Question about SanDisk Sansa e260 MP3 Player
What can i do is it frozen or what?
I turn it on and i only get the dial blue light no image nor sound what can i do? i tried plugging it to computer and to the outlet and still only get the blue light of the dial after a while the light turns off I do not see any instructions in the manual. Thanks for your help Isabel
Thanks I jsut held the power button down and the middle button for like 7 seconds and it worked
Posted on Jun 29, 2007
Yes mine had the same problem except I didn't even get the blue light. But I just held the power button down for about 20 seconds and it worked agian! good luck
Posted on Jun 27, 2007
I contacted sandisk and they provided a very complicated solution which includes downloading a file ( http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe ) taking the battery out for 5 minutes and pressing the record button with the hold.... I think it worked for me Check their page and write about the problem they are very friendly you can also call them on a 0800 number for your country https://www.customernation.com
Posted on Jun 26, 2007
You can reset it by holding the 'power' button down for 15 seconds just in case you were wondering.
  • 85 Answers
Try to restart it and or reboot it you can also let the battery drain completely before you try the first two things. If it does not work, perhaps it is the motherboard that is the problem. Thank you, Connie
Posted on Jun 25, 2007
My toshiba at200 table 10.1 wont turn on
1. When you press the power button to turn it on, do you see any thing on screen, like the toshiba boot up screen or something like that. Or is it completely blank (black color) always.
2. Can you see a faint image of your desktop (try to see it in dark place with flash light). This is important to confirm.
3. Also, when you press power button, do you see the LED lights on laptop blinking or solid green (which ones are in blinking/solid) and do hear any sound ? Or do you feel that your laptop doesnt even try to boot.
4. Can you hear any Beeps when you try to turn on the computer. If yes, what is the sequence of those beeps.
Continued......
If you answers are -
1.
blank
2.
no image
3.
only the satellite light is blue, the powercord is blue and the battery is blue
4.
no noise
Please do the following carefully and let me know result :
1. Shutdown and Unplug your laptop.
2. Remove the battery from the laptop.
3. Wait 2-3 minutes
4. Now press ON (power button on laptop) for 1 minute
5. Then release the finger and wait one more minute.
6. Now plug in the power cable (dont insert battery yet) and press ON button.
7. Did your screen start working now ? (do you see windows loading)
Jan 04, 2015 | Video Game Consoles & Games
Samsung syncmaster 2220 blinking blue light and no image display
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 26, 2014 | Samsung SyncMaster 2220WM 22" LCD Monitor
How to adjust pressure on resmed s9
I think you are talking the the RESMED S9 CPAP Machine. If so,
1.Press the Setup button and the Push Dial (see first image below) for 3 seconds.
2. Turn the Push Dial until you see the Options Screen (see second image below).
3. Press the Push Dial once to select the Option Screen.
4. Turn the Push Dial until Set Pressure is highlighted in blue.
5. Press the Push Dial once. The highlight should now be orange.
6. Press the Push Dial once. The selection should change from orange to blue.
7. If finished, turn the Push Dial until <8. Done!
Jan 29, 2013 | Health & Beauty
On this timer is the light color of time Day and the blue cover on time for night?
You posted under GE 7-day random vacation timer.
This timer shows 7 days of the week.
The nighttime hours are white with blue background.
Daytime hours are blue with white background.
Timer dial rotates clockwise, and make 1 revolution each week.
To set timer, manually rotate dial until current day and hour line up with 'time now' pointer.
Move slide switch to TIMER ON.
Timer randomly turns on-off at preset times.
To watch timer in action: turn lamp ON, plug lamp into timer, plug timer into outlet, and then manually rotate dial clockwise several rotations and watch lamp turn on-off.
http://waterheatertimer.org/images/GE%2050462%207-Day%20Random%20Vacation%20Timer.jpg
http://waterheatertimer.org/GE-timers-and-manuals.html#50462
Aug 13, 2011 | GE 50462 7Day Random Vacation Timer
No picture no sound loud humming sound for a short period when you turn it on than a orange light flashing at bottom where the blue light is when you turn it on.
AV cables reversed perhaps. Sounds like VIDEO (Yellow, Green, Blue or Red) cable is plugged into the AUDIO section. Perhaps you have switched the RED (Left audio) cable plugged into the RED (Component) Video cables. This would account for the loud buzz and since the set isn't getting an image it goes into standby mode. Just a thought.
Nov 25, 2010 | HP Pavilion MD5020N 50" DLP HDTV
Blue light comes on and then clicks off after a
it sounds like a virus or error on the mainframe although it could be your battery try taking your battery out and then plugging it into the mains. then turn it on without the battery in but still plugged in to the mains there may be sumthing wrong with ur batter
Mar 03, 2010 | Packard Bell Easy One Silver 2120 Notebook
Samsung Syncmaster 205BW power button lights up image will appear
Hold down the power button and the auto button. if that doesn't work try the power button and the source button.
Jun 24, 2017 | Samsung SyncMaster 213T 21.3" LCD Monitor
Frozen
http://www.sansa.com/support/sansa_e200/faqs
Question 9 from the Sansa FAQs gives these instructions:
Applies to the following Operating Systems:
  1. Windows XP, Vista
The player might have a power glitch. As a result, it does not turn on and is not being detected by the computer.
STEP1 - Reset the player
  1. Hold down the Power button for 20 seconds, then release.
  2. Run the hotfix.
STEP2 - Connect the player to the computer
  1. Connect the device to the computer
  2. Once the device responds, disconnect, and turn it on.
Jan 05, 2009 | SanDisk Sansa e250 MP3 Player
Hp1903 blank screen
power shortage maybe...try to plug your monitor on the other power supply,,be sure that your monitor is compatible on the voltage it required..
Aug 04, 2008 | HP vs19 (Silver) 19" LCD Monitor
SanDisk Sansa e260 MP3 Player Logo
74 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
