Comes up with over temp after using steam wand and wont alow me to use it after unless i turn my unit off for a hour
SOURCE: WAter is not running through espresso and low temp
Hi Suzy, about the replacement part for your 80s machine, contact one of the dealer to get a heating element with same specs shipped to you.
Youu can contact Saeco parts In NY
215-361-7000 Toll free in USA:
1-888-950-4878
or
I can also see that the other expert here has a contact of his own they should also deal in parts: www.CeriniCoffee.com by calling them in NY at : 718-584-6120
Here is more Saeco part dealers:
Saeco Home Espresso Machine Parts
Saeco espresso machine
SOURCE: ventilate sign on my coffee machine
When it says to ventilate, it is asking you to prime the pump. Put acup
under the panarello wand ( the steamer/frother) to catch thedischarged
water and press the hot water button (upper left button onmy machine).
Wait until air stops coming out with the water, usually3-5 ounces, and
then press the hot water button again.
You machine is now ventilated (primed) and should be ready to go.
SOURCE: Hot water come out from steam wand when pumping Saeco Classico
Gasket on steam valve is worn. Replace gasket and or steam valve.
SOURCE: Saeco Odea Go - slow to brew coffee, comes out of steam valve
The steam valve needs to be replaced, because the pins have been damaged from high pressure buildup, could have been caused from a very fine grind. You can also check the screen in the brew unit that might be blocked and causing the high pressure backup.
