Question about Nintendo Wii U
Cannot update wii u
Screen states connection to Internet is successful. But keep on getting error code 105-4400 when updating.
  • 3 Answers
I had the same problem so I moved my unit close to my router and it worked. although still took over an hour it did finally work. also downloaded a game, that took 4hrs. won't do that again.
Posted on Jan 07, 2013
    Problem Solver:
  • 16 Answers
Supposedly there was a patch for this problem, but if you keep getting the error, try this http://howtofixstuff.blogspot.ca/2013/09/how-to-fix-wii-u-error-code-105.html
Posted on Sep 19, 2013
jyackle5
  • 8197 Answers
SOURCE: Whilst trying to update our Wii error code 32007
Here is what the code means. I got the same code last night with my sons I had to move the wii closer to roughter to work.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=32007&system=Wii&locale=en_US
Good Luck and please rate
Posted on Mar 25, 2009
SOURCE: i cant get my wii to do a system update.
The main reason this error will occur, is Nintendo's update servers are overloaded, and in this case you can just try again later. If you changed settings on a wireless router, such as the channel it broadcasts on, it may not like the Wii, and also cause this error. Other solutions can be located at Nintendo's support website. Direct link to your problem: http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=32007&system=Wii&locale=en_US
Posted on Dec 10, 2008
  • 51 Answers
SOURCE: error messages when updating Wii with my wireless connection
It sounds like your Wii is not getting a strong signal. Go to your internet settings and perform a connection test and check your signal.
Posted on Jul 28, 2009
sanjuro77
  • 62 Answers
SOURCE: remove error code 32017 on wii
Usually this means the Nintendo servers are busy. You can try again later. If that doesn't work, try moving the Wii to a place where it can get a better internet connection.
Posted on Jul 22, 2010
SOURCE: I am trying to update my wii so i can get netflix.
If you get an error code of 32002 on you Wii console, this indicates a problem with your Wii communicating with your wireless router.
There are a couple things you can try/check to help fix this problem:
1.Try using a different channel on your router and update your Wii to take to the router on that channel.
2.If your router is using WEP (encryption), make sure your Wii is set to the same encryption.
3.Make sure the MTU values on your router match those entered on your Wii.
Also note that if you make changes to your wireless router and you have a computer that uses that router too, you'll need to update your computer to match the new settings on your router.
Posted on Feb 03, 2011
Undefined
From the Wii main menu, use the Wii Remote to select the "Wii" button.
Now, select "Wii Settings" to access the "Wii System Settings" menu.
Using the arrow on the right side of the screen, scroll to page two and select "Internet."
Select "Connection Settings."
Select "Connection 1: None"
(Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.")
Click on "Wireless Connection" and then "Search for an Access Point."
Select "OK" and the Wii will display all the wireless networks it finds.
Select the wireless network that is yours.
Asked to enter a security key?
If you are prompted to "Enter the Password or Key," then the wireless network you are trying to connect to has wireless security turned on. You will need to type in your security key or password and select "OK."
  1. Select "OK," "Save Settings," and then "Yes."
    • The Wii console will run a connection test with your wireless network.
  • As long as you see "The connection test was successful," the "Wii Support Code" does not matter and can be ignored.
  • The connection test was successful - Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates.
  • The connection test was not successful - If the test was not successful, you will receive an error code.
    • Error Code 51330: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again.
For detailed step by step instructions with pictures use this link: http://www.nintendo.com/consumer/systems/wii/en_na/netflix.jsp?menu=watch&submenu=rvl-ht-sys-internet-connect
Apr 23, 2013 | Nintendo Wii Video Game Consoles & Games
Error code 32004
we need to start from square one... let's do this
Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
(Are you using a wired Internet connection to your Wii console?
The Wii console will run a connection test with your wireless network when the test is completed. You should see the following screen:
The connection test was successful - Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates. Click here to find out what's next!
Error Code 51330 or 52130: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again.
As a last resort... 1. reset your router or 2. temporarily remove the password from your router... this way you will know where the problems lies.
Thanks
Feb 24, 2012 | Nintendo Wii Console
Trying to hook it with netflix keeps giving me an error code 51420
  1. From the Wii's main menu, select the Wii icon along the bottom left of the screen.
  2. Select "Wii Settings".
  3. Click the left arrow to get to Wii System Settings 3
  4. Choose "Wii System Update"
  5. Choose "Yes" to connect to the internet and perform a Wii system update.
This should remove the error and allow you to watch Netflix.
Jul 23, 2011 | Nintendo Wii Console
Error code 51331. unable to connect to internet. choose internet settings and then cofirm your connection.
(Are you using a wired Internet connection to your Wii console? If so, click here for specific help.)
(If you're not sure which is yours, or you don't see any wireless networks, click here.)
Don't know your router's security key?
Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand!
Linksys Netgear DLink
Belkin Apple 2Wire
All other brands
Error Code 51330 or 52130: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again. Please refer to step seven (7) above for more information.
All other error codes: Try our error code troubleshooting where we have detailed information on many common error codes. (You can ignore any "Wii Support Code" you receive on a connection test.)
Jun 28, 2011 | Video Game Consoles & Games
Trying to connect my WII council to the internet and it keeps coming up "Unable to connect to the internet Error code: 50230"
Error code 50230 is thrown when the Wii's internet connection has not yet been configured. These instructions on configuring the connection settings come from Nintendo's website at:
http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
  1. Power on your Wii console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button.
  2. Now, select "Wii Settings" to access the "Wii System Settings" menu.
  3. Using the arrow on the right side of the screen, scroll to page two and select "Internet."
  4. Select "Connection 1: None"
  5. Click on "Wireless Connection" and then "Search for an Access Point."
  6. Select "OK" and the Wii will display all the wireless networks it finds.
  7. Select the wireless network that is yours.
  8. Asked to enter a security key? If you are prompted to "Enter the Password or Key," then the wireless network you are trying to connect to has wireless security turned on. You will need to type in your security key or password and select "OK." secureaccess.png Don't know your router's security key? Let us help you find your router's security key. Select the brand of your router below and we'll provide you with the default information for that brand! Linksys Netgear DLink Belkin Apple 2Wire All other brands
  9. Select "OK," "Save Settings," and then "Yes."
    • The Wii console will run a connection test with your wireless network when the test is completed. You should see the following screen:
    • The connection test was successful - Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates. Click here to find out what's next!
      • Error Code 51330 or 52130: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again. Please refer to step seven (7) above for more information.
      • All other error codes: Try our error code troubleshooting where we have detailed information on many common error codes. (You can ignore any "Wii Support Code" you receive on a connection test.)
May 07, 2011 | Nintendo Wii Console
Just got internet and want to get wii online
How to connect your Wii to the Internet Let's get you connected!
      • All other error codes: Visit the nintendo website for more information on this where we have detailed information on many common error codes. (You can ignore any "Wii Support Code" you receive on a connection test.). Hope this was helpful? Please comment for more information and thank you for using FixYa.
Apr 04, 2011 | Video Game Consoles & Games
How do i set up my new dsi to the internet
Power on your console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button. Now, select "Wii Settings" to access the "Wii System Settings" menu. Using the arrow on the right side of the screen, scroll to page two and select "Internet." SELECT CONNECTION ONE NONE (Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.") Click on "Wireless Connection" and then "Search for an Access Point (Are you using a wired Internet connection to your Wii console? If so, click here for specific help.) Select "OK" and the Wii will display all the wireless networks it finds. (If you're not sure which is yours, or you don't see any wireless networks, click here. Select "OK," "Save Settings," and then "Yes." The Wii console will run a connection test with your wireless network when the test is completed. You should see the following screen: As long as you see "The connection test was successful," the "Wii Support Code" does not matter and can be ignored The connection test was successful - Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates. Click here to find out what's next! The connection test was not successful - If the test was not successful, you will receive an error code. Error Code 51330 or 52130: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again. Please refer to step seven (7) above for more information. All other error codes: Try our error code troubleshooting where we have detailed information on many common error codes. (You can ignore any "Wii Support Code" you receive on a connection test.
Jan 30, 2011 | Nintendo Dsi Pink Console
I cannot get on the internet thru my tv and wii
Jan 26, 2011 | Nintendo Wii Console
How do i get internet on the wii
Jan 23, 2011 | Nintendo Video Game Consoles & Games
52030 error message when trying to hook to the internet
Jan 23, 2011 | Nintendo Wii Console
Nintendo Wii U Logo
1,133 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
