Hi We have a Zanussi Turbodry and when i tried to open the door it wouldn't move and i have now broken the handle off!!! How do we open the dooe?? Thanks Lynsey
  • Washing Mach... Master
  • 3,463 Answers
Get a thin screwdriver and poke it in between the door frame and the front of the washer where the door latches in, push hard and see if it will release that way..
If no go, then remove top of washer , and with a long screwdriver or similar try to release the door catch from inside the front of washer, you may have to lever it open, and possibly break the door lock in the process.
There really is no other way of releasing door.
You obviously will have to replace the whole door handle assy, and the door lock.
Plz rate my solution.
Thanks.
Posted on Jan 19, 2009
Where can I find a manual?
You may view/download the manual here.
Mar 14, 2012 | Zanussi Washing Machines
Zanussi FL884 Washing Machine door lock broken.
More likel that the door latch or handle is broken.
Only way to open door now is to remove the top cover and force the door lock open from inside, you may possibly break the lock by doing this, but there is really no other alternative.
Mar 29, 2010 | Washing Machines
Zanussi jetsystem turbodry 1200 door wont open
its the doorcatch,turn power off, remove lid and put hand in machine where doorlock is situated feel about and try open catch, repair or replace?
Jun 24, 2009 | Zanussi ZWF1420W Front Load Washer
Broken plastic door handle
Depends what you mean by the "handle". The outer door ring is listed as a spare part 112100592, and behind it is the "handle"
112300530.
In view of the age of this model, spares may be hard to find, so keep an eye on eBay for a used door or door assembly or whichever of the part numbers above is required. Good luck.
Jan 11, 2018 | Splendide 2100 Vented Washer-Dryer
What is E 40 on Zanussi Turbodry 1200?
E40 indicates the doors not closed properly. Sometimes it can be the lock itself or the main control board
Nov 24, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi WJS 1397W
possibly a foreign object in pump.
tilt backwards at a good angle and remove pump. i find the easiest way to do this is to undo the 3 screws round the periphery of the pump
Jul 11, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Door wont open
Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Dec 23, 2007 | Zanussi FJS1225W Front Load Washer
Door latch broken, clothes stuck inside!!
not that easy. best way to try is to chew away as much of the handle as possible till the door peg is in view then prise open with a small screwdriver. you can sometimes reach down the inside the machine from the top and feel for the tip of the peg and do it that way
Apr 01, 2007 | Zanussi FLA1001W Front Load Washer
Zanussi jetsystem Turbodry 1200
It appears that you may have a faulty door interlock or a faulty PCB. pcb is not really a DIY job as some boards require proramming on certain versions. Regards Advisor
Oct 30, 2006 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
