Question about Whirlpool Duet GHW9150P Front Load Washer
Erreur f-28 et la porte n`ouvre pas laveuse whirpool duet
4 Suggested Answers
watugot
  • 290 Answers
SOURCE: extended warranty
Yes. You should be able to get one from Whirlpool. If not, Sears will sell you one no matter where you bought the machine.
Posted on Oct 09, 2007
ginko
  • 19396 Answers
SOURCE: à la mise en marche
Vérifiez l'eau provient de tuyau à l'arrière de la machine.
La laveuse a basculer de niveaux d'eau (water-level switch) , quand ce
est défectueux, il s'arrête à mi-remplissage.
Je pense que c'est le problème
désolé pour mon français
merci
Posted on Sep 04, 2008
richroth
  • 9472 Answers
SOURCE: whirpool duet washer estimated time remaining flashes h followed by f
FH No water detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Potential Causes
• If there is no water in the unit:
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
- Verify inlet valve operation
• If there is water in the unit:
- Verify Drain pump operation
- Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Posted on Nov 29, 2012
Samsung microwave CP1395 malfunction E-32 in manual. If I use oven function or a combo like microwave & grill it stops midway and will not work again!
Bonjour
nous avions une erreur 32 sur notre four
ce n'etait pas l'element damper ci-dessus (test? manuellement)
nous avons trouv? la cause un peu par hasard : en appuyant tres tres fort sur le plateau interieur l'erreur 32 disparaissait et le four refonctionnait qqles secondes
donc :
debrancher le four
demontage de la tole de dessous le four
demontage de la piece qui detecte la presence (ou qui mesure - tres mal - le poids) : 3 vis
Sans lui debrancher ses fils electriques
avec un petit boulon par exemple et un serre joint : ecraser doucement le centre du capteur
poser le capteur er le serre joint derriere le four et remonter le four
rebrancher
ca marche
sans l'option mesure de poids mais comme c'est une fonction qui ?est pas au point c'est pas grave
stephane
bretagne
contact@armorstudio.fr
Apr 24, 2013 | Microwave Ovens
Je n arrive pas a restaurer mon iphone j ai toujours une erreur 1015 qui s affiche
Télécharger
http://modmyi.com/forums/3g-s-downgrading/714717-ultimate-downgrade-tutorial.html
puis
Après la deuxième restauration ne sont pas utiliser de la neigerouge, utilisez la pluie pourpre. Purple rain sera roboot votretéléphone sans utiliser irecover ou QuickPwn. après jailbreak estyoull complète être bloqué en mode de récupération suffit de débrancher et rebrancher ouvrez iTunes. iTunes devrait rocognizevotre appareil et activer votre service
Bruce
Jan 12, 2011 | Apple iPhone 3G Black Smartphone
J'ai un code erreur 5200 .... quoi faire ?
Ce code d'erreur vous dit que l'unit? de purge n'a pas compl?t? un bon pouvoir sur le cycle et la came n'est pas dans la position correcte. Typiquement ceci signifie que l'unit? de purge est enfonc?e prolong? en raison de l'accumulation de beaucoup d'a s?ch? de l'encre.
Ouvrir la couverture et quand la t?te vient au centre, tirer le cordon d'alimentation. Une fois ce pouvoir est de peut vous transf?rer maintenant la cal?che ? l'extr?me gauche si c'est ? un endroit o? il ne vous g?nera pas. Maintenant utiliser une serviette en papier et tacher doucement toute l'encre suppl?mentaire de des Coussins d'encre et les appuie en bas. Si la lame d'Essuie-glace est ?tendue, le nettoie et il devrait claquer de retour en place. S'il est toujours enfonc?, essaie vaporisant le secteur avec Windex mais n'importe ne lequel obtient pas sur n'importe quoi sauf les coussins.
Nouvel An heureux !
Si je pourrais ?tre de plus ample assistance, me permettre de savoir. Si ceci aide ou r?sout le probl?me, s'il vous pla?t l'?valuer et donner un t?moignage pour ma r?ponse.
Merci, Joe
Jan 01, 2011 | Canon Pixma MP500 All-In-One InkJet...
Pourquoi code erreur 52030
Bonjour,
Mon nom est Brandonmxb. Je veux essayer de vous aider du mieux que je peux. Je ne parle pas anglais, mais puisque vous parlez français, j'ai appris la belle langue, ou bien je viens d'utiliser Google Translate. Bref, voilà votre solution.
Certains utilisateurs ont un problème de reconnexion à la fonction WiiConnect après la mise à jour il ya des systèmes.
Si vous avez trouvé soit un 32002 ou une erreur 52030 essayez de changer votre canal sur le routeur à 11 ou 1. Si votre déjà sur l'une de ces chaînes aller de l'avant et mettez-le à tout le reste, laissez le cycle de routeur, au moyen (redémarrera après le changement), puis changez-le sur le canal 11 ou un. Aussi, si vous avez un téléphone sans fil aller de l'avant et de l'éteindre juste pour s'assurer qu'il n'y ait aucune interférence. Si rien de tout cela fonctionne aller de l'avant et appeler Nintendo sur l'organisation d'une unité de remplacement ou de dépannage mai ils vous fasse.
Pour les "routeurs Linksys WRT54G" Entrez l'adresse IP du routeur (par défaut est 192.168.1.1) le mot de passe et nom d'utilisateur (par défaut admin / admin) puis cliquez sur l'onglet sans fil, maintenant sélectionner un autre canal sans fil dans le menu déroulant. Ce correctif mai ne fonctionnera pas pour vous, mais il vaut la peine d'essayer, et à nouveau ce correctif n'est pas garanti de fonctionner pour toutes les consoles.
Si cela a permis, s'il vous plaît taux de moi.
Besoin d'aide?
Aller à: http://www.nintendo.com/consumer/
Appelez: 1-800-255-3700 *
Dec 12, 2009 | Nintendo Wii Console
Je ne suis pas capable d aller dans mon mp3 il ne le reconnais pas et il a une erreur allors je ne peux pas mettre ou enlever des chanson
réinstalle le firmware du mp3 et cela devrait régler le problème
tu devrais trouver le firmware sur le site du fabricant du mp3
dans la section support.
une fois téléchargé, connect ton mp3 et ouvre le ''firmware updater''
il devrait trouver le mp3 par lui meme sinon aide le à trouver le bon lecteur soit le lecteur E: ou peu importe
une fois que cela sera fait déconnect le mp3 de l'ordinateur de facon sécuritaire a l'aide de l'option retirer un périphérique
et ton mp3 devrait maintenant te permettre d'ajouter ou de suprimer des chanssons
Bonne chance
Jun 19, 2009 | RCA JET S2002 MP3 Player
Arr?t de la laveuse amana
Code 2E demande l'assistance d'un technicien. Remplacement du module de contrôle électronique. Problème réglé par le vendeur. Excellent service.
Jul 26, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
294 people viewed this question
Dan Webster
Dan Webster
Sal De
