Sony DVD connect to RCA tv model rlded3258a-c, no sound
5 Suggested Answers
  • 10865 Answers
SOURCE: old tv, digital converter and dvd hook up?
connect the converter in connector to the antenna.
connect the converter out to the dvd in, and the dvd out to the tv in.
Posted on Jun 12, 2009
  • 290 Answers
SOURCE: my tv got no sound..but if connect a video/dvd via rca ok.
Sounds like you have a tuner or an antenna problem. If you are using a DVT converter box to watch off the air TV, the signal has to be very good to get sound and picture. Try connecting a VCR or a DVD player trough the coax cable and see if it you get sound an pic on Channel 3 or 4. If you do, it is an antenna problem.
Posted on Nov 30, 2009
BElectric
  • 1140 Answers
SOURCE: Have new sony dvd player
Hello prunefeet.
If you're certain you've connected the cables correctly, I think the part you may be missing is selecting the correct input on the TV. Switch the TV and DVD player on, then press the INPUT button on the RCA remote (supplied with the TV) slowly and repeatedly until you either get the setup/welcome screen from the Sony DVD player or you return to the TV channels again.
If you don't have the original RCA remote control or you cannot find the signal from the DVD player by pressing the INPUT button, please can you let me know the following:
1. How many jacks/plugs are there on each end of your RCA cables - 3 or 5?
2. Which remote control do you use to operate the TV?
Thanks,
BElectric
Posted on Mar 27, 2011
gopakumarg43
  • 75462 Answers
SOURCE: What is the code for RCA model RLDED3258A-B
082,091,057,029 are the codes to check. If you wish to get more setup codes, check this link. Pull up older posts there. Setup code list and proceedings to some popular brand remote controls are given.
Posted on Mar 02, 2013
Where can I find my RCA TV code?
If you have a universal remote, you can use its "code search" feature to find a code that will enable some or all of the functions of your RCA TV. If searching produces no result, your remote may not have one in which case you will have to try another remote.
Aug 01, 2014 | RCA Televison & Video
Mar 02, 2013 | RCA Televison & Video
I've tried connecting a Sony DVD player to my TV using Pb Pr V cables. I get a picture, but no sound.
The cable u are using it is the S-video cable?Yes,this cable dosen't support audio.Must used a RCA component cable like R,W cable connected between the tv and the DVD player to get sound.
Mar 14, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Have Sony KDL-40EX400 LCD TV, Sony STR-DH510 AV reciever, Sony DVP-NS57P dvd player. When connected to reciever using component connections the TV does not show a picture. I have seen this problem in a...
  • If I understand your question correctly you want to watch your DVD on your TV thru your receiver,
  • you need to connect either composite connections "Audio/Video Output " red/white/yellow RCA jacks or "Optic cable output" of your receiver
  • ( pls note that component to composite conversion is not possible on receiver ..use one type connection thru all the way )
  • to "Audio/Video input " red/white/yellow RCA jacks or "Optic Cable input" of your TV
  • than just switch to DVD mode on corresponding your RCA or Optic connection...
There you go..Your DVD sound and video both are on the TV..
  • Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Feb 06, 2011 | Sony DVP-NS57P
HOW TO SET UP SONY DVD PLAYER WITH HITACHI 42 LCD TV
Connect yellow video output on DVD player to yellow video input on TV using RCA cable. Connect white audio output on DVD player to white audio input on TV next to yellow. Connect red audio output on DVD (next to white) to red audio input on TV using RCA cable. Select on the TV using remote, the proper input for DVD player connection.
Aug 08, 2010 | Sony Televison & Video
No sound on my AVD-S10 CD/DVD reciever.
just check up your rca chord maybe loose connection or defective rca chord. in audio only
Jun 19, 2010 | Sony AVD-S10 DVD Player
Sony Model DAV ? SB 500W Home Theatre System
Please check at rear of TV for Digital Optical IN port as home theater should have optical out port at rear. If you got any optical in port in TV, just connect optical wire between TV and home theater.
2nd option is check Line Out pins at rear of home theater system, if found, hook red-white RCA cable there and put it to same input in TV where you hooked Video (composite or component) cable.
Let me know the results to help you more.
Jan 07, 2009 | Sony DAV-SB500W System
Connections for DVD Recorder/LCD TV/ SKY PLUS
Connect the AV output of the Sky box to the AV input of the Panasonic combo.Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the Sony tv. Power up Appliances, and you should be OK.
Apr 11, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Connecting receiver/dvd and vcr combo and TV
do u have rca outs form the tv to the aux in of any dvd system sterio unit
Jan 10, 2008 | Sony DAV-FC8 System
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
