Question about Kenmore Oasis HE 27087
F1 comes on 2to3 times a wash
I lift the lid re-start then it finishes. what a big pain in the behind!
  • 119 Answers
CHECK THESE:
lid flashes when the following conditions occur:
➔ User presses START with lid open.
➔ User presses START after 2 consecutive machine cycles
without opening lid.
➔ The machine/motor control cannot detect the lid switch
opening and closing properly.
BOYNISMO@YAHOO.COM
Posted on Jul 07, 2009
LG Tromm front load washing machine WM2688HNM, does lid on this washer remove differently from other LGs? Trying but won't budge HELP SOS!! How do I remove lid to get to inner works of this machine?
You need to remove the front panel there’s 2 screws behind that panel once you remove those screws the top from the front push it towards the back and slide it up at the same time
Nov 18, 2017 | LG Washing Machines
WHy won't my washer finish its cycle?
check lid switch first, this is most common.(machine thinks lid is open), carefully lift and lower lid an you should here a faint click. otherwise i hit some timer issues but not so common. there is no reset, the model you gave comes back as electro-mechanical and not electronic
May 10, 2014 | Maytag MAT12PD Top Load Washer
F1 comes up and it stop on the rinse wash cycle also how do you take the top off to get to the basket?
F1 is the board not communicating with the motor, almost all the F1 codes i have come across have resulted in a replacement of the board. But to answer your question, you will need a putty knife or flat head screwdriver. Slide it into the crack in the top front of the machine approx. 2 inches from the right side, you will be pushing the lid clip. Once you push it in you can lift one side up. Repaet on the opposit side and it should lift right up. Be sure to tape the lid shut so it does not come flying open when you lift the top.
Thanks, Repairman45
Dec 19, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Flashing F1 code, how do I fix
F1 code is water leaking. 1- Dry out the bottom housing to make the F1 disappear. 2- Replace Actuators and the lid seal to prevent this happens again. The actuators is pulling down from the left and right sides to hold the top lid against the top surface of the tube groove to seal water from coming out during the wash cycle. When actuators are bad, they can not hold the lid down or make the lid tilted to one side hence the leak is coming. When the lid is tilted for a long time the seal is distorted then it has to be replaced since it is out of tube groove shape
Dec 11, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
My kenmore washing machine will not enter into the last cycle and will not rinse out. Silly as it may seem banging on top of the machine with the lid closed sometimes gets the machine to start again and...
Hi, check lid switch, open lid, check carefully locate lid switch, or lift top of machine, get access to lid switch, could be broken or faulty, also check all wiring harnesses, there could be loose connection, check timer connections, all other connection, but first check your lid switch. when you lift lid, look for small slot, on machine around area lid covers, use something to press and release lid switch, preferable something non conductive, i use a small screwdriver. it could be just broken / faulty lid switch, or loose connection, you can check yourself, or let someone check for you, that's no big deal, always switch off power, before doing any repairs. good luck.
Aug 13, 2009 | Washing Machines
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Whirlpool cabrio top loader,always having to "reset" 2 times 1 cy
Hi Curtis: File a class-action suit against the Whirlpool company. There is something wrong with the electronic module that tells the washer to shut down during the rinse cycle.
If you pause, lift the lid, pour in about 3 gallons of water into the tub, close the lid, push start, the washer should continue without having to wear out your fingers pushing the buttons. The buttons will eventually be pushed down into the control panel and you will have to use a pencil to reach them.
Also helps to have a nice cool bottle of regular beer (not the light stuff) before you start the load, the washing duty will work out much smoother. Good Luck.
Dec 29, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer stops with an F1 Code during rinse cycles.
Well I have the same problem the only way I have found that my washer works is that on the soiler level make sure you put that on the heavy. And that should work I know its a pain but thats what I do and my washer washs with out stopping
Dec 04, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 CODE COMES ON AFTER LID LOCK
THE PRINTED CIRCUIT BOARD IS BAD. I DO NOT BLAME SEARS FOR THIS I SHOULD OF HAD A SURGE PROCTECTOR ON THE MACHINE. THIS MISTAKE COST $175.00. SO LIVE AND LEARN
Mar 30, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Kenmore Oasis HE 27087 Logo
69 people viewed this question
Sal De
fordexpert
Robert Rankin
