Question about Invacare Health & Beauty
The wheelchair does not come on or light up at all. When I put t
Nothing on my Invacare Torou SP electric wheelchair seems to turn on whatsoever when I put the battery charger on the green light to the charger goes out. The batteries seem to have only 2.2 V charge on them instead of the 24 V charge, when in series. Everything seems to be plugged in and connected correctly. I found two fuses and those seem to be OK. The wheelchair was in storage at below freezing temperatures in a garage. The wheelchair was plugged into a charger all this time. In fact I had two chairs in the parking garage one was OK and one wasn't. It definitely seems like the battery voltage is low but every time I plug the charger in the green light goes out which indicates a fault on the system. Do you have any suggestions on how to troubleshoot the system. Is there a way I can bring gel cells down to a local garage and have them check the batteries. Is there any way that I may have left the chair on with the charger on too and cause damage? The chair is dead as a door nail but in perfect condition otherwise. The chair is also about seven years old but the batteries are less than a year old. This is my second electric wheelchair and I'm having trouble having the insurance company cover service charges on this chair. The chair works great when it did and I could go about anyplace with it. It was such a good backup if I can get it going please help me.
  • 175 Answers
A note of caution when using a standard battery charger for a car on powerchair or scooter batteries, or ANY sealed batteries. The chargers for this mobility equipment are designed to slowly charge the batteries in spurts so that there isn't a dangerous buildup of hydrogen-sulfide gas which is produced when charging any battery. Because the batt's are sealed, the casing could expand and blow apart when not allowed to slowly, and in spurts, charge.
Car batteries are unsealed, so the gas escapes. In any case, apply no more than 4 amps to any mobility battery, and do so for only an hour or so before letting the battery settle down and the gas recombine with the gel inside.
Gel batteries should be stored with a full charge, disconnected from the equipment in a cool, dry space, and shouldn't be stored for more than a few months without periodic recharging. At the price of them, it pays to take good care.
Posted on Jul 12, 2009
  • 27 Answers
Your batteries have shorted out internally. If you have a 2/10 Amp car battery charger, you may be able to bring them back to life like so...
- Switch the charger to 2 Amps
- if your chair uses two 12V batteries, connect the car charger across only one of them. If it uses four 6V batteries, connect across two. Be sure to match red to plus and black to minus!
- plug in the charger and watch the Ammeter meter. If it "pegs" and won't come down, the battery is toast. If it goes down to aboult half, you are on your way.
- When the meter gets down to about 1/4, switch to 10 Amps. The meter will again go up.
- When the meter drops to about 1/4 again, the battery is charged,
- Repeat above for the next battery.
This process will take several hours per battery. You don't have to remove the batties from the chair. However, it would be a good idea to do so in case a battery fails.
Good Luck !
Posted on Feb 03, 2009
How to recharge but I get a flashing red light on transformer in battery box. this is a Invacare Pronto M91 Electric Wheelchair
The red light on the transformer/Charger means the charger is bad. Sometimes it can also be battery harness wiring. Most often it is the charger that needs replaced.
Jun 22, 2014 | Invacare Supply Group Invacare Pronto M91...
When I turn my wheelchair on a service indicator light at bottom of joystick blinks 9 times. How do I fix this?
If: Battery indicator flashes the charge level is low
immediately after recharging.
Then it is a. Weak Batteries.
b. Charger malfunction.
c. Electrical malfunction
Solution a.Replace batteries.
b. Replace charger. Contact Dealer/Invacare.
c. Contact Dealer/Invacare.
I got the above from the manual. The link is:
http://www.invacare.com/doc_files/1125085.pdf
Regards
Chellakumar
Jun 13, 2014 | Invacare Pronto M51 Power Wheelchair
I had a wrench showing on my wheelchair. Now the wrench is gone and the unit will not turn off..
Hello, If the joystick won't turn off it is a joystick problem. You can unplug the joystick cable from the joystick to save battery if you need to. This kind of problem means your joystick will need to be repaired at Invacare or replaced by a dealer of Invacare chairs.
Jun 01, 2014 | Electric Mobility Invacare Pronto M41...
I have the tdx sp and the wrench light is flashing 7 times what does this mean?
There is a problem with the remote joystick. Could be a bad connection or bad harness to the remote joystick. If harness is fine then the joystick has issues and needs to be replaced or rebuilt.
Try the 4-wire harness first.
Nov 03, 2013 | Invacare Supply Group Invacare Pronto M91...
Troubleshooting an invacare tdx sp electric wheelchair
Behind the drive wheels is a selenoid that has a flip up for "PUSH" and flip down for "DRIVE", make sure they are both in "DRIVE". That's what worked for me.
Oct 13, 2012 | Invacare Health & Beauty
Put joystick into lock mode
press and hold on button til beep then push and hold joystick til beep then pull and hold joystick til beep turn off then on should be unlocked now
Oct 04, 2012 | Invacare Supply Group Invacare Pronto M91...
Turn on key shows full charge.but within 30secs one green goes out and one red starts flashing invacare scotter
those lights go by voltage not amps the battery has charge the battery then remove it bring it to a auto parts store to have it tested
Mar 31, 2012 | Electric Mobility Invacare Pronto M41...
Stability locking kit
The M51 does not have a stability locking kit. The Invacare TDX SP has a gas strut stability locking kit that just had an extensive recall campaign associated with it. Please describe your issue in greater detail.
Jul 16, 2010 | Invacare Pronto M51 Power Wheelchair
Pronto M51 ...the yellow light is blinks and dosen't stop
Take your drive units both out of gear and put them back in that will reset the computer and it started mine working again.
Apr 21, 2009 | Invacare Supply Group Invacare Pronto M91...
Health & Beauty Logo
372 people viewed this question
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
gnshome
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
