Power turn off by its self - Televison & Video
  • 2discsleeve Jan 30, 2009
    Why does this happen?? besides it being broke...lol Can I fix it myself??
    Sergeant:
    Champion:
  • 223 Answers
I think the problem is a faulty resistor on the power supply board. If you can check this for yourself or find a qualified technician. Hope this helps.
Posted on Jan 18, 2009
Have a mitsubishi model 73640 and the power light turns on makes some noise thens turns off by it self.
The red indicator merely shows power is getting to the set. Probably the power supply has failed.
Jul 17, 2014 | Televison & Video
When i turn on my dynex tv it turns off by it's self then turn's back on
replace bulged capacitor at the power supply board the it will works normal.
Aug 30, 2012 | Dynex 19 in. LCD Flat-Panel HDTV
My Philips 42pfll7603d/10 turns its self on and off has no picture or sound and on the source menu it shows side then turns its self off
Look for loose contacts in power outlet, power cord, RC jacks, cable, sockets. Try changing the input device to something that works such as a DVD player.
Aug 06, 2012 | Televison & Video
Pc turns it self on by it's self
Make sure the power button isn't sticking at all. If it is sticking then use some glass cleaner on a cotton swab and clean around the button.
Try plugging the computer directly into a wall outlet instead of a surge protector or power strip to rule out a faulty product.
If the same thing keeps happening then you'll need to replace the power supply.
Jan 12, 2012 | E-Machines eMachines Desktop PC
The reset power flasher is continually on! How do I remove? Dean
Issue All lights on the product control panel flash and a 'Reset Power ' message displays on the product control panel. Solution one: Turn the product off and then on Follow these steps in the order presented to turn the product off, and then on again. Step one: Turn the product off and then on
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Wait 15 seconds.
  3. Press the Power button (c01602202.gif ) to turn on the product.
Step two: Print a self-test report
  1. Load clean, unused, plain white paper into the input tray.
  2. Press the Setup button.
  3. Press the Right Arrow button (c01185072.jpg ) to select Print Report , and then press OK .
  4. Press the Right Arrow button (c01185072.jpg ) to select Self-test Report , and then press OK . The self-test report prints.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution two: Reset the product Follow these steps in the order presented to reset the product. Step one: Reset the product
  1. Press the Power button (c01602202.gif ) to turn on the product.
  2. With the product turned on , disconnect the power cord from the rear of the product.
  3. Unplug the power cord from the wall outlet.
  4. Wait at least 15 seconds.
  5. Plug the power cord back into the wall outlet.
  6. Reconnect the power cord to the rear of the product.
  7. If the product does not turn on by itself, press the Power button (c01602202.gif ) to turn it on.
  2. Press the Setup button (? ).
  3. Press the Right Arrow button (c01185072.jpg ) to select Print Report , and then press OK . The Print Report menu displays.
Solution three: Service the product If you have completed all the preceding steps and are still experiencing a problem, service the product. Determine if your product is in warranty or out of warranty. If you need help determining your product's warranty status, go to HP's Warranty Check Tool .
Aug 16, 2011 | HP Officejet 6310 All-In-One InkJet...
Printer was working ok then error 0x610000f6 came up this comes up all the time
Follow the below mentioned steps to resolve the issue :
This error is usually due to Carriage Jam issue. 1) Power off 2) Unplug the power cable from the wall outlet (should always power off first using the power button). 3) Remove the back piece and putting it back, making sure it's well adjusted. 4) Also removed the piece where the printed paper land, and put it back. In case if this doesnt help follow the below mentioned steps : Print a self-test report : ollow these steps to print a self-test report. Press the Power button to turn the product on. Press and hold the Cancel button. Press the Red-eye Removal button. Solution one: Turn the printer off, and then turn it on Follow these steps to turn the product off and then to turn it on. Step one: Turn the printer off, and then turn it on Press the Power button to turn the product off. Wait 15 seconds. Press the Power button to turn the product on. Step two: Print a self-test report Print a self-test report. Refer to the section on how to use these solutions at the beginning of this document. If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. Reconnect the USB cable, and then try to print again. If the issue persists , continue with the next solution. If the self-test report does not print , continue with the next solution. Solution two: Clear all paper jams Follow these steps to clear any paper jams. Step one: Remove any loose paper 1. Disconnect the USB cable from the product. 2. Disconnect the power cord from the back of the product. 3. Remove all unused paper from the tray. Step two: Remove all paper from inside the back of the printer. From the back of the product, remove the rear access door or duplexer, and then remove any paper stuck inside of the product. Press the tab on the left side of the rear access door to release it, and then remove the door by pulling it away from the product. Gently pull any jammed paper out of the rollers.
If your product has a duplexer :
1. Remove the duplexer from the rear of the product and remove any paper or scraps of paper stuck inside of the product. 2. Open the duplexer and remove any paper or any other obstructions. 3. Close the duplexer. 4. Reinstall the rear access door or duplexer.
Step three: Remove jammed paper from the front of the printer. Remove the paper very carefully. If the paper tears, part of it might remain inside the paper path and damage the product. Carefully remove all traces of paper that you can find. Reconnect the power cord to the back of the product. Press the Power button to turn on the product. Open the carriage access door. The carriage might try to move into the access area. If so, allow it to move to that position.
With the product turned on, disconnect the power cord from the back of the product. Unplug the power cord from the power source or electrical outlet. Check for any paper or objects that might be stopping the carriage. Reach inside the product, and then manually move the carriage. If the carriage is stuck on the right side of the product , move the carriage to the left side of the product. If the carriage is stuck on the left side of the product , move the carriage to the right side of the product. If the carriage is stuck in the middle of the product , move the carriage to the right side of the product. Remove any loose paper or obstructions found. Make sure that the carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Close the carriage access door. Reconnect the power cord to the product and to the power source. Reconnect the USB cable to the product. Load plain paper in the tray. Press the Power button to turn the product on. Step four: Print a self-test report If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. Reconnect the USB cable, and then try to print again. If the issue persists , continue with the next solution. If the self-test report does not print , continue with the next solution. Solution three: Make sure that the cartridges are installed correctly Improper placement or installation of the cartridges can cause a carriage jam. Installing only one cartridge can also cause a carriage jam. Follow these steps to make sure that the cartridges are installed correctly: Step one: Remove the cartridges Press the Power button to turn on the product. Open the carriage access door. Press the tab on one cartridge to release it and then remove it from the slot. Repeat the previous steps to remove the other cartridges. Look under and around the carriage, and then remove any obstructions. Step two: Reinstall the cartridges 1 - Latch in down position Slide one cartridge into its slot with the matching icon, and then press it in until it snaps into place. Figure 9: Slide one cartridge into its slot and snap it into place
Repeat the previous steps to install the other cartridges. Close the carriage access door. Load plain paper in the tray. Figure 10: Load plain paper Step three: Print a self-test report Print a self-test report. Refer to the section on how to use these solutions at the beginning of this document. If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. Reconnect the USB cable, and then try to print again. If the issue persists , continue with the next solution. If the self-test report does not print , continue with the next solution. Solution four: Connect the printer directly to a wall outlet If the product is connected to a power strip or a surge protector, follow these steps to connect the product directly to a wall outlet. Step one: Connect the printer directly into a wall outlet Press the Power button to turn off the product. Disconnect the power cord from the back of the product. Disconnect the power cord from the power device. Plug the power cord directly into a wall outlet. Connect the power cord to the back of the product. Press the Power button to turn on the product. Try to print.
Print a self-test report. Refer to the section on how to use these solutions at the beginning of this document. If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. Reconnect the USB cable, and then try to print again. If the issue persists , continue with the next solution. If the self-test report does not print , continue with the next solution. Solution five: Perform a power reset. Follow these steps to reset the product. Step one: Perform a power reset Press the Power button to turn on the product. With the product turned on, disconnect the power cord from back of the product. Disconnect the power cord from the wall outlet. Wait at least 15 seconds. Connect the power cord into wall outlet. Connect the power cord to the back of the product. If the product does not turn on by itself, press the Power button ( ) to turn it on. Try to print. Step two: Print a self-test report. Print a self-test report. Refer to the section on how to use these solutions at the beginning of this document. If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. If the issue persists , continue with the next solution. If the self-test report does not print , continue with the next solution. If the self-test prints, then your carriage jam issue is resolved. Connect the USB cable to continue the print job. Step three: Search for more information If you detect another issue, go to the HP Product Support Home Page, and then search for another document that relates to the issue you are experiencing. Solution six: Service the product If you have completed all the preceding steps and are still experiencing a problem, service the product.
May 01, 2011 | HP Office Equipment & Supplies
Our oven has no power since truning self cleaning on.
We have the same problem, we placed our oven in self cleaning mode and now it will not open up... All power has since has shut off. Please assist us with turning the power back on, thanks....
Jan 04, 2010 | KitchenAid Architect Series II 30"...
Why does my Tv turn off by its self after turning
power problem. it takes a lot of power to start it up, but the power supply can't do it anymore. needs a new power supply.
Jul 15, 2009 | Hitachi C21 F800S TV
Dell172fpb 17" monitor
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and the monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
  4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
Kenwood kdc 3011 rests its self every time i turn the car off
This means that the power lead you connected the red and yellow to is a switched live and each time you turn off the ignition the power goes off and therefore resets. to fix this problem you need to connect the yellow to a permanent 12v supply that stays live when you turn off the ignition.
May 27, 2008 | Kenwood KDC-2011S CD Player
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
