Question about Wintergreen CMV CT-723A 17" LCD Monitor
No Video Whenever I turn on the monitor i get no video images. I do get the OSD (On Screen Display) Menu. Which shows me the Resolution/s of which the Pc video card is sending. If i switch resolutions in the Control Panel it shows that it has been Changed But still no video images. I checked to see if any pins were bent ..but.. one of them are. I tried this Monitor on numerous Computers with the same result/s. I am stumped. It is a lovely monitor.
  • 432 Answers
Did you take the monitor out and put it back in before the pin was bent? Or did it just all of a sudden blank out.
Posted on Jun 24, 2007
How do you adjust brightness on a Gateway ZX4971. There are no buttons on the monitor.
My Gateway monitor instructions refer to buttons located on the right side. The procedure calls for pressing the Auto button first to set the display image for the current screen resolution then pressing the Menu button to open the on-screen display (OSD) menu. You can move through the OSD menu to select parameters such as Picture (brightness).
Dec 18, 2014 | Gateway Computers & Internet
Tip
Troubleshooting Flat Panel Monitor issues. Screen is blank and power indicator...
Screen is blank and power indicator is off
The monitor is possibly not receiving power. Perform the following steps to fix the problem:
  1. Ensure that the electrical outlet and the monitor are both switched on.
  2. Check that the power cord is firmly plugged into the electrical outlet and the power supply unit.
  3. If the power cord has a removable fuse, replace it.
  4. Try another power cord.
  5. Try another electrical outlet.
  6. Check the power connection at the back of the panel.
Screen is blank and power indicator is steady green
Brightness and Contrast may be too low. Adjust the brightness and contrast using the On-screen display controls (OSD) by selecting the button
Screen is blank and power indicator is steady amber
The monitor is in the Power Management Standby state. The power management feature is invoked when the computer recognizes that you have not used your mouse or keyboard for a user-definable period. Perform the following steps to bring monitor out of the power management state:
  1. Press any key on the keyboard or move the mouse to restore operation.
  2. Check the Power Management software on your computer.
  3. flatpnlmont12.jpgPress the (OK) key to switch between analog and digital mode. If the panel is the wrong mode for the signal being provided, the monitor appears to go into sleep mode.
Screen is blank and power indicator is flashing green
Display mode of the computer is outside the range of the monitor. The display mode the monitor uses is controlled by your computer. Therefore, you should refer to your computer's documentation for details on how to change display modes.
The image size, position and shape may change when the display mode changes. This is normal and the image can be readjusted using the IMAGE SETUP and the monitor controls.
Note: Unlike CRT monitors, which requires a high refresh rate to minimize flicker, TFT technology is inherently flicker-free. If possible, configure your computer for 1600 x 1200 addressability at 60Hz vertical refresh rate.
Use the following table as a guideline and reconfigure your computer to use a supported display mode. The highest resolution (for example, 1600 x 1200) produces the optimal output, but limitations of your monitor may prohibit this setting. Adjust the addressability mode until an image appears.
CHECK SIGNAL CABLE" message is shown and power indicator is steady amber.
The monitor is not receiving a video signal. Perform the following steps to fix the problem:
  1. Check that the signal cable is firmly connected to your computer
  2. Check that no pins are bent in the signal cable connector.
There are noises in the video signal. The IMAGE SETUP function is used to adjust the level of noise in the video signal which causes horizontal lines or areas where the image appears to be unstable and jitters or shimmers. This can be done automatically or manually.
Note: It is not applicable to digital input.
Use the image setup fix the problem:
  1. flatpnlmont6.jpgSelect (Image Setup) menu in the OSD.
  2. Select Manual to adjust CLOCK/PHASE settings.
Image appears to be discolored
The color setting may be incorrect. Perform the following steps to adjust the color settings:
  1. flatpnlmont8.jpgSelect (Image Properties) from the OSD menu.
  2. flatpnlmont9.jpgSelect (Color Properties) to adjust the color mode you find most comfortable or fine tune the colors using the Custom menu.
A few dots are missing, discolored, or inappropriately lighted
A small number missing, discolored, or lighted dots may be present on the screen, which is an intrinsic characteristic of the TFT LCD technology and is not an LCD defect.
Using On-Screen display (OSD) controls
flatpnlmont12.jpgThe settings adjustable with the user controls are viewed through the OSD. Press the (OK) button to display the main OSD menu.
OSD main menu:
Note: The LCD monitor needs time to become thermally stable the first time you turn it on each day. Thus, to achieve more accurate adjustments for parameters, allow the LCD monitor to warm up (be on) for 15 minutes before making any screen adjustments
on Aug 08, 2010 | Televison & Video
Screen won't turn on
You can try to do the monitor self test.
Monitor Self Test:
1. Physically test the monitor autonomously from the computer.2. Switch both the monitor and the computer off, and then disconnect the VGA cable le from the computer.3. Turn the monitor on, pressing the power button for about three seconds. The self-test screen will come up .4. If the image is clear, bright, and shows red, green, and blue, the monitor is working properly. Video issues may be due to the video resolution in the computer, and not the monitor.5. If the image is not apparent and intense or the colors are not accurate, then the trouble is with the monitor or some of the (OSD) settings. In this case, test your particular monitor's information for OSD.
It is always important to check the color of your power light for so you can distinguish if the monitor is defective. Getting red lights on the the power panel states that the power section of the monitor is faulty.
Dec 03, 2011 | Emerson Televison & Video
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
DELL E153FPf doesn't show the image
OSD Warning Messages A warning message may appear on the screen indicating that the monitor is out of sync range.
Cannot Display This Video Mode
This means that the monitor cannot synchronize with the signal that it is receiving from the computer. Either the signal is too high or too low for the monitor to use. See Specifications for the Horizontal and Vertical frequency ranges addressable by this monitor. Recommended mode is 1024x768 @ 60Hz.
Occasionally, no warning message appears, but the screen is blank. This could also indicate that the monitor is not synchronizing with the computer or the monitor is in a power save mode.
Jan 18, 2010 | Dell E153FPf 15" TFT LCD Flat Panel...
Hi I've got a Samsung TFT monitor -Syncmaster 710V - that gives an error message.Message reads: Not optimum mode Recommended Mode: 1280 x 1024 60Hz This screen is impossible to get rid of. Anyone know the...
Try to change the desktop display settings, see screenshots below, see if it works
Right click on your destop and go to properties > settings
  1. Set your Screen resolution to 1280X1024
  2. Then click advanced and go to Monitor and set the refresh rate to 60 Hertz.
Dec 06, 2009 | Samsung 710V 17" LCD Monitor
I have a Dell monitor and the text is blurry and fuzzy, how do I fix this?
this is actually from dell support website.. hope it will correct your problem...
1 Ensure the correct resolution is set for the monitor. Flat panel monitors display the sharpest, clearest images when set to their optimal resolution. Sometimes games and other programs will change the resolution then fail to set it back once they are closed. This will then make the desktop look big, distorted, and grainy. Perform the following steps to adjust the resolution:
  1. Right-click an empty area of the desktop, and then click Properties. (Or, click Start, click Control Panel, and then double-click Display.)
  2. In the Display Properties window, click the Settings tab.
  3. Under Screen resolution, move the slider to the desired setting. For most flat panels the optimal setting will be all the way to the right.
  4. Click Apply, and then click OK.
  5. If prompted, restart the computer.
NOTE: If the resolution will not adjust to the appropriate settings, the video driver may need to be reinstalled or updated.
2 Ensure the screen is clean. Finger prints and smudges will make the screen look blurry. Clean the screen with a soft lint free cloth. If needed, dampen the cloth with warm water or use a LCD cleaning kit that can be purchased from most electronics stores.
3 Use the On Screen Display (OSD) on the monitor to select the Auto Adjust feature. Selecting this will synch the video signal and can sharpen the video image.
4 Reseat the video signal cable to ensure a secure connection.
5 Use the On Screen Display (OSD) on the monitor to select the Factory Reset feature.
6 Test the monitor on another computer or test another monitor on this computer. If available, testing different hardware will isolate if the problem stays with the computer or monitor
Sep 12, 2009 | Gateway FPD2275W LCD Monitor
I have a Westinghouse LCM-22W2 LCD monitor. I believe my power board is bad. I want to either replace the power board or bad capcitors, if I can find them. I do not know how to take off the back cover,...
Have you gone through the user's guide? There are some sleep settings and automatic adjustments that this monitor makes, and other changes that users have inadvertently triggered that seem to be causing quite a bit of confusion these days. Make sure you haven't overlooked the Troubleshooting steps outlined there:
Troubleshooting
No Power
• Make sure the AC cord is plugged into the back of the LCD monitor.
• Make sure the AC power cord is securely connected to an AC outlet.
• Plug another electrical device (like a radio) to the power outlet to verify that the
outlet is supplying the proper voltage.
No Screen Image
• Make sure monitor is turned on.
• Make sure the video cable is securely connected to both the monitor and PC or
Audio/Video apparatus.
• Make sure you have selected the correct video input source
• Adjust the brightness and contrast levels.
“Out Of Range”
• Restart your computer and adjust your desktop resolution and refresh rate to 1680 x
1050 at 60 Hz.
Fuzzy Image
• Set desktop resolution on your PC to 1680 x 1050 at 60 Hz.
• Adjust Phase/Sharpness setting on the monitor
Cannot find 1680 x 1050 under screen resolution on my Display Properties
• You may need to download and install the latest video card driver for your PC.
Listed below are websites for major video card manufacturers:
Nvidia: http://www.nvidia.com/content/drivers/drivers.asp
Intel: http://downloadfinder.intel.com/scripts-df/support_intel.asp
ATI: https://support.ati.com/ics/support/default.asp?deptID=894
Image Too Bright or Too Dark
• Adjust the brightness and contrast levels under the OSD menu.
• Perform Auto Adjust.
Distorted Image
• Reset the LCD monitor by performing the “Reset” function using the OSD.
• Remove extra accessories (such as a VGA extension cord).
Image is Not Centered (size is not scaled correctly)
• Adjust the horizontal and/or vertical position using the OSD.
• Check image size setting.
You can see an online version here: http://www.westinghousedigital.com./pdf/60_User_Manual.pdf
I do not know how to remove the cover from that monitor. Here is a link to Westinghouse customer service technical support: http://www.westinghousedigital.com./contactus.aspx or
Our service and support team is available:
Monday through Saturday
9 AM - 9 PM Eastern Time
1 (866) 287-5555
I hope this helps to resolve your issue.
Dec 07, 2008 | Westinghouse 22" Widescreen LCD Flat Panel...
First post is misleading...sorry..not one pin bent bb.but none were bent (typo) sorry
It could be the monitors invertor board has gone bad. Call a local computer shop and tell them you need a new invertor board for your monitor and see what they say. Write me back and let me know.
Jun 25, 2007 | Wintergreen CMV CT-723A 17" LCD Monitor
Wintergreen CMV CT-723A 17" LCD Monitor Logo
74 people viewed this question
Top Wintergreen Computers & Internet Experts
David Payne
David Payne
Are you a Wintergreen Computer and Internet Expert? Answer questions, earn points and help others
