Maytag neptune model number mah8700aww stops mid cycle and door will not open
Krazytech
  • 725 Answers
SOURCE: Maytage Neptune E3 code - Model MAH8700AWW - machine won't finish cycle
“E3” code – Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Possible causes of ‘E3’ codes: 1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause. 2. Hall Sensor fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Hall Sensor – PCB that is located on the back of the motor that senses motor rpm. It is not a separate part, but rather an integral part of the motor.
Posted on Sep 23, 2009
SOURCE: my maytag neptune washer model
there is no "red string" on this specific model. Its really irritating that everyone is saying this when clearly no one can find a red string. Stop giving this advice. From what i can tell so far the release lever is inside the machine and to get to it you have to remove the front panel. My problem now is i cant get the top electronic panel off to get the front panel off... this machine is like a giant chinese handcuff!! I will never buy a maytag ever again!!
Posted on Aug 18, 2010
  • 46 Answers
SOURCE: i have a maytag neptune washer model MAH500B that
Try to operate the machine in its final cycle, ie. Spin or drain, door release catch will operate once cycle ends.
Posted on Jan 15, 2011
heatman101
  • 43501 Answers
SOURCE: neptune washer model MAH5500B stopped working mid
Check out this tip...
Washing Machine Door Jammed
heatman101
ginko
  • 19396 Answers
SOURCE: maytag neptune front loader model
Hi.
First disconnect power by tripping circuit breaker or disconnecting power cord. While power is off access the hose connected to drain pump. The pump assembly is mounted to the right rear of the base. With power not connected undo hose from pump, collect water and remove blockage, fit the pump back. See page 63, section six in the manual below:
SERVICE MANUAL.
Regards.
Ginko
Posted on Jun 18, 2011
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
Maytag Neptune door will not open
Under the soap tray toward front there is a wire or cord to pull and that will open the door it may be green in color
Oct 20, 2014 | Maytag Neptune Washing Machines
How do I open the door to my front loading maytag neptune? It was in mid cycle, made a horrible sound and stopped running. Has all my clothes in it and I can't open the door.
Please check this link for tips to open the door that is jammed.
Make sure to drain the water by opening the drain valve manually.
Click on : Door lock
Feb 07, 2013 | Washing Machines
Our maytag neptune mah8700aww front loader will not drain and unlock the door. what do i do.
The drain pump os obviously either blocked or gone. Lie the drain hose on the ground to drain by gravity. Then have a look at the pump. This may need to be taken out as I'm not sure if there is a pump filter on this particular model. The door is designed to not open with water in the drum.
Dec 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Front Load Washer - SD error
hi there,
it appears that you have a door switch problem. the door latches on these machines are equiped with a mechanical switch and if this switch disengages in any way, the machine thinks that the door is open, even if it's not.
the code that you see is actually a "dS", which stands for door switch.
check the door latch, which is where the door switch is located.
thanks.
Sep 26, 2008 | Maytag Neptune MAH6700A Front Load Washer
My maytag neptune washer #mah8700aww,display "lo" what is?
maytag neptune washer model # mah8700aww. there is no power on the display. checked power to outlet,
Apr 29, 2008 | Maytag Washing Machines
Maytag Neptune Error Code LO
latch open it means your latch on your door is not connecting It happened to me when I switch the door to open the other way your washer wont start or will stop mid cycle if the connection isn't made it is simple to fish hopefully you haven't already paid for someone to come to fix it :)
Apr 15, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune MAH8700AWW Front load
I have a maytag neptune front loader (MAH8700AWW) unless I turn the water off @ the faucet the water continues to run into the washer after the load is done .How can I fix this.
Oct 20, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
