Question about HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive
HP's USB port's being VERY picky
My zip drive works fine in my USB port(s), but NONE of my THREE usb ports detect my *MIDI CORD / KEYBOARD*. (I work with alot of music software, and the good ones won't work without a midi keyboard) My supercheap, school-issued IBM laptop had no problem with this, so I'm wondering if there's something extra that I have to do in order for my (older but better) *HP* to work with it...
iqbal_del
  • 655 Answers
SOURCE: USB port problems with hp printer
There are few things to remember using USB.
  • If your System is in hybernation mode, don't remove any attached USB device, because it will damage your USB driver. This is one of the known problem from microsoft.
  • If you have to remove any USB device use 'Safely Remove Hardware'.
To remove currepted USB drivers its not enough to remove your printer drivers.
  1. You should un-install the 'Universal Serial Bus Controllers' from Device Manager.
  2. Then re-boot to clean registry.
  3. Install the 'Universal Serial Bus Controllers' using XP Setup CD.
  4. Then check the Mass storage, PDA etc, it should recognized by XP.
  5. Then install printer driver (don't attach printer to system untill setup finish or setup says to connect).
I think it will fix.
Please let me know your feed-back.
Thanks
Iqbal
Posted on Apr 15, 2008
  • 119 Answers
SOURCE: Keyboard or motherboard?
Its your keyboard thats the problem because if it was you mboard or one of the tracks in the circutry is the keyboard connection panel you would have a problem using all the alphabetical keys because they are all connected to the same track.
Posted on Jul 05, 2008
muttandjeff
  • 359 Answers
SOURCE: usb ports on HP pavilion 5000 have shut down
SOUNDS LIKE YOU HAVE A CORRUPTED DRIVER OR HAVE LOST DRIVERS FOR USB PORT GO TO HP WEB SITE AND FIND YOUR COMPUTER AND DOWN LOAD DRIVER FOR THIS DEVICE AND SEE IF IT HELPS HAD TO DO ONE WITH LIKE PROBLEM RECENTLY , WORKED FOR ME
Posted on Jan 12, 2009
siawolf
  • 749 Answers
SOURCE: My USB ports no longer detect devices when plugged in.
Updating, or in some cases reinstalling, the drivers for your computer's USB interface should resolve this issue.
Locate the iPod in Device Manager
  1. Connect iPod to the computer.
  2. Quit iTunes if it launches.
  3. On the Start menu, click Control Panel.
  4. In Control Panel, open Administrative Tools. Note: If you don't see Administrative Tools, look at the left column in Control Panel for a link that says, "Switch to Classic View," and click it.
  5. Double click the Computer Management shortcut.
  6. In the left column, click on Device Manager.
  7. In the right column, click the plus (+) icon next to Universal Serial Bus controllers to expand this selection.
  8. Locate the iPod in this list. In some cases one of the entries will have "iPod" in its name. If no such entries are present, the iPod is most likely represented by "USB Mass Storage Device."
  9. Note: A red "X" appearing next to the iPod's entry in Device Manager indicates this device is disabled. To enable this device, right-click its entry in Device Manager and choose Enable from the shortcut menu.
  10. Update the USB driver
    1. Right-click the iPod's entry in Device Manager and choose Update Driver from the shortcut menu.
    2. In the Hardware Update Wizard that appears, select "Yes, this time only" to allow Windows to connect to the Windows Update Website. Click Next.
    3. Select "Install the software automatically (Recommended)" and click Next. Windows searches for updated drivers and installs any it finds. If Windows is unable to find updated drivers on its own, continue with step #4.
    4. Click Back.
    5. Select "Install from a list or specific location (Advanced)" and click Next.
    6. Select "Search for the best driver in these locations."
    7. Select "Include this location in the search" and type the following in the field below: C:\Windows\INF
  11. Click Next. Windows searches this location for drivers and installs any it finds. If Windows is unable to find updated drivers on its own, you must reinstall the USB drivers as shown below.
  12. Note: During installation, if a message appears stating that the software you are installing "has not passed Windows Logo testing" click Continue Anyway to continue installing the drivers.
  13. Reinstall USB driver
    1. Right-click the iPod's entry in Device Manager and choose Uninstall from the shortcut menu.
    2. In the resulting dialog box, click OK.
    3. In the Device Manager window, right-click Universal Serial Bus controllers and choose Scan for hardware changes from the shortcut menu.
    4. Windows automatically reinstalls the necessary USB drivers and attempt to remount the iPod. Regards...
Posted on Apr 07, 2009
adnanbhatti
  • 1188 Answers
SOURCE: HP Pavilion ZV5000, some key not working on
Yes, you can try re-seating the ribbon cable. Also remove any dirt with a paper.
If this does not solve your problem, then buying a new one may be the only option.
Trust me, computer peripherals are not meant for repairs.
Posted on Sep 28, 2009
Why are the Keys on my axiom pro 61 not sending MIDI messages?
Does your keyboard have a "MIDI OUT" port? If yes, then
there is a selection to choose between USB or MIDI OUT port.
For my M-AUDIO oxygen 61 (silver), I must press the [Advanced] button then Note F3 on the music keys manual to toggle the MIDI-OUT.
If set to INT, it will not sent via USB. If set to USB it will not send via MIDI-OUT port. To use MIDI-OUT port I need external 12V DC adapter.
Jul 29, 2014 | M-Audio Axiom Pro 61 Advanced 61-Key USB...
Hello guys, i have a problem with my midi keyboard. My PC doesn't recognize the USB connection and i can't find any solution.
Well first start by verifying USB port works by plugging in a hard drive or something thus proving you have a good port and USB Cable. At which point hook the keyboard up ( and make sure to properly install drivers provided on cd with purchase) being a pc this may take several attempts to install. What software are you trying to control? Reason? Logic? Fruityloops?
Oct 07, 2011 | Alesis Q49 USB/MIDI Keyboard Controller
My husband has an HP computer and is using windowsXP. Suddenly, he cannot enter any typed infomation as required during a search, but his cursor works to go to the blank field. He cannot type into the...
Your keyboard USB cord has probably become loose. Try reseating the cable into another USB port, or just reseating it if the keyboard uses a keyboard cord.
If this doesn't work, try a different keyboard (if you have another one around the house).
You may have either a bad USB port, dirty port, or bad keyboard.
please rate my solution!
Jul 17, 2010 | HP Pavillion s7420n PC Desktop
USB drive problem
I had a client with this same issue. However, her issue was that the top left USB port would only accept flash drives. Your external harddrive is probably not getting enough power from your USB port. Try using two USB ports (you can get a connector for this) to power up the external harddrive.
Apr 06, 2009 | HP Compaq nx6325 Notebook
My hard drive and midi controller wont work with usb
When you connect a hard drive and any other USB device to a 4 port hub you have to use the external power supply all the time. You may have fried the power pins on the USB port you used to connect the 4 port hub. If you can get the hard drive to work separately on the USB port, the 4 port hub may no longer be passing power from the laptop.
Nov 09, 2017 | Vestax Vci 100 Midi Controller
Keyboard not functioning at all
The problem may be two things:
1) Its cord is disconnected from the PC unit
2) Your Keyboard drivers are outdated.
If the cord is fine, I recommend that you go to the hardware wizard (Start Menu -> Settings -> Control Panel -> Hardware Wizard) and run a "detect new hardware." This feature should be able to get your keyboard going again - and you should be able to access this feature by using your mouse only.
Aug 06, 2008 | Microsoft Natural Ergonomic 4000
MIDI hookup
The midi port looks like the bottom one in the picture:
http://www.e-tech.nu/images/sound_connectors.jpg
You need a cable from the keyboard midi (din connector) to the DB-15 on the sound card/mainboard. If you dont have a 15 pin midi/game connector you could buy a soundcard with midi onboard or a usb midi port like the:
http://www.zzounds.com/cat--USB-MIDI-Interfaces--2434
Jan 11, 2008 | Car Audio & Video
USB
I had a similar problem, with no help from HP support. A USB hard drive would be recognized, and work, but a Sandisk flash drive and a Fujifilm camera would not. All drivers were uninstalled/reinstalled/updated numerous times. HP finally concluded a hardware problem. However, I noticed an updated BIOS on HP's web site to fix "USB problems" with some equipment. I flashed my BIOS with the new version, and USB now works. Some minor glitches, but acceptable..
Oct 24, 2007 | HP Pavilion ze2000 Notebook
HP Pavilion ZV5000, ZV6000, ZX5000 Series 12 Cell Li-Ion Battery - DP390A (DP390A1) CD-ROM Drive Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
