Question about GE Ovens
HOW MUCH TO REPLACE KEY PAD ON GE WALL OVEN MODEL JKP14WOP3WG
captaynkyrk
  • 170 Answers
SOURCE: replace oven ignitor for ge profile oven
If you go to this link: http://www.partselect.com. You can put in your make and model number in and get a diagram of your oven and see how it goes together. You can also order parts online, or at your local appliance parts store. Good luck!
Posted on Jul 20, 2008
SOURCE: top oven doesn't heat.
We had this same problem in our lower oven and found the solution the night before Thanksgiving. With 26 people coming for dinner, I desperately need both ovens. (Turn off the breaker for the oven before you do this.)
My husband took the control panel off of the upper oven and found a wiring diagram. In the text, it said there was a manual reset for each oven in the access panel for each one. He opened the access panel for the lower oven and found the reset button in the middle of that area. He said it was a black circle with a red button in the middle. After reseting, we turned the breaker back on and everything works great!!
Posted on Nov 27, 2008
dgjtex
  • 405 Answers
SOURCE: Install bake unit in GE wall oven model JKP07J
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
Posted on Dec 27, 2008
SOURCE: GE P7 Wall oven model JK1905AV only gets warm....
I have a pair I'm trying to get rid of if you're interested.
Posted on Aug 05, 2009
Testimonial: "thanks!"
  • 69 Answers
SOURCE: need instructions on my GE profile wall oven
GE.COM really helps
Posted on Sep 20, 2009
F7 code flashes on jenn aire 27 inch wall oven
The F7 code indicates that the touch pad either has a "stuck" or shorted key. Depending on the oven model, you either need to replace the touch pad or the controller (clock) and the touch pad. (Some Jenn Air appliances sell the two as one unit.)
Please add a comment with your model number to get additional information on the availability and price for the parts. (Parts may be available from a number of suppliers, including jenn-air.partselect.com.)
I hope this helps.
Mar 01, 2012 | Jenn-Air 27 in. Electric Single Wall Oven...
Tip
I get error F7 on GE oven.
Hi.
F7 on GE ovens means that there is a poor contact to keypad detected. When this happens the problem is either keypad or control panel.
Problem is fixed testing keypad and control assembly and replacing the faulty part.
Here the procedure to test the parts:
Hold down the CLEAR/OFF button on pad.
Disconnect the ribbon cable connecting control panel to pad and wait about one or two minutes to see if the code comes back.
If the code comes back, then you likely need to replace control assembly.
If the code does not re-appear on display, then the problem is with the key pad. In that case replace the key pad.
The procedure is only indicative. In case of faulty control assembly procedure may not be a definitive test. In that case replace the control pad first.
To find parts and diagrams for your appliance, enter the model number in the links listed below:
Where do I find parts and diagrams?
Regards.
on Aug 10, 2010 | GE Profile JTP18 Electric Single Oven
GE model #JTP18SDSS electric wall oven displays F-7 and will not work. Tried disconnecting for a few minutes --- still doesn't work.
this is a function pad is jammed or stuck.Recommend that you try to un stick the pad or replace the electronic control
Dec 31, 2010 | GE JKP15 Electric Single Oven
I have a GE Range model JBP85. I have an error code F7. It appears the clock key is stuck. Is there any way to unstick this or any other key? The key pad is expensive to replace.
Hi, Error F7 on your oven means that the keypad is shorted or stuck and to resolve this issue you'll have to replace the Electronic Range control (ERC).
Oct 23, 2010 | GE JTP15 Electric Single Oven
Error Code -F1- and Broken glass door
Welcome to fixya.com f- 1 is the electronic key pad a key is stuck and usually you will need to replace the key pad site to obtain parts is partsselect.com but before you do disconnect power to unit for 15 min then re connect power to see if unit reset its self. And at Parts select.com you can order the glass you need, Regards, Lee Davidian
Apr 19, 2010 | GE Profile JTP56 Electric Double Oven
I have a 24" single gas wall oven model JGRP17VEW4BB and it is displaying an F7 error code and the time. I've tried shutting off the power but it comes back right away. Do you know what part I will need...
HI. This is a basic communication issue that will concern, either the control board, or touch/Key pad assembly. Normally, this will produce a stuck key, which will cause one of the power relays to become suspended.
Determine if The problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting the key pad Ribbon Cable from control(main), and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
NOTE_ Some models incorporate the touch/Key pad into the ERC as a single assembly(Whole device), in which case this test is not necessary. Simply replace the ERC (Clock).
Jan 17, 2010 | GE JGRP17 Gas Single Oven
Ge profile wall oven - f7 but I fix with eraser trick - now the clock can't be reset and the 4 does not always work on the keypad
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
Aug 28, 2009 | GE Profile Advantium 30" Built-In Single...
The oven controls are not working. then FO shows
If your appliance is newer than 1996 F0 error code is a stuck key pad .
To verify turn off power and access the control panel and remove the ribbon connector that goes from key pad to control board .
Now restore power.
If the F0 code goes away you'll have to replace the key pad .
If it stays it means the control board is bad.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 11, 2009 | GE 30" Built-In Single Electric Convection...
Oven comes on for no reason followed by the start beep
yes you can kill the power and lock out the box with a pad lock for safety. the panel is attached by screws usually on the bottom of panel. lower and seperate the control panel ribbon from the erc (electronic range control). without removing any other components leave ribbon loose and replace panel. turn power back on. if the beeping does not recur, the control panel probably has a stuck key. if it does resume the erc is faulty
May 17, 2009 | GE JKP20 Electric Single Oven
F-7 code on wall oven .. bought in 2000
You have either a stuck key pad or a bad ERC(clock).
Try jiggling all buttons several times each.
If it does not correct your problem replace the electronic control.
Feb 27, 2009 | GE Profile JT952 Electric Double Oven
Ovens Logo
129 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
