Question about Pentax Optio S60 Digital Camera
Troubleshooting lines in pictures
Sometimes the pictures have horizonatl lines in them. I have no idea what causes this problem, or if it can be fixed
  • pat Liske Jun 25, 2007
    This is not a printing problem. The lines appear on the camera LCD monitor!
  • DADUDEMATT Feb 24, 2009
    purple horizontal lines appear across the lcd screen and show up on the photos
    pentax support says it is a problem with the sensor and advisese me to send it in NOO
    i want a way to fix it by myself for free
    Problem Solver:
  • 40 Answers
Hmmm, kinda vague on your query. Lines show up where? I'll take a stab at the most common place where lines show up and that's on the ink jet print itself. When lines & bars show up generally you need to clean the print heads & your printer has a utility to do that - somewhere.
Posted on Jun 24, 2007
  • voufic Jul 23, 2011
    I have this problem too on a Pentax Optio S6, horizontal stripes all over the picture no brigthness control on exterior photos. It was solved by replacing a broken flat cable that controls the shutter apperture on the front of the objective. Definetly not the ccd sensor, just a faulty cable, caused by natural retracting movement of the objective.
I have Soney TV KDL-46EX713. Green lines come on/off the screen. Sometimes screen goes entirely green with background picture still visible. Sometimes only green lines flicker like in picture below.
Looks like power supply board fault. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Apr 17, 2016 | Televison & Video
I have a Sharp Aquos LC-60LE650, no picture or sound with various flickering lines, mostly horizontal. Lines come and go, sometimes moving across screen. Any help? Picture included.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 27, 2015 | Sharp Televison & Video
Two tone screaching sound
In most cases the cause would be bad capacitors in the power supply. You can get repair kits from sites like www.TvRepairKits.com to fix this
Oct 07, 2012 | Televison & Video
My t.v starts well then after a short while, the picture starts reducing its horizontal until one horizontal line is left ,then goes off. What is the problem?
The most likely thing happening is that an electrolytic capacitor is failing, causing the horizontal signal to decrease. I'm not sure if many techs troubleshoot to the component level anymore, since most circuits are incorporated into boards that they replace, to fix the problem. You can sometimes contact a Mobile TV Repair Service to come out to your place to fix it, but you should also contact Sony to see what they can offer:
http://esupport.sony.com/
It's a good idea to contact Sony, since there are recalls that occur, in which case the unit is usually swapped out.
Good luck, and hope this helps.
Jan 28, 2011 | Sony Televison & Video
Vertical lines that scoll the screen picture.
Ok this problem is coming from either your tv sets vertical circuit or the tuner itself is faulty, most likely the problem is coming from your vertical circuit with bad solder on the vertical ic or you have a faulty capacitor which can also cause this problem what i would suggest unless you have electronic experience on troubleshooting electronic components is to take it to near by tv repair shop and have then troubleshoot this circuit to see which component is giving you this problem, thank you,hope this helps.
Aug 11, 2009 | Mitsubishi VS-50705 50" Rear Projection...
Green lines in TV
Take the TV cabinet apart and unplug and replug all the circuit board connectors, that may fix the issue.
Jul 06, 2017 | Samsung HLN5065W 50" Rear Projection...
Black screen with sound only no picture.
I have same problem,it appears to be the flyback
xfr.
Apr 18, 2008 | Hitachi 32UDX10S 32" TV
Takes sometimes up to 7 times to get TV turned on and to stay on with a picture
I believe you have a loose conection in the horizontal deflection circuit,a good place to start checking is the horizonatl driver transformer ,horizonatl output transistor and output transformer,one thing to try is taping on side of the set to see if it reacts and does something different,If you are familiar with tv service this information will give you a place to start but if you are not too familar see the assistance of a servicer,it should not be expensive.
Oct 15, 2006 | Philips 32PT543S 32" TV
No power even standby LED..
This is like a car running without a driver,the horizonatl output transistor has the voltage it needs but it does not have horizontal drive signal applied to the base of the horizonatl driver transistor,the driver transistor should have a signal coming from the signal processor where the signal is generated just to get give it to the driver this driver then it gives it to the output to energize the flyback and light up the picture tube and generate a few other supplies,158 volts are there because the output is not turn on,try measuring voltage somewere else in the set and not at the collector of the output,there is a b+supply that goes to the signal processor(8 to 12 volts),check to see if you have this voltage,I couldn't tell you the pins in the siganl processor IC without squematic,It seems you know your way around tv service but be careful when checking voltages.Let Us know if you need more information.
Oct 10, 2006 | Samsung TXJ2067 20" TV
Pentax Optio S60 Digital Camera Logo
110 people viewed this question
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
