Question about Gateway (4000798) Motherboard
Want to turn my server into a home pc motherboard 4000798
Gateway 920 server series, do I need to change bios to put windows xp on it and run as a home pc?
  • 1 more comment
  • Michael Anderson
    Michael Anderson Jan 18, 2009
    AMIBIOS V 07.00.00 S03_3A17
    having a tough time formatting the drive also
  • Michael Anderson
    Michael Anderson Jan 22, 2009
    I found the solution myself (after much experimentation) ;)
    I updated the bios, I also had to put the cd-rom on the secondary IDE channel as master. Used KillDisk to overwrite the drive to get the leftover Linux files out. Used a Win'98 boot disk to run fdisk
    and partition the drive, formatted with FAT32 file system. Then installed Win XP, allowing the setup to format into NTFS file system and setup XP. Got a driver set from Intel for the onboard ethernet and got a third party raid driver. Intel celeron 2.2ghz CPU,
    4GB SDRM.....this thing now runs like its on fire! Should be the fastest PC I've seen. Good to get some good use at home out of my old webserver. :)
  • marcatron Mar 26, 2009
    I have a SUN FIRE 420R SERVER that I would like to make a personal computer for audio production applications. Is this possible?
I need driver for motherbord ms9147c avdio-driver
Posted on Jan 19, 2009
I have a gateway gt4022 running windows xp. When
Probably hardware failure. To test that remove all disks and extra components and try again to boot into BIOS. If you can't then you will know for sure. If you can then take the opportunity to change the boot order and put the cd first and the hd second. Now connect an optical unit and try to boot in a bootable disk, preferably a Linux Live-CD. If you can then the hard disk is dead, replace it.
Jul 13, 2010 | Gateway GT4022 PC Desktop
Hi, I have formatted the SATA hard drive in my Gateway GT 5408 with Intel motherboard D945GCFG1. I want to load XP pro instead of the original Vista which was on it. Do I need to change the Bios or install...
No, you do not need to install a new driver as long as that is the same sata hard disk tha used to work in your Gateway computer. Just boot into your windows xp installation cd and let the setup continue.
Should you need further assistance, please let me know.
Mar 08, 2010 | Gateway GT5220 PC Desktop
Gateway 5310 series Multi videocard output
The MB video, is automatically disabled when you plug in any other card, accordingly, usually it is "Enabled" when it is taken out. You can adjust the Video RAM size sometimes via the BIOS, though. Now to get the drivers, look on the MB, there will be a set of big, Numbers and Letters, usually white, or black, by one of the slots, that is the Motherboard's identity, or get Everest, a free MB identity program, now, using that number Google, that-number + motherboard drivers, That will get you them, download and install. XP SP2, would be better...
Feb 26, 2010 | Gateway 5310 (1008368) PC Desktop
Am using linksys wireless system suddenly Ihave high speed ser
I think it's a defect in the computer. I've had the same problem and my husband did too with his Gateway computer. Not sure yet about a solution.
Nov 12, 2009 | Gateway 920 Series (gtwy920) Server
I have a unknown password to a Administrator login to a Gateway laptop(M405) with Windows XP OS. How to unlock laptop?
The best way to do this is using the Offline NT Password & Registry editor.
You can download it at the following link:
http://home.eunet.no/pnordahl/ntpasswd/
This utility will enable you to reset the password of any user that has a valid (local) account on your Windows NT/2k/XP/Vista etc system.
The link above includes some directions on how to use this utility.
Nov 10, 2009 | Gateway 920 Series (gtwy920) Server
Tweak BIOS to install Windows XP
Shouldn't need any "tweaking". Not sure offhand on the c700, but manytimes the Compaq bios is limited (and I'm a Compaq user - servers, desktops & laptops). What is itexactly that you're trying to achieve? I replaced Vista on my F500 series first with XP and finally with Linux - no problems (other than initially finding drivers). Just make sure to download and build an XP driver disk beforehand and you won't have any problems.
Jun 30, 2009 | Compaq Presario 700 470024-192 Notebook
You should be just fine with the existing BIOS. It should not affect anything with setting this up as a home PC.
I hope this helps clarify your problem,
Eric
Jan 19, 2009 | Computers & Internet
Cpu information?
CPU-Z is a free program that will give you CPU information. There's a download link on the upper left of this webpage.
Jul 02, 2008 | Gateway 920 Series (gtwy920) Server
Processor
What type of chipsetup your motherboard has and up to what bus speed its supports, what processor speed now u use and what model is your server, most server main boards supports two processors please lets us know what model server u got
Jun 27, 2008 | Gateway 920 Series (gtwy920) Server
I have two operating systems on my hard drive.
You can manually disconnect the IDE/SATA cable temporarily from your motherboard (the one with NT PRO & XP HOME), then you can cleanly install a Windows XP on your new Hardisk. And after installing, you can re-connect the other hardrive on your computer and format it under your NEW Windows XP, be sure to set the BIOS BOOTUP sequence that you boot on the right drive.
-mrsolution
Jun 11, 2008 | Gateway GT4022 PC Desktop
Gateway (4000798) Motherboard Logo
612 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
