Question about Westinghouse Kitchen Ranges
How to install a wrg605is westinghouse range hood
I had to clean the range hood, but I forgot where the switches went and I need help on putting it all back together again.
5 Suggested Answers
  • 89 Answers
SOURCE: Brand new Viking 3048SS hood - fan switch not working
think i would call viking back and ask for refund of inspection fee and go by the bad switch scenerio the electrician said new fan that would be considered flaws in workmanship in most states dont know where you are located but pretty much same anywhere most inspectors for these companies always try to blame problems off on installers hold your ground and make them fix it and refund that" inspection " fee I've been doing electrical work for several (20+) years it takes longer than 5 minutes to troubleshoot something like that good luck
Posted on Aug 23, 2008
  • 203 Answers
SOURCE: Range hood light switch not working.
you have checked the bulb? if so the the switch of disconnect from supply first and have a look at the condition of the switch it might be full of goo. joe
Posted on Nov 22, 2008
SOURCE: fan switch not work - Viking 3048SS brand new range hood
I did some more troubleshooting and figured out how to get the plate off that houses the switches. I disconnected the fan switch and created a safe electrical by-pass. I re-connected the main power supply and sure enough, the fan worked. Issue = defective switch. Currently looking to order replacement. Problem solved.
Posted on Apr 11, 2009
SOURCE: replace fan/light switch zephyr pyramid range hood
I am also looking for instructions for PLHV36W6CC.
The fan is on right now but the switch is sliding back and forth loosely.
I just downloaded the manual but that was no help.
If someone has a quick solution, that would be great.
Please email me at robert_attieh@yahoo.ca
I have stuck my hand up and fiddled around but besides just ripping it out, could use some help.
Thanks,
Robert
www.150FastGroup.com
Posted on Aug 03, 2010
How to replace control switches for a venmar hood fan
[PDF]Download - Venmar
www.venmar.ca/DATA/.../131_5_en~v~Installation_Manual.pdf
Before servicing or cleaning unit, switch power off at ... solid-state speed controldevice. 8. ... should not be allowed to accumulate on fan, filters or in .... We recommend to install the hood at a minimum distance of 24" from an electric range and.
FAQ - Venmar
www.venmar.ca/en-faq.html
Can I use other controls than Venmar controls with my unit? What is the ... Range Hoods. Can I replace an "over-the-range" microwave with a range hood? ... VenmarConnaisseur C270 and C600M ยท Rocker switch control. Venmar V10 ...
Range Vent Hood Switch Parts In Stock from RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Range-Vent-Hood-Switch-Parts
Shop for your Range Vent Hood Switch from our huge inventory. Check our ... RepairHelp for Range Vent Hoods ..... Blower variable speed control switch.
Range Vent Hood Repair Help - Free troubleshooting
Jan 23, 2016 | Venmar Kitchen Ranges
Viking hood Lights out
There is a short inside, you need to check wirings to locate the short.
Apr 05, 2008 | Viking VWH3048 Kitchen Hood
Westinghouse Self Cleaning Oven - Digital
hello susie,
try this site
http://kitchen.manualsonline.com/manuals/mfg/westinghouse/westinghouse_oven_product_list.html
May 13, 2013 | Kitchen Ranges
Westinghouse range hood wrf900cs light blew, light globes replaced but lights still not working
I had the same problem. An audible pop and the lights stopped. Fans still works, light bulb filaments appear intact.
My problem was that a short piece of the copper on the printed circuit board, inside the switch housing, had vaporized as if it were a fuse. I soldered a bridge of copper wire across the small 5mm gap and all was working again.
Access the switch compartment by removing the filters, undo a couple of retaining screws to remove switch unit.
Make sure the electricity to the unit is Off/unplugged before proceeding!!!
Switch unit cover has 4 screws holding it on. Once inside the unit, trace the wire (mine was grey colour) from the light switch to the small printed circuit board. The copper printed circuit link to the connector had gone...no sign of burning, just gooone!
Solder a bridge of copper wire across the gap and reassemble switch unit to test.
....send beer donations to me in qld...cheers!!!
Jun 29, 2012 | Kitchen Ranges
I want to remove a faulty westinghouse range hood to replace it. Its mounted between two cupboards. I've removed the filters and looked inside. I can't find the mounting screws. Pls provide procedure....
Some are mounted from the cabinet interior, check that as you will have to open the portion of the cupboard containing the vent tube or chimney to remove the old and reattach the new one. Some Westinghouse were slide in and had a side locking bolt running into adjacent cabinets
Nov 22, 2009 | Kitchen Ranges
Nov 18, 2008 | Hotpoint  Standard Range Hood
Fan switch not work - Viking 3048SS brand new range hood
There is the on off switch and the blower control that controls the speed of the fan. It is more than likley the blower control that would need replaced.
There could also be a wire disconnected in the hood.
Aug 19, 2008 | Viking VWH3048 Kitchen Hood
Broken Belt for Fantom Crosswind 600XL
Hello, your Fantom vacuum will take a Panasonic U vac belt, to replace it, their are two screws in the back, one on each side of the back of the housing, take out the two screws and lift off the top hood, and the vac belt is on the side, remove the brush roller clean any debis away, put the new belt around the metal motor shaft first then around the brush roller, and pull down into the housing, make sure it locks in evenly, then turn the roller to make sure it moves freely. then put the hood back on front first, hold down and put the screws back in, in the back. now your ready to vacuum. Any question or more help I can give, please call 1561-848-3387 Thank you, Teresa.
Jun 16, 2008 | Westinghouse WST1550 Wired Deluxe Upright...
Lighs
Saint...first...have a look at the bulbs. Make sure the bulbs are 'really' good and that the sockets are clean inside and undamaged. Second, the switch might be bad.
Nov 15, 2007 | Broan-NuTone Broan Range Hoods Deluxe...
Kitchen Ranges Logo
55 people viewed this question
Top Westinghouse Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Westinghouse Kitchen Range Expert? Answer questions, earn points and help others
