Question about Sewing Machines
Drop feed dog 1222e pfaff
How do you drop the feed dog for free motion quilting
  • 8 Answers
SOURCE: Dropping Feed dogs on kenmore model 19233
Remove extension table/accessory box by gentle pulling it away from machine. You are left with just the free arm. In the back of the free arm, lower left corner, you will fine the feed dog lever. Push the leaver to the right to lower the feed dog.Instructions for lowering and raising the feed dog are on page 48 of your owner's manual. Good luck!
Posted on Jan 01, 2008
SewExpress
  • 41 Answers
SOURCE: fREE MOTION QUILTING
Hi Susan,
You're absolutely correct, you'll need to either drop the feed dogs (lever generally located near the bobbin case or on the outside base of machine) or cover the feed dogs with a plate (many machines have this included).
Then... you'll need to lower the presser foot - when you lower it, it should NOT touch the bed of the machine but sit slightly raised off the fabric surface. As you stitch the presser foot will lower onto the fabric to hold it taught as the needle penetrates.
Oddly enough it's easier to achieve smooth stitches when sewing at a faster speed, but begin by stitching fairly slowly until you get a feel for free-motion stitching. You'll be doing all the guiding and it may feel a bit strange and uncontrolled at first.
Position yourself at your machine so that when your hands on your fabric/bed of machine, your shoulders are relaxed (not all hunched up) and your elbows are slightly higher than the bed of the machine.
You'll want to stitch in a side-to-side or back and forth motion (as opposed to trying to turn the fabric.
Best of luck with this technique. Once you're comfortable with it, you're sure to enjoy the freedom of creating!
Happy sewing,
Kim & Linnette
Posted on Jul 31, 2008
  • 3 Answers
Pull out the removable table and you will see the drop down feed dogs switch lever behind the back of the machine. Move that lever to the left or right to have feed dogs go back to normal sewing mode OR for embroidery mode.
Posted on Mar 07, 2009
Zenqi
  • 208 Answers
SOURCE: Thread gets caught in feed dog while free motion quilting.
First, remove the thread and re-thread the machine. If the thread isn't in the take-up lever properly, erratic problems ensue.
Next, try removing the needle plate and bobbin case and inspecting both for any nicks or burrs. (your instruction book will guide you how) These can be very carefully polished off with 1500 grit sandpaper. Also check the hook for burrs.
Posted on Feb 21, 2010
bargainbox
  • 1388 Answers
SOURCE: I cannot get the feed dogs to come back up on my
Flick the switch to raise the feeddogs then rotate the handwheel one full revolution to re-engage the cam...voila
Posted on Mar 28, 2010
What [art do I need to fix a Pfaff 1222 where the needles is sewing in the same hole - failing to advance
Hi, It sounds like you may have dropped the feed dogs, like you would for darning or free motion quilting. Page 24 of the manual shows the control and I have included a link to the manual. http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/pfaff_1221_1222-manual-EN.pdf
May 02, 2017 | PfaFF Sewing Machines
Pfaff 113 want to free motion quilt the foot will not allow me to se. I even took the screw for adjusting preasure all the way out and it still has too much preassure
Sounds like perhaps you have the incorrect foot. Did you perhaps purchase a quilting foot (used for piecing)? A free motion foot is actually shorter in height so it will not contact the feed dogs or needle plate. It is this added space that allows the fabric to be moved freely under the foot. Also, be sure to drop the feed dogs.
Open Toe Free Motion Spring Foot
Open Toe Free Motion Foot
Pfaff 113 free motion foot Google Search
If the presser foot is still too long, perhaps the shank is not correct for your machine. Sorry, am unable to locate information re your particular model.
Sewing Machine Feet
Apr 05, 2017 | PfaFF Sewing Machines
Can I do stippling on my 400xl
This is free motion quilting. There are a ton of web sites and videos available. You'll need a darning or free motion quilting foot for your machine. Drop the feed dogs. If you are certain you want to do free motion quilting, a Supreme Slider helps you move the fabric.
https://www.amazon.com/Supreme-Slider-Motion-Machine-Quilting/dp/B007XGITA2
Learn How to Free Motion Quilt Stippling
How to Free Motion Quilt on Regular Sewing Machine
Free Motion Quilting for Beginners 10 Tips
Free Motion Quilting Beginner Tutorial 1 of 4
Mar 07, 2017 | Sewing Machines
Can the presser foot be raised slightly on pfaff tiptronic 2030 to facilitate free motion quilting? There is not enough clearance with feed dogs down to freely move material to quilt. Thank you.
You need a special foot for free motion quilting--it is slightly shorter in height than a regular presser foot, which essentially provides space between the presser foot and the needle plate to manually move the fabric. Sometimes machines came with a standard darning foot accessory. Your Pfaff dealer probably has at least one style in stock. But there are other specialty feet you can probably use, ie Big Foot, clear free motion foot, C-shaped, oval, etc. You can also purchase a shank adapter (verify it is the correct shank for your machine) and use it with a kit of snap-on presser feet so you can have a variety of presser feet for different functions.
Pfaff Presser Feet
Pfaff Big Foot Free Motion Quilting Foot
Pfaff Free Motion Guide Presser Foot
Pfaff Free Motion Open Toe Quilting Foot
http://www.sewingpartsonline.com/snap-on-sewing-machine-presser-feet.aspx
May 07, 2016 | PfaFF Sewing Machines
How to set 2140 for free motion sewing
Which model are you using? Creative 4.5?, On the newer machines it drops automatically once the embroidery attachment is hooked up. On older Creatives v2.x there is a slide lever in front of the presser foot on the front.
Sep 26, 2012 | Sewing Machines
How do I set my pfaff mahine up for free motion quilting
try dropping the feed dogs, & reduce the top thread tension one number at a time till the stitches are normal
Feb 27, 2012 | Sewing Machines
Can't free motion quilt on Juki-T98QE
You need to be using a free motion foot or a darning foot, the regular presser foot is not for free motion.
May 29, 2010 | Juki TL-98Q
Sewing Machines Logo
147 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
