Question about Asko Washing Machines
Detergent compartment of Asko W6342 fills up with water after every wash
ginko
  • 19396 Answers
SOURCE: Kenmore HE 4t Elite Front Loader Washing Machine
Inside the dispenser drawer, at the bottom there is a tab that you can push down to remove the dispenser drawer. Remove the drawer and check if the dispenser holes are clogged, this is a common cause.
Posted on Mar 22, 2008
  • 417 Answers
SOURCE: asko washing machine w6342 showing f3 and cant open door or operate?
Make sure the programme selector switch is at an end of wash position as these door locks are interlocked to prevent accidental opening during operation. There is also a 2-3 minute time delay after the was finishes so disconnect for say 5 minutes and try again.
If it still doesn't open you will need to get access to the mechanism dependent on what type of relrase mechanism you have;
if it is a push button release with a cable to the lock sometimes you can remove the top panel of the machine and pull on the cable or linkage to open.
If it is a lever type release mechanism this is more difficult to open but you can sometimes reach and release it by the same method.
Always disconnect the machine from the electricity supply before working on it.
Posted on Oct 13, 2008
barkencoa
  • 3463 Answers
SOURCE: Detergent dispenser is filled with water after wash is completed.
The water is left there because the syphon action is not working in the dispenser, what you need to do is to remove the dispenser drawer completely and thoroughly clean the conditioner compartment, poking any holes or tube, particularly the syphon tube with a piece of flexible wire or similar to ensure it is completely unblocked.
. to test, fill the conditioner compartment with water, and it should slowly empty itself, if it does not, then it is still blocked.
Plz rate this solution.Thanks.
Posted on Dec 27, 2008
  • 57 Answers
SOURCE: Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Posted on Oct 10, 2009
keithd2704
  • 56 Answers
SOURCE: The Softener is not going through.
Hey Ben Fixit,
Depending on what unit of Nexxt 500, not all of them have a slide out soap box. The unit I have of the Nexxt 500 series only has an access lid that lifts up.
To address the blockage on this style of machine, a user can start with a kettle of boiling water and slowly pour the water into the fabric softener well.
Remember fabric softener is made with plant fats and during the colder months can coagulate and clog the lines. This is due to the colder temperature of the water, especially if the user does not use hot water to wash all of their clothes.
Keith
Posted on May 31, 2010
My ASKO W6342 washing machine drum will not turn on any setting, it fills and drains fine but the drum does not turn during the cycle, however it is free to turn by hand, the belt from the motor is OK, I...
It seems a minor problem for me, but cannot say anything without checking your washing machine. You should better call washing machine repairer to fix this minor problem.
Mar 14, 2014 | Asko Washing Machines
Reset asko w6342
you do you know that you have to wait up to 3 min for some doors to open as there is a safety lock on them other than that check your door lock
Jan 27, 2014 | Washing Machines
Should I put powder detergent in the tray or in the drum in my Asko front load washer?
But the powder in the tray. I have a asko washer myself
You should to able to go on line and download your manual
Go to Asko.com Good Luck
Feb 12, 2013 | Asko W6461 Front Load Washer
The soap isn't emptying out of the compartment during the wash cycle. 1. We didn't load any items too close to the dispenser. 2. We didn't use the Rinse program, just main wash cycle. 3....
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Aug 01, 2011 | Asko 24 in. D3112 Free-Standing Dishwasher
Water remaining in fabric softener compartment of the detergent drawer after cycle is completed
There is a chance it might be clogged. Have you tried to unplug the washer and plug it back up to reset it?
Mar 03, 2011 | Asko W6461 Front Load Washer
Not getting enough water
hi yes it sound like the valve is faulty,or the tap.
Jun 08, 2010 | Asko W6221 Front Load Washer
Water leaking from deyergant compartment
Make sure these isn't any foreign objects in the tube that leads into the drum from the detergent tray.
Remove the top of the unit. 2 screws in the back. Top left and top right and slide the top off. Look under the tray and locate the tube and feel around. You may have to remove the tube to get a better look.
Dec 24, 2009 | Samsung WF218AN Front Load Washer
Dec 27, 2008 | Bosch Washing Machines
Water inlet valve problems
repairclinic.com has parts available.
Jul 31, 2008 | Asko W620
Washing Machines Logo
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
marley mcelhinney
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
