Question about KitchenAid 24 in. KUDI02FRSS Stainless Steel Built-in Dishwasher
No water flow through dishwasher
Water flows into the dishwasher but it collects at the bottom. the water is not traveling through arms of sprayers. Need a new motor? Does the motor have a reset button?
I've gone through turning off the power and resetting the machine but it still continued with same problem.
  • Joe Havlik Feb 04, 2009
    same problem different unit.I have a samsung unit 3 years old, water come in sits at bottom of unit then drains out at end of cycle. I took apart the entire inside, cleaned what I thought might be able to be cleaned still nothing. Would the pump being bad cause this? does the water flow in without the pump working?
    It started not long after we noticed a glass had shattered in many pieces but I thought we cleaned that out. Is there some place else I should be cleaning?
  • garyrotschi Feb 14, 2009
    the water in collecting but not moving through cycles and draining
    Sergeant:
  • 229 Answers
No you need to clean out the spray nozzles with an old toothbrush etc both top and bottom and also clean out the debris filter below or at the heating element at the bottom of the washer. Then run a bottle of dryright etc. to help clean up the buildup in the machine. Then do this once or twice a year from now on and that washer should work great. Hope this helps.
Posted on Jan 18, 2009
I had the same problem I own a Kenmore Elite dishwasher. Diverter motor needs to be replaced. The diverter motor is connected to a plate that controls the flow of water to each washer arm. When the plate moves it has holes that align to the proper tube that supplies water to a washer arm. When the diverter motor is broken it is unable to rotate and cannot direct flow of water. When this happens water will only be able to come out of one spray arm in my case the back sprayer or turbo wash. The diverter motor is located under the dish washer and the diverter plate is located under the bottom sprayer arm.
Dec 01, 2011 | Kenmore Dishwashers
I have a LG LDF7810 WW. The bottom rack does not come clean any more. I pulled the sprayer arm and checked as manual suggested. Anything else?
Could be a bad VIRO motor. It moves a valve to change water flow between bottom spray arm and top spay arm about every 2 minutes of the wash cycle. You have to pull the dishwasher and lay it on it's back or side to change it, but you only need a phillips screwdriver.
Feb 07, 2011 | LG 24 in. LDF7810 Built-in Dishwasher
Arms are clogged
You may have debris in the sprayer arm jets. It is usually simple to remove the sprayer arms. Then rinse them well using the sink sprayer for forceful water power. I have sometimes had to use a tweezer to remove bits of plastic, paper, bone, or food particles. Once you've remove the debris, rinse well forcing water through to dislodge any other debris. Once you've reattached the sprayer arms, you should have cleaner dishes. Also, some brands of dishwashers have a pipe that runs up the inside back wall and connects to a pipe that runs under the top shelf. Water flowing through this pipe under the top shelf propels the sprayer arms. If the connection at the back is not flush with the "propel" pipe there won't be enough water pressure to turn the sprayer arm. Check to see if your dishwasher has this type of set up.
I hope this works. If it does, please let Fixya know by rating my solution.
Dec 04, 2010 | GE Dishwashers
LOW WASH PRESSURE ON UPPER SPRAY ARMS
Dec 04, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
The top section wont wash clean
Dec 04, 2010 | Maytag 24 in. MDB5651A Built-in Dishwasher
Water does not spray or circulate
Dec 02, 2010 | Asko D1776 Stainless Steel Built-in...
Machine runs but not cleaning dishes
Dec 02, 2010 | Maytag 24 in. MDBH950AWS Built-in...
Dishwasher fills up, but doesn't spray.
Dec 02, 2010 | Dishwashers
The spinner on top of the dishwasher, that I guess shoots out the water is not spinning. I think?
Dec 01, 2010 | Maytag 24 in. MDB3700 Built-in Dishwasher
Spray arms do not turn. water to them but not
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 23, 2009 | Bosch 24 in. SGS43C12 Classixx...
KitchenAid 24 in. KUDI02FRSS Stainless Steel Built-in Dishwasher Logo
340 people viewed this question
Top KitchenAid Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
