Question about Thermador Ovens
Thermador SCD302Zs, F7
After cleaning oven, beeping and F7 start
Gigatech
  • 259 Answers
SOURCE: Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Posted on Dec 09, 2007
Master_Tech
  • 770 Answers
SOURCE: f7 error
F7= function key is stuck or shorted >> you can turn the breaker off to the unit then back on if it come back up it will have to be replaced
Posted on Jan 27, 2008
kram26
  • 544 Answers
SOURCE: I need to self- clean my Thermador convection oven
hi,
here is the manual for your oven try to follow them and make them as your guide enjoy..
click on this site..
http://specs.retaildeck.com/CACHE/FILE2202.PDF
thank you,
please don't forget to rate our answers.
Posted on Feb 19, 2009
  • 56 Answers
SOURCE: F7 appears on GE double oven JT950SA
f7 is a stuck keypad or overlay all you can do is replace it
Posted on Jun 30, 2009
  • 70 Answers
SOURCE: F7 code and a random beeping
f7 err code means problem with the control panel.control panel needs to be replaced.if u like u can try for a temporary fix.open up the control panel by removing screws at the bottom of the conrol panel.disconnect the ribbon connector which comes from the control panel and connects to the control board.take a piece of paper towel and clean its end and put it back.some times this works.do not forget to turn of the power b4 doing this.
Posted on Aug 21, 2009
Testimonial: "Thank you that will help in the meantime b4 getting replacement part"
How do I stop my Thermador Oven SC302TS from beeping F7
Check this link for possible solution. It says that a function key may be stuck or you may have a problem with a control board.
Thermador Fault Codes AppliancePartsPros com
Feb 24, 2015 | Thermador SC302T Electric Double Oven
Our Thermador oven starts to beep when you shut it off and the way we are getting it to stop beeping is to set up a fan in front of the open oven to get it to cool. This stops the beeping after 10 m
Check if the internal ventilation fan is running. It is intended to cool down the oven exterior. Some units made 2004-2007 can overheat during self-cleaning.
Oct 14, 2014 | Thermador C301U Electric Single Oven
F7F1 error code
replace the ERC. may also require a new touch pad, but testing is required.
Feb 13, 2014 | Thermador SMW272 Electric Double Oven
I have a Thermador model smw272 and F 7 is flashing on the lower oven display, with a beeping sound every second.
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 30, 2011 | Thermador SMW272 Electric Double Oven
F7 and beeping
oven starts to beep and shuts off. I shut the circuit breaker off and it re sets itself and hopefully when I power it up it will start to work. We have replaced the front panel and all th PC boards and reset the reset button behind the panel. If there was a was that I could disconnect the shut off that's built in I would keep the oven.
When this oven work, it's great however at this time i am losing patience and maybe I should toss it out and get a new oven which I really don't want to do!
I am very capable of taking it out and opening up the panel an re setting all the boards once again if that would help? Thermador has had a recall on this unit as some people claim it will overheat and go on fire? The stove has little mileage on it and we would like to keep it but if you have a way of fixing it or if not we would love to hear from you! .
Mar 20, 2011 | Thermador C302U Electric Double Oven
My thermador oven is getting an F7 error message and it won't stop beeping. I tried holding the off botton but that won't do it.
You can take off the part of the front (the thing that looks like a vent and when that is off you can see a plug in. Unscrew two screws and then plug back in and screw the two screws back and it will stop beeping. We have a built in Thermador oven, microwave and warming drawer together. We had to find out by ourselves because we couldn't get to our breaker box. Hope this will help someone someday :)
Feb 21, 2011 | Ovens
My oven is beeping and the F1 code and F7 code are appearing on the screen
Hi
F1 indicates a fault on the electronic oven controller (the clock) & F7 means a function key is stuck.
Check all the keys on the keypad if the fault remains you probably need a new clock.
Dec 19, 2010 | Thermador SC302T Electric Double Oven
Hello! I have a Thermador double oven and it is beeping F-7 as it is finishing up a self-cleaning. In addition I am also getting F-1 F-1. The bottom oven cleaned and unlocked with no problems. Now the...
Hello, Per my manual:
F7 - This is caused by close contact to the control panel for more then 32 seconds,such as someone leaning against the controls or objects hanging in front of controls.
F-1 - Touch OFF or turn power off at the circuit breaker, wait 3 minutes and turn it back on. If condition persists, note the code number and call an authorized servicer.
Hope this helps,
Vicki
Oct 15, 2010 | Thermador SC272T Electric Double Oven
F7 error
Jan 11, 2008 | Thermador SC302T Electric Double Oven
Ovens Logo
42 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Thermador Oven Expert? Answer questions, earn points and help others
