my experience, Sony receivers can be picky and power cycling "will" insure the code set, then try the volume.
Posted on Mar 09, 2007
Kazong
  • 152 Answers
SOURCE: Remote control code to program for directv receiver
i have a ton of codes i need your model# of your Directtv Receiver.
Posted on Feb 05, 2008
SOURCE: Viewsonic HDCP LCD & DirectTV HD receiver
Will Direct tv recievers work with my new 23" widescreen ACER monitor? The monitor has VGA input,DVID withHDCP input and HDMI input
Posted on Mar 02, 2009
  • 56 Answers
SOURCE: How do I program a Directv remote witha Samsung Directv receiver
http://www.directv.com/DTVAPP/global/contentPageIF.jsp?assetId=P4380052#h:1020.989
there is the website, put in the name of the receiver as Samsung and make sure you are under "SATELLITE SET TOP BOX" and follow the instructions on programming. hope this helps!
Posted on Apr 05, 2009
SOURCE: remote will not work
Use your box and go into Menu then to Setup then Select, next Syst Setup go to Reset then go to Reset defaults use the mute select buttons at same time after double flash press 961 then go back and press mute select after the double flash press 00001 and presto the remote worked again!
Yeah I didn't have to reset everything.
Read all your screens first before just calling DirectTV!
Posted on Apr 24, 2009
Need the codes to program the remote to operate the sound bar
[PDF]Remote User Guide - MyDISH
https://www.mydish.com/filestream.ashx?ID=3037
remote. The standard setting for TV2 operation is UHF. If you wish to use. IR signals ... The on-screen bar ..... a remote-controllable audio receiver or amplifier.
How to Program DIRECTV Remote Control ' DIRECTV ...
https://support.directv.com/.../how-to-program-directv-remote...
DIRECTVLearn how to program your DIRECTV remote control in just a few short steps and ...control up to four devices, such as your TV, HD DVR, DVD player, and audio ...
Is it possible to have DirecTV remote control sound bar volu
Dec 21, 2015 | Televison & Video
How do I setup my dvd to mt tv, i use direct tv
DIRECTVTo do this, press and hold the MUTE and ENTER buttons while pointing at your Genie HD DVR, Genie Mini, or Wireless Genie Mini. The screen will display Applying IR/RFsetup. To program your remote to control a regular HDTV (not a DIRECTV Ready TV) or audio devices, follow these steps: Press MENU on your remote.
How to Connect DIRECTV Receiver to TV ' DIRECTV Support
https://support.directv.com/.../how-to-connect-directv-receiver...
DIRECTVHow do I connect my DIRECTV receiver to my TV? Print. Email ... This will help you determine what cable to use to connect your receiver directly to your TV. ... For example, a DIRECTV receiver, DVD player, Blu-ray™ Disc player, o... How to ...
Remote Control Code Lookup - DirecTV
Dec 10, 2015 | Supersonic Televison & Video
Why can't i see 1080p programs on my directv hd dvr? The test on the hdr says my receiver doesn't receive 1080p. My tv is a Sharp LC-62C42U which is suppose to receive 1080p!
Your DVR can't detect whether your TV can do HD or not. If the message is stating that your receiver (which is your DVR) can't receive 1080P, then you'll need to contact DirecTV for assistance. You may need to replace your DVR.
Mar 01, 2011 | Sharp LC-62C42U 42 in. LCD TV
Sharp 37" LCD/TV will not remain programmed with DirectV. DirectV technicians have come out to re-program the Sharp TV. They simply say over and over again that it is a Sharp problem. They keep telling me...
First of all any make or model tv will work with any directv receiver as long as it is connected properly. In my expierence Sharp TVs are compatible with all directv recievers. Is the directv remote not functionly properly with your sharp tv or do you have a black or snowy display. Your tv has to be on correct input in which the technician should of educated you on this instead of suggesting the purchase of a sony branded tv. Black or snowy display indicates the wrong input. Using the tv remote find a button labeled source or av or input and try pressing that button until you see a picture. otherwise call directv tech support at 800-347-3288 and demand that this issue is resolved immediately.
Mar 09, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Toshiba dr-2 and directv hd sat rcvr hr22
Check the manual to see if there is an automatic code search feature for your Toshiba. It may be easier to program your directv remote to operate your toshiba. You may not get the full use from either remote, but its worth a shot
Dec 01, 2008 | Arris DCT2608
Direct TV HD Receiver/Recorder codes
Check the Innovage manual for the automatic code search. If it works, you still may not have full control of your HR20. Try to program your Directv remote to operate your components
Jul 07, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
I have the One for all Cinema 7 remote control. I need the code for the Directv HD Receiver Model H21-100
I gave up on the Cinema 7 remote control. I got it to turn the HD Receiver on and off by programing the L buttons but could not change channels. Although the Sony remote is very large, I programed it to operate the Receiver.
Thank you
Apr 08, 2008 | Televison & Video
Can't program my DirecTV HD receiver
this remote will not work with the directv receivers. the best thing you can do is get an actual directv remote... $15 from the directv website and program that to the other electronics you want to use it with
Feb 10, 2008 | Philips PM-8FS LCD Touchscreen Remote...
Feb 05, 2008 | RCA DRD430RG DirecTV DTV Receiver
Directv remote codes
go to menu
setup
setup again
remote
tv
brand
the satelite receiver will tell you the procedure for programing the remote
Nov 14, 2007 | Televison & Video
Televison & Video Logo
361 people viewed this question
Top Directv Televison & Video Experts
john milligan
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
