Question about Yamaha YG6600DE Generator
Yamaha yg6600de does not work
Generator started smoking and does not generate electricity
FRANKSFIXIT
  • 72 Answers
SOURCE: conversion of Yamaha gasoline electricazl generator engine to natural gas
My answer:
Hello Bill:
Here are the site links you'll need to check and/or get info, or buy your adapter kit for your Yami YG4600D Genset conversion kit.
Most likely it's running an 8 or 10HP engine on it now? In any case it's most likely less then 12HP. Not sure what size engine you have, as you didn't say only for the model #? On older Gensets it's harder to track down the HP rated engine is all.
For your Yami YG4600D Genset there you most likely will have your choice of at least 4 adapter kits depending on if you are going to keep gasoline as an option. If you're definitely NOT going to be ever running gasoline again then there are 1 or 2 adapter kits to choose from.
Use the site links below, and then browse whichever area you want as there are many options there. The last link listed takes you through all the different engines by make & model #'s.
I would also shop around locally where you are in LA, as you might be able to get that adapter kit for a lot less then the $227 to $267 they are asking for there at that site.
If you don't see your exact model # (or kit) there call them on their 800 toll free # listed at their site.
Also - if this site doesn't meet your expectations customer service wise at least you will have a starting off point with the wealth of information supplied there!
http://www.propane-generators.com/what_kit_do_i_need.htm
"What Kit Do I Need?"
http://www.propane-generators.com/simple_explanation.htm
"Simple Explanation"
http://www.propane-generators.com/a-c_kit_list.htm
A and C Kit List
Please post me a reply as to this info helping you solve your adapter kit problem there by following my posting recommendations above. Also please rate my troubleshooting fix as well.
Keep me posted and I'll follow up as well.
Best regards,
Frank
Posted on Sep 07, 2008
FRANKSFIXIT
  • 72 Answers
SOURCE: Yamaha Generator YG4600D
My answer:
Hello Bill:
A and C Kit List
Best regards,
Frank
SOURCE: Yamaha ef1000 will only idle and produce 12 vac
Hi, I have the same generator and I pull the load and it is fine. The engine RPM is controlled by the
governor. The voltage will not come up until the RPM is at full. First see what the RPM problem is and then check the voltage. Open the cover and look to see if the carb linkage is hooked up , if it is you mite have carb problem and address that first. Hope that helps.
Posted on Dec 19, 2008
rwvanlue
  • 486 Answers
SOURCE: Yamaha ef2400is generator needs some choke to run
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your local lawn & garden dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
Posted on Dec 04, 2009
  • 142 Answers
SOURCE: My yamaha generator yg6600de will run good for 2
Did you check oil level.
The low oil level protection may have stopped it.
Posted on Jul 01, 2010
I have a yamaha yg6600de generator when you hook up the battery the starter starts to crank the engine ?
Start by checking the Ignition switch, to begin with. It should not be getting power to the starter motor if it is in the off or on position, only in the start position. It should not be getting power to the starter motor if it is in the of or on position, only in the start position.
If that tests OK, then check wiring behind the control panel.
If you need parts you can find them on this page: https://www.generatorguru.com/yg6600d-yg6600de/
If you need any further help please let us know. :)
Oct 04, 2016 | Yamaha YG6600DEJ 6600 Watt Industrial...
Valve sticks. Runs for less than a minute and then shuts down.
Ed,
We would love to help you out!
First,check the oil level is to the very top of the filler as these have an automatic shut off if the oil gets too low. They like to be filled to the very top of the filler hole. Try running it, if it still shuts down let us know and we will assign an Engineer to your case. :)
http://www.generatorguru.com/ask-the-guru/
May 11, 2016 | Yamaha YG6600DE Generator
Yamaha re2500 no oil flowing to valve train?
my yamaha generator will not start/electric) it's dead. is there a fuse on these
Nov 30, 2010 | Yamaha 2500 Watt Industrial Inverter...
3000 watt yamaha generator is really hard to start and when started it stalls under load.
sounds like the carberator needs cleaning and the linkage that makes it open up under load. it works off the flywheel. a lot of generator problems are gas related. water, trash and varnish build up in the carb.
Aug 25, 2010 | Yamaha 4500 Watt Electric Start Generator...
Can you help me? I have generator yamaha ef 2600. Generator normally running about 3 minutes then rpm comes unsteady and gen stops. Moreover at load 2kW gen immediatly works unsteady and stops. Without...
As you describe the problem, the reason is unstable load handling.
This means that the fuel or air is not enough.
When begin to be unsteady:
  1. If smoke comes out of muffler - the input air is not sufficient. Try to clean or change air filter (cleaner).
  2. If no smoke, the fuel is not enough. The reason may be the mechanical governor, or the fuel supply to it, fuel filter/strainer etc.
Aug 05, 2010 | Yamaha 2300 Watt Generator - EF2600
Yamaha ef1000is was rained on, starts and runs after unplugging wire plug from generator, runs when replugged, but no electrical output
Sounds like the rectifier got fried. Moisture in these units is a dangerous thing. Even if you feel the unit sat long enough to dry ouit, it sometines will hold moisture in the electrical componants.
Jan 15, 2010 | Yamaha 1,000 Watt Portable Generator...
Generator stopped producing electricity
if the generator has been sitting for a while you might have to excite the magnets to start producing power. plug in a reversible drill and with the generator running turn the drill in the reverse direction by hand while holding the trigger in the forward position.
Mar 24, 2009 | Yamaha 4500 Watt Electric Start Generator...
Yamaha YG6600DE Generator Logo
52 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Dusty Ryan
Level 1 Expert
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
