Question about LG 42PG20 42 in. Plasma HDTV
Humming from back of tv
Hi, I just purchased a 42" plasma around 2 months ago and all of a sudden im hearing a loud humming coming from the back. the sound comes and goes but it mostly comes. It does go away for some time if i tap the back. what is this sound?
  • 1 more comment
  • Anonymous Apr 12, 2009
    just bought a 42" vizio plasma tv, and i got the annoying bzzz too, if i turn it off for a little while and yurn it back on, no bzzz, but after a short while, bzzz is back!!!! aaaahhhhhhhhhhhh, so annoying!!!
  • ninoamigo Apr 15, 2009
    lg please improve
  • Anonymous May 04, 2009
    Hi I have the same problem, starts buzzing after some time, switch off for a while and it fixes the problem but only temporarily. jscruggs420, specifically do you mean there is a problem with the power supply? how can I fix this is it a case of the capacitors failing?
  • 36 Answers
Sounds like your powerboard, you can try a cheap fix by putting a small fan behind the tv on low and see if that helps. Also I would not settle for this and call in the warranty and get it fixed while you can.
Posted on Jan 18, 2009
How do I fix loud humming noise in my DLP HLP4663W 42 IN Samsung TV?
I would start by checking all the cooling fans to see if one is dirty or possibly failing.
Aug 30, 2015 | Samsung HLP4663W 46-Inch Widescreen DLP...
Loud random humming noise coming from near my glove box
Blower motor ? Take the glove box , plus lower panel ! When it happens , investigate the noise . You don't say what make , model , year vehicle . Don't know whats back there .
Jan 15, 2018 | Cars & Trucks
Humming sound
Samsung states - A buzzing sound from your plasma TV is normal. It is caused by the electrical charges used to create the images on the screen. The buzzing, however, should not be so loud that you can hear it when the volume on the TV is set at normal levels.It is also important to determine the type of buzzing sound. A sound like a ground hum is completely normal. This buzzing can originate near the power cord connection or from the SMPS board position on the upper back of the TV. The buzz will be more audible as contrast increases on the screen, most notably when displaying an all white screen. If the buzzing sound is loud, you may have the Contrast set too high. Lower the contrast to reduce or eliminate the buzzing.You may also have loud buzzing if the rear of your Plasma TV is too close to a wall or other hard surface. Try moving your TV away from the wall until the buzzing is minimized. [1]
If the buzzing is at a higher frequency and resembles a crackling sound (like the sound of Velcro being pulled apart), and originates from the upper middle back of the TV, you likely have a failing SMPS board. Place a support call with Samsung to have the SMPS board replaced.FP-T5084 Have a known buzzing problem with a very simple fix.If the buzzing is coming from the left or right sides of the rear and the volume can be changed by pressing lightly on those locations, you are probably hearing the vibration of the grounding springs on the back panel. Call Samsung (or whoever) and have a technician confirm the problem. The easiest fix is to insulate the offending spring by applying some felt tape.
May 22, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
I have an kenmore elite "ultra wash" model 665. not sure the rest.. about 7/8 years old, making loud buzzing sound during wash cycles,starts about 5 minutes into the normal wash cycle. i removed the inlet...
I have the same problem as those who stated their dishes are not getting clean. If you listen to the wash cycle you should hear water sloshing around inside. If you hear just a humming sound the washer has no water. I have this problem. I had a tech come and he told me the water is syphoning out my drain and I need to change my plumbing, then he charged me $65. I have lived in this house for ten years. 6 with the washer that came with house and 4 with this Kenmore Elite. This problem started about 6 months ago. So what I have been doing is opening the door, after the humming starts and the sloshing stops, and adding about 2 L of water. It seems to wash just fine after that.
Jan 12, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
Buzzing or humming rear passanger tire
Hub bearing in the right rear is the most likely problem
Mar 27, 2009 | 1994 Honda Accord
No picture or sound
Hi, your color wheel needs to be replaced, the bearings fail causing the grinding noise, the new ones use "air bearings" so they are supposed to last much longer, video-tek
Mar 26, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Panasonic TV Turned it self off, humming speakers, loud bang & Burning Smell
hi there, you do have a big problem at your tv, the loud bang means a part is broken, maybe you will cost 50 % of the original price of your tv. ty
Dec 26, 2007 | Televison & Video
LG 42PG20 42 in. Plasma HDTV Logo
909 people viewed this question
Computer Repairing
Computer Repairing
