Question about Kenmore 46462 Front Load Washer
Kenmore fornt load washer
I am getting brown spots on white shirts after a load
  • 15,935 Answers
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
Kenmoore 600 washing machine. Clothes comes out with brown spots.
Are you on a well, or town water supply? If machine needs cleaning you could try running a load with just water and a bottle of CLR it is a cleaner for calcium, lime and rust I think, if it smells after that of the cleaner run a load with white vinegar in it with the water. hope it helps, good luck
Jul 03, 2017 | Washing Machines
Brown streaks on white cloths?
Hi Ralph,
It may be important to have an idea as to what caused the stain/discoloration. Carbona (http://www.carbona.com/home.php) has different products specific to the various reasons for the problem. You may be able to use bleach, depending on the fabric affected. Some white material turn yellow with bleach
Hope this helps ~ Good luck!
Alexander
Mar 02, 2015 | Kenmore 45081 Front Load Washer / Dryer
My HE top load Kenmore is staining all of my dress shirts. from small little spots to large massive areas. I am wondering what it is. I have ruined about 50 shirts so far. Could it be the soap?
If they were all in the same load, something must have fallen into/got mixed with the load, such as ink pen, etc. Full washer with hot water and add cleaning agent such as ammonia or plain detergent to clean the washer cycle.
To clean those shirts, add a 1/4 c of "Simply Green" / The Green Stuff ($ store brand) to temp appropriate water, directly spray on spots and let soak a few minutes, then wash (with or without detergent) and do a double rinse cycle. Naptha or Zote laundry BAR soap are good as "detergent". HTH
Mar 06, 2014 | managemylife.com
Sometimes I get little brown spots on my wash, like on a tee shirt or shirt. The spot will not come out on a rewash.
the main cause of this problem is a rusty object inside the machine,ie a small screw/paperclip/nail something that has come out of a pocket and is lying in the nachine,adrian,,,,,,
Aug 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
White shirts have grayish stains
try soaking the shirt with ritz's white dye.
Sep 13, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Rust in Kenmore washed clothes
Sounds like you have a bad drum bearing. I would guess that it's grees rather than rust although it will look like rust.
Please rate solution if helpful
Aug 23, 2009 | Kenmore 24032\24036 Top Load Washer
I get grey stain/spots on my white cloths
Jun 09, 2009 | Kenmore HE2 Plus Front Load Washer
Iam getting brown spots on white shorts after washing with Kenmore front loading washing machine
If it's gunk or build up the marks should wash away. In this case run a long cycle using "affresh" or "washer fresh" with an empty load and use the hottest water available to help rinse the gunk out.
If the marks do not wash away, it could be grease due to a bearing failure. Listen for loud growling or grinding either by spinning the drum by hand or putting it into a spin cycle. If this is the case, the rear tub assembly (contains bearing) will need to be replaced. Not much can be done about the ruined clothes :(
Jan 18, 2009 | Kenmore 44102 Front Load Washer
Washing leaves spots in dress shirts
What you could possibly try, is run an empty load, to wash the washer drum clean of sediment. If the washing macine drum is stained, clean it by hand with a cleaning compund, like clorox or some other kind of cleaning solution. Another thing that you can try, is to use the dish washer cleaning solution that they sell, to clean dish washers of sediment. It comes in a small white, plastic square container and Walmart sells it.
Jan 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 46462 Front Load Washer Logo
121 people viewed this question
Sal De
fordexpert
Robert Rankin
