Question about Thermasol Signature Series Control Package, Contemporary, ThermaSol
Ttmpl error code thermasol steam generator
Does the unit need to be fixed by the factory with this error code?
5 Suggested Answers
  • 105 Answers
SOURCE: Unit not working - don't know how to remove
this unit is hooked into your plumbing system via a water line from either the hot or cold,...there will (should) be a shut-off valve to this steam unit that is either on or off,..it doesn't have to be off because the water doesn't run through it unless it is turned on. How it works is water runs into it, gets turned into steam and sent up to (i presume) your shower module. The reason for the long wait for hot water is that your hot water maker is a longway from your bathroom,...that water is traveling a long way to get to your bath,...common problem,....you can get whats called a "recirculating hot water line" installed,..simply another water pipe gets installed parallel to your existing hot water line, connect it into the existing hot line as close as you can get to your bathroom, put a little pump in line, and wah lah you have hot water circulating in that now "loop" so when you turn on tap, the hot water is closer,....removing the steem unit is easy but have a pro-electrician do it because these units are usually 220 volts and thats the one that'll kill ya if you touch it wrong, whereas 115 volts just makes ya jump.
Posted on Jan 06, 2010
SOURCE: LCD shows TTMPL and steamer doesn't work.
Funny, mine starting displaying the same thing around the same time. I contacted Thermasol and apparently the temperature sensor in the generator unit is malfunctioning and needs to be replaced. They're sending one to me, i'll let you know if it works.
Posted on Jan 19, 2010
SOURCE: TTMPL code showing on my Signature series control panel. ???
I have a Thermasol steam generator which had the error code TTMPL and it had to be replaced by the manufacturer. From memory, the error code might stand for "tank temperature monitor pressure low" or something similar. As an aside, the replacement generator just started to show the same error message -- so now I'm two for two -- and not entirely happy.
Posted on Apr 27, 2010
  • 7 Answers
SOURCE: hi, I have a 2
This sounds like you may have some calcium build up in the water feeder or level switch. You can call our tech support at 800-776-0711 and they can help you with the next step to get this problem solved.
Posted on Feb 01, 2011
Light flashing no steam
Please call Thermasol tech support at 800-776-0711 and our techs will gladly help you out.
Jul 06, 2010 | Thermasol Steam Bath Generators - Ambiance...
I have an old thermasol steam unit 84 salvaged from a bath reno. there is a check valve on one pipe and a union fitting on the other. unfamiliar territory, how do i hook it up and what potential problems...
Check valve is the cold water inlet---valve keeps water from siphoning back out causing unit to boil dry. Probably is quite a bit of lime inside from "hard" water
Feb 06, 2010 | Thermasol Steam Bath Generators - Ambiance...
The steam shower reads ttmpl
This is a temp sensor low or disconnected contact Thermasol at 800-776-0711 and our tech support team can help you out.
Feb 02, 2010 | Thermasol Steam Bath Generators - Ambiance...
Jan 16, 2010 | Thermasol Steam Bath Generators - Ambiance...
LCD shows TTMPL and steamer doesn't work. The model is SET-NTS-SN of Thermasol Signature series.
Dec 14, 2009 | Thermasol Signature Series Control...
Steam generator will not activate- thermasol model ASD300A
how do you know the unit has power?
what control do you have?
does it light up.
Mar 15, 2009 | Thermasol Steamshower Generator AF Series...
Thermasol steam generator constanly taking on water
the water feeder leaking and you will need a new one call 800 776 0711
Feb 06, 2009 | Thermasol Steamshower Generator AF Series...
Thermasol Error 5
call tech department 800 776 0711
Jan 16, 2009 | Thermasol Steamshower Generator AF Series...
Thermasol model 140 does not produce steam
call 1-800-776-0711 and get a EVA# to send unit in for repair.
Jan 10, 2009 | Thermasol Steamshower Generator AF Series...
Thermasol Signature Series Control Package, Contemporary, ThermaSol Logo
Top Thermasol Electrical Supplies Experts
Steve
Gene Haynes
Are you a Thermasol Electrical Supply Expert? Answer questions, earn points and help others
