Question about Canon MP610 Photo All-In-One Printer
Will not print from PC
Sets up, starts up, paper goes through unprinted
    President:
  • 2,692 Answers
Try the clean printhead routine directed in you manual.
Your Canon printer support page below:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13800
Posted on Jan 18, 2009
I am using Premium Kodak Photo Paper and selecting photo paper in the preferences which I have used successfully before, but have just started having trouble. It started by printing a dark band more than...
Hello. By the sound of it the paper is slowing down at the point were the dark band is. If you can pay close attention to the speed of the paper the entire print. If is appears to slow down, then feeds out correctly, there are two things to look for. The Paper could be sticking in the tray at that point or the rollers are loosing grip. It can also be a combination of both. Make sure no ink or dust has built up in the rollers and also make sure you dont overload the paper feed tray. This increases the bend of the paper through the rollers and can cause them to slip.
Other than this the rollers can be re-set or replaced but it is normally not economical to do so.
I hope this helps Regards GM
Apr 12, 2011 | HP DeskJet 952c InkJet Printer
How do you retrieve the old faxes? The paper wasnt in the right feed and a bunch of faxes came in and it never got through. I need to retrieve it.
? Printing All Unprinted Documents in Memory
1 Press [Menu].
2 Use [{] or [}] to select , then press [Start/Copy].
3 Use [{] or [}] to select .
4 Press [Start/Copy].
The fax prints the documents one at a time, after each the reception number is displayed on
the LCD.
5 After printing, the LCD displays .
6 Press [*] to delete the previous printed documents.
If you want to keep the documents in memory, press [#].
Jan 31, 2011 | Canon FAX JX200 Fax / copier Plain Paper...
Only right side of the page prints - help!
Marks repeatedly appear at even intervals on the unprinted side of the page.
c00366165.gif Internal parts might have toner on them. The problem typically corrects itself after a few more pages. The paper path might need cleaning. Click here to go to the Print Defect ruler for more information.
Clean the device. The imaging drum might be low. Click here to go to the Print Defect ruler for more information.
Replace the imaging drum. The fuser might be damaged. Click here to go to the Print Defect ruler for more information.
Contact HP Customer Care Marks repeatedly appear at even intervals on the unprinted side of the page.
Contact HP Customer Care hi at the link given below, click on it and locate the page (halfway down) where it states this
Contact HP Customer Carehttp://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=ca&taskId=110&prodSeriesId=445194&prodTypeId=18972&prodSeriesId=445194&objectID=c00366102
Nov 04, 2010 | HP LaserJet 2840 Printer
HP Color LaserJet CM1312nfi MFP printer leaves a 2 inch area unprinted using any programs. So basically it doesnt print the entire page.
turn on/off, unplug, plug in2_bing.gif, should reset configs.
take all the paper out, put half as much back in.
check the rollers to make sure no paper or particles are preventing printing
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above. HP has an awesome website for this type os trouble shooting
hope this helps and good luck
Apr 29, 2010 | HP Color LaserJet 2600n Printer
Epson R2400 letterhalf borderless printing
No Borderless option for custom paper sized. Borderless prints are only available for pre-define paper size like 8.5"x11", 4"x6", 5"x7", 8"x10", etc.
Jan 23, 2010 | Epson Stylus Photo R1800 InkJet Printer
Before the printer started printing, I removed the paper. Now it won't print. When I click on the open printer folder, it indicates the the printer is offline.
open printer folder hover over the printer icon right click it and click (use printer on line) also delete any spooled unprinted work by double clicking your printer icon, go to see whats printing, and delete them.
Oct 16, 2009 | HP PSC 1210v All-In-One InkJet Printer
THE PICTURES ARE NOT CENTERD ON THE PAPER THERE IS A WHITE BAND APROX 1/4 TO 3/4 OF AN INCH LEFT UNPRINTED
Try opening a picture and printing it, except instead of clicking OK to print, find the button that says preferences and check the setting there. Adjusting these settings should help square up the photo on the paper. You may also try using an option in there called Defaults that will print using default settings and that should print just like it did when you first got the printer.
Jun 06, 2009 | HP Photosmart D7360 All-In-One InkJet...
Printable area
hey did u have page set up .in file menu go through that ....
or u can go to format(icon)at the top in M.S office . go in boarder
& shading set frm there ....
Feb 19, 2008 | HP PSC 750 All-In-One InkJet Printer
Not printing full A3
Make sure the machine and the driver are set for A3 . Most likely the paper tray, or setting in the menu are not correct.
Or the driver paper size is not correct.
Jan 31, 2008 | Xerox DocuPrint C20 InkJet Printer
Hp psc 2410 photosmart
marglet, Turn-off and unplug the printer for a couple of minutes...there may be improper setting stuck in the printer memory. then plug it in and try to print the envelopes..if that doesn't work...Make sure there aren't any custom print settings causing this. Lastly...Try updating the drivers. Download the latest drivers from the site. http://www.shopping.hp.com/webapp/shopping/search/search_request.do?pageName=HP+printers_land Good Luck, Tim
Feb 03, 2007 | HP PSC 2410 All-In-One InkJet Printer
Canon MP610 Photo All-In-One Printer Logo
51 people viewed this question
old marine
old marine
