Question about Char-Broil Electric H2O Smoker
I have electric charbroil smoker and it keeps tripping breaker
SOURCE: need instruction manual for the smoker h20 chargrill
all I need is the instructions on the smoker h20 chargrill thats all
Posted on Jul 02, 2008
SOURCE: Tripping Circuit Breaker
Same problem I have. I think the element or thermostat is gone. You will have to replace them. Here are the part numbers repectively:
4501649
4160214
Posted on Jul 05, 2008
SOURCE: Tripping the electrical Breaker
I have used the charbroil bullet electric H2O smokers for years (wore 2 out - currently on my 3rd). I won't use anything else (having used many, many others - HOWEVER - as with every product made there are things to watch or overcome. Learn to use it properly and look forward to many years of great BBQ.
Ambient (outside) air temp below 70 (depending on wind also) will affect these smokers drastically - highly recomend getting or making a "smoker blanket" (got mine at cabelas years back - if you can't find one welding blankets from an industrial supply store can be made into one) to insulate the sides - this drastically reduces heat loss and reduces the electrical load.
Another MAJOR mistake many people make is extension cords - avoid the use of them at all if possible - if not possible then purchase the heaviest gauge you can find.
Always pre-heat your smoker - Always use boiling water (or other liquid) in the H2O pan added after smoker is pre-heated - Always minimize opening the smoker once cooking has begun.
The heater element can be cleaned when cold with a very mild detergent and room temp water.
If you have the large 2 rack but are only smoking enough to use a small amount of rack space on only one rack remember that you are heating a whole lot of air - i have a couple (different size) wood boxes wrapped in foil to take up excess air space - this means less air volume to be heated and better heat control - DO NOT use cardboard boxes or other low temp combustable items in the box construction!
Make sure the house outlet you are plugging into is a 3-prong GROUNDED outlet on a 20 amp breaker.
Finally, make sure your smoker is level and remember there can be up to a 20 degree cooking temp swing in temp between the bottom rack and top rack (top rack 5-20 degrees hotter than bottom).
The heater element will cycle on and off during normal use.
Good smoking and enjoy.
Posted on Nov 24, 2008
  • 16 Answers
SOURCE: i just got my charbroil offset smoker and i have
Use approximately 5 lbs of charcoal or a little more that a chimney charcoal starter and let it go grey and get your grill to the temp you are looking for then add the pecan on top of the charcoal in the fire box.
Posted on Apr 04, 2010
ChefBarry
  • 4 Answers
SOURCE: Trying to figure out how to use my charbroil h2o
You can get a free PDF manual at Char-Broil,com and you can also talk to other users at http://sizzleonthegrill.com/user-forums/ and I bet you get lot's of help there.
Posted on Jul 12, 2010
Cajun injector electric smoker stopped working
Check for power at your outlet; a tripped GFI or a tripped breaker in your panel box may be the cause if the outlet is dead. If the outlet is good then you know it is the electric smoker.
Nov 27, 2014 | Cajun Injector Double-Door Xl Electric...
Why does my electric grill trips my breaker
It appears your gfi may be rated for a lower current draw or it may be deffective. You could try changing your gfi to one that matches the 15 amps in your circuit. If this does not work you could try finding another plug around the house that has a higher rating. It would help if you knew the amount of amps your grill draws. Do not change the breaker to a higher rating. The wiring in your wall is matched to the capacity of your brakers and upgrading your breakers without changing your wiring to match the new rating could causes an electrical fire. If you are nor sure what to do contact an electrician.
Apr 01, 2012 | Char-Broil charbroil Patio Caddie Shelf,...
Eeaf smoker keeps tripping off
Hi sally mako...
Make sure your breaker is strong enough to handle the ampreage draw of the smoker element.
Try a different receptical with a known larger breaker...
If still kicks the breaker, then remove the electric plug from the receptical and check all connections on the element and controls to make sure they are not corroded or broken and shorting out.
Please take time to rate me
Sep 24, 2011 | Masterbuilt 20070106 Electric Smoker
I have a char-broil smoker. It's not electric, though. It's a charcoal outdoor grill. I need to know how to use it. Got it at a garage sale and forgot the instructions the seller gave me. Any...
I'm not sure this is the same model you have, but it's the only one Charbroil now makes. In any case, most vertical charcoal smokers work the same way.
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/06701289%20assembly%20manual.pdf
I hope this helps you. Enjoy your smoker and thanks for choosing FixYa.
Aug 16, 2011 | Char-Broil Electric H2O Smoker
Grill will not turn on
I assume you are referring to the auger motor. If so, have you checked the electric receptacle the g=auger motor is plugged into? Plug another electric appliance, like a lamp into the receptacle to see if the lamp works. If not, look for a tripped circuit breaker in your home's breaker panel. If one is tripped, make sure nothing is plugged into the offending receptacle and reset the breaker. Plug the auger motor back in to see if the breaker trips again. If does, there's an electrical issue with the auger motor or the cord.
If none of the above is the problem, i have included a link to Traeger Industries website. There you can find and download the Owners Manual for your Grill-Smoker, which also has a Trouble Shooting Section.
http://www.traegergrills.com/
Feb 21, 2011 | Traeger Industries BBQ070 All-in-One Grill...
Where can order electric cord for H20 Charbroil Smoker 10yrs old
any whitegoods store will have this type of cord, just check what brand not what year...
Jul 18, 2010 | Char-Broil Electric H2O Smoker
Electric smoker is now tripping GFCI breaker
GFCI breaker tend to wearout and become more sensitive after time and use. Motor loads are especially hard on them. Also resistance loads such as heating elements. Your smoker may be pulling a bit more electric than it used too.
Check the power draw of the smoker when operating, if it is high then fuigure out why. It it is normal then replace the braker. Use a regular breaker if the GFCI is not required, or run a cord from an outlet that is not on a GFCI breaker.
Heatman101
Jan 24, 2010 | Masterbuilt 20070106 Electric Smoker
4501649
4160214
May 27, 2008 | Char-Broil Electric H2O Smoker
Apr 28, 2008 | Char-Broil Electric H2O Smoker
Char-Broil Electric H2O Smoker Logo
Top Char-Broil Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dean Gruber
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
